Forum Replies Created
Right. I’ve used my
Right. I’ve used my rudimentary GIMP skills to add another set of traffic lamps in place of that massive planter. This is what I would expect it to look like:
yep! Took you a bit longer to
yep! Took you a bit longer to post doing all those fancy graphics 🙂
I think the traffic lights here will not conform to standards. It’s a mess.
Well, I won’t link to his
Well, I won’t link to his video, but I’m going to do the analysis he missed: I think this cyclist rode through the red by mistake.
If you watch how they ride, they are diligently following the zig-zag cycle lane markings to get over the tram tracks. That is not the behaviour of a reckless light jumper, they would have taken the straight-line over the junction.
Then if you look at the light sequence on street view, it’s not that clear. Normally, when you have green lights either side of a junction, it means you can proceed. Also, you normally have red lights both sides of a road when you should stop.
When the left green arrow comes on, you might think to follow the cycle path that goes initially to the left. Confusingly, when it’s clear to go ahead, there are just two green arrows on the right and red lights both sides.
Careless you-tubers give
Careless you-tubers give careful cyclists PTSD?
Another factor might be low
Another factor might be low sun. If this website is to be believed, sunrise on the day of the incident was 05:16 – one minute after the stated time of collision.
There’s also a strava segment: https://www.strava.com/segments/3549942
The quickest rider down that segment passed the collision location doing 35mph, so it’s quite possible to get some speed up down there.
The google satellite imagery
The google satellite imagery of this junction seems to show the path vehicles typically take when right-turning out of this junction, you can see some black tyre tracks and wearing of the road markings.
It also appears that the cyclist would have been riding downhill at the time, so could have been approaching the junction with some speed.
The give-way markings have been re-painted sometime between Jun 2021 and Feb 2022.
OnYerBike wrote:Maybe I’m cynical too, but it certainly seems to me like this person is using their disability as an excuse to throw a hissy fit about having their routine disrupted slightly.I suspect the crux of this matter is exactly as you state. Possibly one of those people wealthy enough to lunch regularly at The Ivy, yet too tight to pay for parking.
What this person needs to do is consider buying a mobility scooter. They would then have the freedom to negotiate Bath’s unevenly paved pedestrianised areas independently.
The headset bearings are
The headset bearings are likely to be lubricated with white lithium grease, which is good down to -25 deg C, so that should be fine.
I think brake fluid is also ok down to those temperatures too.
What might be an issue, is if you get water trapped somewhere and it freezes, the ice expanding could cause something to break. So as long as it’s dry, I don’t think it will be a problem.
To be fair, it’s not like
To be fair, it’s not like there’s much enforcement of the illegal e-bikes that can go way faster than 20mph anyway.
If it was GPS ringfenced, like rendel says, similar to the way drones won’t fly in certain areas, then it could work. It might even mean that less people are tempted to ride illegally modified bikes.
chrisonatrike wrote:I don’t know where the 15.5mph / 25kmph thing originates but – whisper it – the same rules apply “on the continent”. If you Google there appear to be EU directives about this. They probably stole it from the UK though.I think the 15.5mph limit probably comes from the Dutch ‘snorfiets’, a moped with a maximum speed of 25kph that is permitted to use cycling infrastructure and where no helmet is required to ride (although this is changing).
https://bikecity.amsterdam.nl/en/inspiration/mopeds/
As much as the Dutch don’t like mopeds on the cycle lanes, I do think having to cater for moped traffic has resulted in a better standard of infrastructure.
Well maybe there’s an
Well maybe there’s an argument for another category of e-bike, 20mph, no licence, registration, helmet or insurance requirement, but banned from shared paths and some cycle lanes. It’s not like the bikes don’t exist, it’s what the majority of e-bikes sold in the USA are limited to.
If you live in a city blessed with infrastructure and where 15.5mph is enough, you get one of those. If you’ve got a longer commute on rural roads and A-roads with next to no cycling infrastructure, you get a 20mph bike.
At the point where you’re
At the point where you’re considering a speed pedelec in the UK, you’d be better off just getting a moped with all the regulations that involves – including having to wear a motorbike helmet. I did briefly consider it before dimissing the idea.
I get your point about lack of training etc. but there’s nothing stopping someone buying a road bike with no training and riding flat out on a shared use path. I don’t think a slight uplift to 20mph would be problematic.
Personally, I would like to
Personally, I would like to see the power and speed limit for e-bikes increased to 500W / 20mph.
In a city, it means you *shouldn’t* have to deal with close passes in 20mph limits.
For my previous, mostly rural commute, it would have meant a shorter journey time. But crucially, it would have made the decision to get an e-bike a no-brainer.
Although I often thought about it, I never bothered getting an e-bike. I got quite fit on the road bike and during the summer, could average 17-18mph – hitting 40mph comfortably on the downhill sections. So I was unsure of the benefit I would get from an e-bike. It might have made the commute less effort, but could have actually taken longer, as it might have slowed me down on the flat sections.
The other day I was comfortably keeping up with someone on one of those silly Super 73 style bikes – uphill on my 20kg dutch bike with hub gears (and I am not fit these days, it was struggling to do 12mph)!
December 2, 2022 at 11:02 am in reply to: Car crashes into building – please post your Local news stories #966671HoarseMann
Cars are at it again – police quickly determined this was just an accident…
Nice. Even a bit of blue sky.
Nice. Even a bit of blue sky. Image needs rotating…
