mark1a
Forum Replies Created
Viewing 15 replies - 316 through 330 (of 344 total)
  • mark1a
    It’s like reading “From the
    It’s like reading “From the message boards” in Private Eye…
    in reply to: Wahoo Element Bolt and MacBooks #993113
    mark1a
    Yesterday on the other thread
    Yesterday on the other thread you said you’d fixed it by reinstalling Garmin Express:
    https://road.cc/content/forum/garmin-gremlins-293335
    And that it wouldn’t connect to Windows either.
    Just mentioning before you spend £300+ on a replacement head unit when the issue may lie elsewhere. Of course if you just want a new head unit, carry on…
    in reply to: Garmin Gremlins #993025
    mark1a
    It didn’t connect to a
    It didn’t connect to a Windows OS though either, is there a device option to select mass storage mode for USB on the Edge itself?
    in reply to: Consultation Doc on Weights and Measures #993039
    mark1a
    hirsute wrote:
    Tea Stop
    You want to talk but you don’t want to talk about bikes? do it here!
    Ah yes I see, thanks.
    in reply to: Consultation Doc on Weights and Measures #993035
    mark1a
    I was looking for a cycling
    I was looking for a cycling reference and couldn’t find one.
    in reply to: Thru axle adapter #992969
    mark1a
    Fulcrum (Campag) UK
    Fulcrum (Campag) UK distributor is I-Ride, and they have this:
    https://www.i-ride.co.uk/products/components/wheels/mtb-wheels/kitfcraqr-rp9-5-cup-for-rear-hub-hh12/?sku=RF1134989
    Might be worth getting in touch to see if this is compatible with 800s, even if not in stock.
    If it is compatible, seems to be available here:
    https://www.lordgunbicycles.co.uk/fulcrum-kitfcraqr-hh12qr-rear-hub-adapter
    Lordgun ship from Europe so VAT may be due on arrival.
    in reply to: Thru axle adapter #992959
    mark1a
    Adapters are easy for the
    Adapters are easy for the front wheel as both TA & QR are 100mm dropout. Rears typically could be 130mm (rim QR), 135mm (disc QR), 142mm (disc TA) and others. Therefore the rear dropout width has to get narrower for QR. Depending on the wheels, the manufacturer may supply suitable replacement endcaps, for example the Mason x Hunt 4 Seasons I run 2 sets of on my winter road and gravel bikes can be switched over in minutes by replacing hub caps. If your wheel manufacturer doesn’t do this, I can’t see a cost effective way of converting without changing the hub.
    in reply to: Ride London Start Time #992743
    mark1a
    It was OK for me, I had a
    It was OK for me, I had a 0600 wave time/0640 start time, ended up getting away at 0620. I suspect a few earlier riders delayed their start to avoid catching the safety car, which let others go early, but then compounded into the later starts.
    mark1a
    That sucks. This is the kind of thing that bugs me about proprietary systems and the artificial problems caused by companies and their tech.
    Does the Karoo just use ANT+ to talk with the Di2 system or can it use Bluetooth? (I use a Wahoo Bolt, so am not directly affected by this).
    Di2 only broadcasts on ANT+ via a private channel, as the D-Fly units predate the open standard ANT+ shifting protocol that Campagnolo and SRAM adopted after that became a standard. So no Bluetooth and Shimano presumably have no intention of moving away from their proprietary protocol.
    It doesn’t affect me as a Garmin Edge user, but it bothers me that Shimano could one day see Garmin as a competitor (power meters) and switch the same functionality off.
    Wahoo could be in the same boat now they’ve acquired Speedplay.
    in reply to: what’s wrong with self assembly? #992349
    mark1a
    Self assembly? I thought that
    Self assembly? I thought that there’s a 50/50 chance that they leave Halfords like that.
    in reply to: Cycling Shoes Advice #992267
    mark1a
    Certain SPD pedals can be
    Certain SPD pedals can be temporarily converted to flat pedals, depending on how much you want to ride in flat shoes, probably OK for infrequent use:
    Shimano SM-PD22
    https://www.bikester.co.uk/shimano-sm-pd-22-pedal-attachment-pedal-attachment-with-reflector-M169808.html
    BBB version
    https://www.merlincycles.com/bbb-bpd-90-feetrest-spd-pedal-adaptors-86845.html
    in reply to: Shimano Hydraulic Brake Version of This? #991605
    mark1a
    Contact r3pro themselves
    Contact r3pro themselves https://www.r3pro.co.uk/ appears to be run by somebody called Phil who makes a multitude of stuff using 3D printing, ideal for low volume. They sell a lot of other disc brake caliper/piston accessories so they may be open to a Shimano piston block.
    in reply to: Interesting book #991381
    mark1a
    https://cdn.road.cc/wp-content/uploads/roadcc/letitgo.png
    in reply to: Intriguing new folding bicycle – Kwiggle #990477
    mark1a
    I wonder if these will be
    I wonder if these will be stocked by Halfords?
    in reply to: New Garmin bike computers #990347
    mark1a
    Agree with above, if it suits
    Agree with above, if it suits your needs now at the price you like, that won’t change when a new model ships, and to add to that, historically the flagship model of a particular generation comes out first (i.e. 1030 before 530/830), and there’s no visibility of anything in a new x40 range. In terms of the “plus” models, when the 1030 Plus shipped, the 1030 got most of the non-hardware features (except the licenced Trailforks maps) by way of a firmware update. So it’s likely if/when a 530 Plus comes out, the 530 may possibly get some of that functionality too within a month or two.
    Having said that, Garmin, like many companies, have had their product roadmap affected by the pandemic, and I would say that the current global chip shortage is continuing to have an effect so previous release cycles possibly not a guide to future events – Garmin will ship what they can make with the supply chain they have.
