What happened with carbon road forks?
  • This topic has 24 replies, 16 voices, and was last updated 2 years ago by HoarseMann.
  • #32907
    JohnM16
    Hi Folks,
    apologies already if this bores you. Feel absolutely free to read something else instead. Plus, I’m old and grumpy;  don’t say I didn’t warn you.
    OK, I’m building a lightweight endurance road bike (NOT a gravel bike:  not even an ‘occasional’ gravel bike), with a Ti frame (haven’t even decided which yet), hydraulic discs and mechanical shifting. The idea is to replace my summer and winter bikes with a single frame, two sets of wheels, no corrosion and more comfort.  Aiming for about 7.25kg to 7.5kg overall (summer weight) for a 54cm.  Also, a disc Ti frame is going to need thru axles.
    With very few exceptions (Firefly, the gorgeous but eye-wateringly expensive Tom Sturdy frames) lightweight Ti road frames come with carbon forks.  I’m OK with that, except that I’d like a slightly curved/tapered fork to give my wrists an easier time,  and proper mudguard eyelets at the end of the fork.
    My old summer bike (an ancient but lovely aluminium DeRosa Planet) has Columbus Minimal carbon forks. Curved, tapered, elegant, really light (350g).  No eyelets, but I don’t ride it in the wet.
    Most pure road Ti frame/carbon fork combinations have ugly straight forks (yes, I know, it’s subjective) minus eyelets. The few that can take mudguards are essentially using gravel forks: over engineered, much too wide (why would I want 50mm tyres on a road bike?) and thus heavier than necessary, and pretty uncomfortable to ride (I’m old, I got old wrists…) for long distances. They soften things up with less steep frame angles and supposedly ‘engineered fork compliance’.  I don’t buy that: with a straight fork,  virtually all the forces end up at the fork crown, which ends up looking like a trucker’s forearm.
    I can’t believe there isn’t a market for a proper lightweight (400g? 425g?) and elegant looking road disc fork that includes mudguard eyelets for winter riding.  There seems to be an absolute assumption that anyone who wants a lightweight road bike is going to be happy with clip-on guards (or none at all); I’ve tried them and have not been impressed.  And no, I’m not bolting P-clips to my forks.
    This isn’t a cry for help;  it’s just a polite rant.  I’ve looked around, and I don’t think anyone (yet) makes the fork I’m describing.  It’s really not a big ask,  and I’m sure a lot of winter-riding roadies would appreciate the option.
    Take care all, watch for those close passes…
    John M.
Viewing 15 replies - 1 through 15 (of 24 total)
  • #1022729
    How about a lightweight-ish
    How about a lightweight-ish suspension fork? Like a Lauf or Roxshox Rudy?
    #1022727
    S.E.
    There are very strong and
    There are very strong and efficient rim brakes, I’m still not convinced that disc brakes are better for the road, they incite us to take more risks, and in emergency situations I feel it’s easier to lock the wheels… They come from MTB, where forks have suspensions (and so straight legs, even before CF).
    You can build curved carbon forks for disc brakes, as shown by Pinarello in Matthew’s post, they even have S shaped forks if you like that… but that’s just not the most obvious way to achieve different structural engineering requirements.
    Compared to rim brakes, forces are at least 5 x greater with rotors (shorter lever arm), they impact a much weaker part of the fork, and last but not least they act asymetrically… all 3 reasons that require much stronger legs, this is obviously the main reason behind these ugly and massive beams – and the loss of the shock dampening traditional shape of old steel forks, because you don’t want flexibility at this level!
    That said, I also get weird vibes when the profile of my bike is appears on my desktop backround wallpaper, i am stuck, like fascinated… it’s both so close yet so different than the century old archetype of a bike…
    #1022725
    JohnM16
    Hi David,
    Hi David,
    thank you;  but I really don’t have wrist “issues” (never had them over 40+ years of rock climbing).  I’m just used to riding a nice (but heavy) steel frame that irons out road buzz.  Ask yourself why there are so many ‘wing’ style carbon handlebars now that so specifically address soaking up road shock.
