mark1a
Forum Replies Created
Viewing 15 replies - 46 through 60 (of 344 total)
  • in reply to: Campagnolo, they make me weep… #1022865
    mark1a
    I think you’re going to have
    I think you’re going to have to get over Campagnolo if they’re not going to fulfil your mechanical & ratio needs and consider Shimano for their wide range of reliable, good value drivetrain components.
    in reply to: Drivers and their problems #1004825
    mark1a
    Younger viewers will be interested to know that the character featured, played by comic Harry Enfield is “Loadsamoney”, an otherwise nameless London plasterer getting rich in the late 1980s building boom.
    Bish bosh shoom shoom wallop – dosh!
    in reply to: Garmin volume issue #1022823
    mark1a
    I think it’s due to an
    I think it’s due to an “undocumented feature not available in the next release”* introduced by a recent update of the Garmin Connect Mobile app. There’s a few threads in the Garmin forums about it. I suspect it will go away when Garmin update the app soon.
    https://forums.garmin.com/sports-fitness/running-multisport/f/forerunner-945/376590/the-audio-prompt-reduces-the-music-volume
    * software bug
    in reply to: di2 problem #1022755
    mark1a
    If I were you I’d get the
    If I were you I’d get the system plugged into E-Tube software with SM-PCE02 and check the system for battery drain issues, just in case the new battery solves the problem short-term but then doesn’t hold charge in future.
    https://bettershifting.com/how-to-troubleshoot-di2-battery-drain-issues/
    in reply to: The Reform Party and the UK’s lurch towards fascism #1016937
    mark1a
    chrisonabike wrote:
    I note they didn’t bring back Blair’s pledge card!
    They kinda did… different pledges (they called them commitments), and there were six not five (one louder).
    https://www.theguardian.com/politics/article/2024/may/16/labour-six-pledges-how-likely-success
    in reply to: What happened with carbon road forks? #1022691
    mark1a
    I don’t think I’ve seen a
    I don’t think I’ve seen a disc brake compatible road fork with the aesthetic you describe, I’m not sure but it could be that the thin, curved design does not lend itself to the increased structural requirements that a disc caliper needs on a fork.
    Also, I’d be careful with putting a curved fork onto a bike head tube angle designed for straight forks, it’s possible that any small difference in trail and rake measurements could adversely affect handling. I’m not an expert on this, but it might happen.
    Anyway, good luck with your search, I scratched the Ti itch a year or two ago, with a Vaaru MPA. It’s not quite what you’re looking for as it has a straight carbon fork (the Ti fork option is also straight), but as my winter hack it’s a lovely bike to ride.
    [cue yet another gratuitous photo opportunity…]
    https://cdn.road.cc/wp-content/uploads/roadcc/vaaru_mpa_0.jpg
    mark1a
    mdavidford wrote:
    Maths question for anyone who can be bothered:
    Given that the theory test is multiple choice, with four choices per question, and a pass mark of 86%​
    According to the binomial distribution calculator at WolframAlpha, the probability of getting 43 out of 50 in a single test with 1/4 chance on each question is 1.819e-19, I think I’d go with actually knowing the answers to the questions.
    in reply to: Pictures of your Bike #685447
    mark1a
    I’d happily pay up to £15 for
    I’d happily pay up to £15 for a set of those.
    in reply to: Tubeless woes #1022077
    mark1a
    I’ve had some similar
    I’ve had some similar experiences to yourself with road tubeless – first tried in 2018 with Mavic’s (new at the time) road UST, it was useless, had 3 unsealed punctures in 4 rides, after running (Stans) tubeless on much lower pressures successfully on MTB & gravel bikes. I concluded it was a combination of trying different sealants (Mavic, Orange & Muc-Off) not sealing on 25mm tyres at 95psi in the wet. Plus Mavic tyres seem to get cuts if you even look at them. Went back to tubes at the time on the winter bikes.
    Forward to 2022, I put tubeless again on a winter bike (Hunt 4 Seasons and Schwalbe G-One Speed 30mm at 65psi) and it seems so much better. Get a fair bit of weeping and a lot of sealed holes but minimal pressure loss, and now on a summer bike which I’ve put Roval CLII on with Conti GP5000S-TR, 30mm front, 28mm back at 70psi, it’s been absolutely fine.
    My conclusion is that road tubeless, in my experience, works best with lower pressures, and with Stans fluid, with some Stans Darts in my jersey pocket (not used yet). The higher pressure just doesn’t seal in time with the lower volume, particularly in the wet. I asked a mechanic in the LBS what sealant they personally used out of the 6+ they sell, he replied “we all use Stans at lower pressures”
    Anyway, good luck!
    Also I should add (from personal experience) that when following andystow’s advice on a thorough shake, always make sure the lid is on properly.
    mark1a
    Energy from the Severn – it’s
    Energy from the Severn – it’s always baffled me why one of the highest tidal ranges in the world can’t be harnessed for a clean, predictable and reliable source of energy.
    Supervised drug consumption – bring it on, should form part of all harm reduction intervention policies.
    mark1a
    Agreed, I sold a couple of
    Agreed, I sold a couple of wheelsets on eBay recently, so not heavy, but a large box. Around £14 for insured 24 hour service, both sets arrived undamaged via Parcelforce.
    Obviously packing is key, and in a suitable box, appropriately marked as fragile.
    in reply to: SM-BCR2 to Mobile #1021367
    mark1a
    The SM-BCR2 has a lead with
    The SM-BCR2 has a lead with the proprietary 2 pin connection for the junction A, and a micro-USB for connection to host device. I’ve never tried connecting it to an Android device and I’d be surprised if it works on a hardwired connection using the mobile app as even the PC application has a weird USB implementation, I couldn’t get that to work reliably on a Mac using VMware or Virtual Box, I’ve only ever got it working either on a hardwired connection with WIndows running natively on the bare metal, or over Bluetooth using the phone app.
    So I’m doubtful and this also seems to be confimed by bettershifting.com (sometime of this parish)
    https://bettershifting.com/di2-e-tube-software-and-downloads/
    One other thing, it appears Shimano seem to have deprecated the old PC software which could use the SM-BCR2, last version which works is 4.0.4, so I’m running E-Tube v5 with a SM-PCE02 and can go back to E-Tube v4 with a SM-BCR2.
    in reply to: Pictures of your Bike #685405
    mark1a
    Rendel Harris wrote:
    …is there anything cool in the bike line you haven’t got?!
    I hope not.
    in reply to: Pictures of your Bike #685397
    mark1a
    I tried something similar
    I tried something similar with some timber and a pair of Delta hitches, with (unlike yourself) limited success, and so for people like myself with minimal (zero) woodworking skills, the Vergo range from Minoura is an off the shelf alternative.
    https://cdn.road.cc/wp-content/uploads/roadcc/minoura_vergo.jpg
    in reply to: Favourite funny #1021083
    mark1a
    https://cdn.road.cc/wp-content/uploads/roadcc/theoretical_cyclist.jpeg
