Forum Replies Created
Viewing 15 replies - 541 through 555 (of 559 total)
  • in reply to: Britain’s Best Cycling City? #931327
    srchar wrote:
    Stevenage.
    Well, they nearly got it right in Stevenage…
    https://www.theguardian.com/cities/2017/sep/19/britains-1960s-cycling-revolution-flopped-stevenage
    Certainly a better attempt than Milton Keynes. At least in Stevenage it’s the road that varies in elevation at underpasses.
    in reply to: Britain’s Best Cycling City? #931321
    Last time I visited Newcastle
    Last time I visited Newcastle upon Tyne I was impressed with the investment in cycling infrastructure. Particularly John Dobson Street, which was a dual carriageway that’s now been converted to a cycle and bus lane.
    If fact, I was so amazed by the cycle lane, I didn’t see the sign that said buses only and got caught in the bus lane by an anpr camera (whoops!).
    https://www.sustrans.org.uk/sites/default/files/file_content_type/bike-life-newcastle-2017-report.pdf
    in reply to: Help identify this vintage Raleigh. #931223
    Something along these lines
    Something along these lines perhaps…
    https://singlespeedcomponents.co.uk/blogs/single-speed-bike-gallery/16388628-ssc-build-triumph-palm-beach-rebuild
    Good luck with it. Be interesting to know whether you managed to get the 700c wheels to line up with the brake calipers.
    in reply to: Help identify this vintage Raleigh. #931219
    CygnusX1 wrote:
    [quote=HoarseMann]Looks almost identical to my 1950’s Triumph Palm Beach. I think you are right about the pedals being replaced at a later date. I spotted the same style of pedals on a bike in this 70’s brochure. Check out the ‘Grand Prix’ on page 4… http://vue.usc.edu/images/Raleigh-Catalog-1969.pdf%5B/quote%5D
    What year is your Triumph? Raleigh bought Triumph cycles in 1954 and moved production from Coventry to Nottingham so its possible they share a lot of common DNA.
    Yes, those look like the pedals I have.
    I think it’s 1954 (from the stamp on the sturmey hub), so that would explain the similarities. It’s even got the same grease port on the bottom bracket. Mine was a skip find, paintwork was awful but bike was complete. Got someone to blast & respray it and he’s like, are you sure? It’ll be £70 and it’s nowt special. Bike served me well for years and was invisible to bike thieves at the time as all they wanted were mountain bikes.
    Probably not worth restoring unless you are looking for a project. Getting the right size rims will be the tricky bit. But could make a good singlespeed hack bike.
    in reply to: Help identify this vintage Raleigh. #931201
    in reply to: Ball bearing in head cap bolt #931247
    Could you unbolt the
    Could you unbolt the handlebars from the stem and unscrew the whole stem? If you pull up on the stem whilst unscrewing it there might be enough friction between the bolt and head cap to loosen it.
    in reply to: Help identify this vintage Raleigh. #931189
    Looks like a Raleigh Superbe.
    Looks like a Raleigh Superbe. It’s got the little wheel by the seat post for the sturmey 3 speed cable, which makes me think it could be a bit earlier than the 70’s, maybe 1950’s?
    https://www.google.co.uk/search?q=raleigh+superbe&safe=active&client=safari&hl=en-gb&prmd=sinv&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjq_JXloMreAhWRF8AKHbJpBCgQ_AUIEygC&biw=768&bih=899#imgrc=EaB0xErCXtZwcM
    in reply to: Cycle frame paint. #931165
    A clear laquer top coat might
    A clear laquer top coat might help. But sounds like the undercoat hasn’t bonded to the frame properly for some reason. A wipe down with a solvent before painting next time will help remove any last traces of grease before priming.
    Or could be the paint is just not tough enough, might need to look at the car spray cans in Halfords as an option. I’ve had success respraying a frame with those.
    However, spray can paint is not as tough as the powdered enamel that is more commonly used on new bikes. But you need a spray booth, airline, mask and oven for that – or find a company that can do it for you.
    in reply to: Novertakes – how to avoid them #931125
    Sometimes I deploy ‘wobbly
    Sometimes I deploy ‘wobbly cyclist’ mode in this situation. Weave about a bit in the lane from primary to the offside edge of the lane looking like I’m thinking about overtaking the car in front. Puts off driver behind as I look so unpredictable.
    Indicating to turn right can also work (then sort of edge out a bit rather than make a right turn and eye contact & a wave back to thank the vehicle behind for waiting).
    But like any of these sort of hacks, there’s a time and a place. If it’s a busy city centre with lots of filtering traffic you don’t want your weaving about to cause a collision. Plus you need to know what’s approaching in advance, so works better if you ride with a mirror.
    in reply to: Sign of the times? #930707
    in reply to: Young couples are getting trapped in their cars #930153
    Hannah spends 20mins driving
    Hannah spends 20mins driving 1.5miles to work and Peter can’t cycle as there are too many cars, so he drives.
    Depressing.
    These big developers need to be forced to do more to provide adequate active travel options. Not going to be much of a community with everyone isolated in their cars and the pavements deserted.
    https://www.bbc.co.uk/news/uk-45970349
    in reply to: Hutchinson Sector 28s sketchy in the wet? #929053
    Stratman wrote:
    Thanks all for the comments, I may be running them at too high pressure, I’ll try them a little softer.
    I’ve ridden the same hill hundreds of times on GP4S and never once had a slip.
    On the few occasions I’ve been swayed by the claims of the latest and greatest, I’ve always ended up going back to Conti’s.
    in reply to: Why does anyone commute into town centres in cars? #929157
    A big reason is taking the
    A big reason is taking the car involves no forethought or planning.
    There are a lot of things to consider when taking the bike. Once you are in the routine of commuting by bike it’s ok, but there is a hurdle to overcome that not many can be bothered to tackle.
    in reply to: Why women don’t cycle? #921321
    Safety is the biggest concern
    Safety is the biggest concern for my wife.
    On the UK roads most drivers are considerate, but there are enough bad drivers to almost guarantee a scary incident on every ride.
    Cycle infrastructure should help, but in the UK it is often a muggers paradise of quiet alleyways lined with bushes.
    Then you’ve got the occasional aggression just for being out on a bike minding your own business…
    https://youtu.be/WYV6o_Nyszc
    in reply to: Garmin Touring directions alert issues #920985
    Use ridewithgps.com (there’s
    Use ridewithgps.com (there’s a free sign up option) to create a route and export the route as a .tcx. Drop that file in the NewFiles directory on the garmin and see if that works.
    These ‘head south’ turn by turn notifications usually crop up when your route planning software has embedded notifications in the route file, rather than letting the garmin deal with it.
