Forum Replies Created
Viewing 15 replies - 121 through 135 (of 559 total)
  • in reply to: Drivers and their problems #1000841
    Well, I’m on the driver’s
    Well, I’m on the driver’s side this time. If he spent the 12 minutes trying to pay for parking before giving up and leaving, then he shouldn’t be fined.
    It annoys me how it seems so easy to fine drivers for (not even) a minor parking offence, yet careless driving largely goes unpunished.
    Well, they’re in the right
    Well, they’re in the right place!
    in reply to: Drivers and their problems #1000709
    andystow wrote:
    I suppose there’s always a remote chance that the drivers are not seeing the “SLOW” sign right before the gentle bend, though.
    Or noting that this is a signed cycling and walking route, so they should be driving with even greater consideration that they are likely to encounter vulnerable road users… https://goo.gl/maps/tTaLr4uBqsdmChWH7
    in reply to: Drivers and their problems #1000677
    I like to think this driver
    I like to think this driver bought a 4×4 for the one time a year they visit a music festival…
    https://cdn.road.cc/wp-content/uploads/roadcc/365319849_6703211459742174_9172900858670355985_n.jpg
    in reply to: Mesh wifi #1015731
    I’d definitely try relocating
    I’d definitely try relocating your router more centrally first before going the mesh route.
    Not only is the upfront purchase cost of a mesh system going to be more than a length of Ethernet cable, but the ongoing electricity consumption for each mesh node is not insignificant.
    in reply to: Test: embedding an image in the main forum post #1015477
    If you delete this newly
    If you delete this newly posted image comment, does the original image remain on the server and still appear in the main post?
    (ie. Does deleting the comment leave the image, as opposed to deleting the image from the comment?)
    in reply to: Desert riding #1015371
    Well you have been busy! Nice
    Well you have been busy! Nice photos, thanks for sharing.
    in reply to: Iffley Lock Oxford – Footpath or Offroad Trail? #1015343
    Cycling is permitted on that
    Cycling is permitted on that section with the orange dots. The River Thames is managed by the Environment Agency. There are certain sections of the Thames Path national route that are suitable for cycling, this is marked as a suitable section on the national trails map:
    Thames Path Map and Trail Information
    https://road.cc/wp-content/uploads/roadcc/Screenshot 2023-07-24 at 15.48.02.png
    in reply to: Commuter shorts recommendation please #1015311
    Any sort of chino shorts tend
    Any sort of chino shorts tend to work well if they’re an elastaine/cotton mix, it doesn’t have to be a technical fabric.
    If the bike is fairly upright and has a big padded saddle, then normal clothes work (although I’d steer clear of any expensive high-fashion items!).
    As for quick drying, I just try not to get wet. I’ve a poncho that is always in my pannier bag ready to go at the slightest hint of rain.
    in reply to: Garmin “Make a U-Turn” problem #1015221
    Fingers crossed it works. It
    Fingers crossed it works. It should just beep once and say ‘off-course’ until you rejoin then it’ll pop-up ‘course found’.
    Cyclist failing to stop at
    Cyclist failing to stop at cycle path crossing causes BMW driver to crash!
    (only joking, it was a drunk driver of course! But not bad reporting from the local rag and I had never appreciated that a traffic calming feature could double as a trap for drunk drivers. We also now know what the bar is for Thames Valley Police to take swift action!)
    https://road.cc/wp-content/uploads/roadcc/b25lY21zOjE4MzEwMmI3LThmYjQtNDRmZC04M2RlLTVkY2E1ZThlOGQxZDoxNGUxODE0Ny0wMDIwLTQyNTYtOTkyMi0yYjMwMDExMGQyMzM=.jpg
    in reply to: Drivers and their problems #1000285
    Finally, let’s cross to Wellingborough, Northamptonshire the largest place I know of where town centre off-street parking is free (although its days are probably numbered now). Do we hear the sound of happy traders, of a retail boom town? Well not exactly…
    There are happy traders and a retail boom happening near Wellingborough at the free (for 5 hours only) parking oasis that is Rushden Lakes.
    in reply to: Garmin “Make a U-Turn” problem #1015217
    There’s a setting to turn off
    There’s a setting to turn off automatic (or prompted) recalculating a route if you go off-course. That should stop this sort of annoying message.
    I did try ‘prompted’ re-routing for a while, but it just keeps nagging you to recalculate the route.
    Thanks, I might be tempted to
    Thanks, I might be tempted to try the washers, at least on the rear as the problem is worse there.
    Yes, I expect a lip on the
    Yes, I expect a lip on the pad is worse than on the rotor. As well as the shuddering, if they protruded enough, they could touch and reduce braking performance.
    I think all things considered, I’m better off having a lip on the rotor and the alignment is probably not too much of an issue. The post mounts are square and look to have been ‘faced’ for a tight fit with the caliper mount, so sticking a washer in there is probably not a great idea as it could cause the caliper to be off centre or could damage the face of the post mount.