    The perfect solution would be Ti disc forks, but I can’t get a second mortgage…
    Cheers
    #1022723
    JohnM16
    Drill?  No disrespect, but
    Drill?  No disrespect, but you gotta be kidding me…
    #1022721
    JohnM16
    I did specify disc forks:
    I did specify disc forks:  the Alpinas look a lot like my columbus Minimals.
    Cheers
    #1022719
    matthewn5
    What about some Pinarello
    What about some Pinarello Onda forks? Not quite the classic forward curve, but certainly not straight. You could (cautiously) drill the ‘wings’ to mount mudguard stays…
    https://cdn.shopify.com/s/files/1/0038/7806/0144/products/P1510554.jpg
    #1022717
    JL77
    I’ve been told that fork
    I’ve been told that fork compliance for comfort lies mostly in the steerer tube. For this reason (and because of the offset/rake) I went for an Enve fork that is tapered 1 1/4 to 1 1/8 instead of 1 1/2 to 1 1/8. With a headset to suit. I think that Whiskey and Ritchey may also offer similar forks. Btw, do not take a different offset for comfort. Offset combined with head angle are for determining trail (in combination with front center; the latter affecting weight division and toe overlap).
    #1022715
    ErnieC
    jaymack wrote:
    jaymack wrote:
    You’re absolutely right but I suspect that carbon forks are staight ‘cos their designers are stuck with the short comings of the material with which they’re working. Should you manage to satisfy your heart’s desire please say as I’d be delighted to know before I look to buy next year’s big-birthday present to myself
    I have straight steel forks on my Master and no short comings with steel as a material.
    #1022713
    You may well be able to
    You may well be able to address your wrist issues in the gym.
    #1022711
    quiff
    jaymack wrote:
    I’m no engineer or materials scientist, but isn’t it equally likely that they’re working with the properties of the material, whereas introducing a curve is just replicating a design based on the properties of the older materials? I do have a curved carbon fork from 10 yrs ago, but for rim brakes.
    #1022709
    quiff
    OP wants something that will
    OP wants something that will take disc brakes.
    #1022707
    mtbtomo
    #1022705
    Richbeck
    Not curved, but very nice
    Not curved, but very nice looking – a pal has these on his handbuilt steel – lots of compliance https://woundupcomposites.com/product-category/gravel-x-forks/
    #1022703
    JohnM16
    Lovely bike;  one of the
    Lovely bike;  one of the frames I’m considering.  I suspect one day he might do a curved Ti fork as well, like Sturdy’s.
    Remember, I didn’t say they had to be thin: just not over-engineered.  I fully appreciate that disc forks are going to be heavier.  But they don’t have to look like girders either.  The Ritchey cross (?) fork mentioned by OnYerBike is getting closer to the mark,  but there’s a lot of spare material on it.
    Also, I really wouldn’t just swap a fork without considering exactly where the axle was going to be, relative to the head tube.  As you imply, you might end up with something unrideable.
    It’s just that if my **ideal** fork existed,  it would really be the only choice of disc road fork that would suit summer and winter riders;  and weight weenies.  And I guess frame makers would manufacture frames to suit it.  They would be called “road frames”.
    Cheers
    JM
    #1022701
    JohnM16
    Thank you for the advice:  I
    Thank you for the advice:  I’ll do some more digging.
    The reason for straight forks (especially) on gravel bikes?  Could it be that they’re easier to make?  When you’re encouraging people to ride 45mm tyres (yes, I know folk use skinnier ones), you don’t gotta worry about the fork design so much.  Never underestimate the power of mass manufacturing to force choices on consumers.
    And curved forks aren’t just an aesthetic.  I’m certain the reason carbon forks are so over-engineered (aka thick and heavy) at the fork crown is because that’s where most of the shock/bending forces end up.  Steel forks could have been made straight, way back in the day (and they’d have been cheaper to make), but they weren’t (and still aren’t), and there was a reason for that – to soften shocks from the road.  My Columbus Minimals feel great;  but they are taking the conventional approach to disc forks.
    I’m still planning on lightweight, so suspension stems are out.  Also,  if you think about it,  they are just trying to compensate for a failure to design decent forks in the first place.  Have a look at the reasons why people like well designed Ti frames (or steel) as opposed to carbon.  It’s down to the feel, and I don’t think straight carbon forks can ever offer that.
    Best
    JM
