Forum Replies Created
Good point. If I’m driving
Good point. If I’m driving and stuck in traffic, I always get out and ask the drivers behind the purpose of their journey. If it’s more important than mine I let them pass.
If I disable javascript, I
If I disable javascript, I get the behaviour you describe (images not loading, three blobs, text only). In some browsers, it is possible to disable javascript on a per website basis. I wonder if this has somehow happened on your computer?
matthewn5 wrote:I’m seeing ‘m.stripe.network’ in the ‘loading’ messagestripe is a payment system – and that url is part of a javascript call (see stripjs section) seems legit…
https://stripe.com/privacy-center/legal#stripejs
Could be a javascript blocker your end? Try a different browser?
Or maybe a DNS cache issue? Maybe try changing your DNS server to google’s 8.8.8.8?
He pleaded guilty to the
He pleaded guilty to the lesser offence of death by careless driving. So will be sentenced for that tomorrow.
I guess one downside to winning the lottery is you lose the financial hardship plea…
I wouldn’t go as far as
I wouldn’t go as far as saying terrible. I’ve been using them successfully for years. I’m sure the more recent Go Pro’s have better image quality, but the Cycliq cameras win in other areas, such as battery life and ease of use as a day-to-day ‘dashcam’.
I was hoping someone would
I was hoping someone would post here that they’ve got a camera that works great in the dark – maybe some of the newer crop of action cameras with HDR and optical stabilisation?
My experience with the original Fly 12 / 6 is it’s quite difficult to get a clear plate at night. At least with 2 cameras and angles you get a couple of chances.
In a well lit urban area with slower moving traffic, it’s pretty good. In a dark country lane with a 60mph limit, generally no chance – unless they slow down behind you before passing, then the rear often captures it.
The flashing light will help, varys the exposure for more chance. The helmet mount will hinder, as motion will cause blurring, so I’d consider mounting on the bike.
I even had a friendly toot
I even had a friendly toot from a HGV yesterday when I sat in primary for 20 seconds to block him passing on double white lines with oncoming traffic! I was turning left and going quite quick downhill, so I pointed at the junction ahead, made a left signal and thumbs up and he didn’t tailgate me. Gave a little toot as I turned off and raised my hand to thank him for waiting.
Despite what some motorists think, nobody goes out cycling to hold up traffic deliberately (well, unless it’s a critical mass event or something).
I tend to let them past ASAP
I tend to let them past ASAP on a narrow lane.
I’ll stay in the centre of the lane until they’re down to my speed before moving to the side and letting them pass. Tends to work ok at stopping the high speed squeeze by.
Keeping central in the lane if a safe pass is not possible, i.e. I’m going downhill at speed, it’s on a bend, I’m about to turn off onto a side road, it’s a HGV/Bus/Coach/Combine/Tractor and the road is not wide enough so need to find a field gate or wide verge etc. But this is usually for less than a minute.
I would view this as an
I would view this as an opportunity to acquire two bikes!
I found as the kids got heavier, that the leverage of a wide flat bar made it much easier to keep the bike upright when stationary.
So, I’d look at getting a nice new endurance/gravel type road bike for the commute, plus a second hand 26″ wheel MTB for kid and shopping lugging duties. The smaller MTB wheels keep the kids seat weight lower for a better centre of gravity, plus you can fit wider tyres for a more comfortable ride.
You will probably spend a lot more time on the commuter bike, so I’d try and avoid compromising it’s performance by trying to get it to do everything.
February 27, 2021 at 11:53 am in reply to: What’s the weirdest thing you’ve had to swerve to avoid? #976715HoarseMann
I hope they called out
I hope they called out ‘droppin’ in’
February 25, 2021 at 5:02 pm in reply to: What’s the weirdest thing you’ve had to swerve to avoid? #976667HoarseMann
You’re right! Thankfully
You’re right!
Thankfully managed to avoid a coming together and a reminder that it’s safer to ride in the primary position.February 25, 2021 at 4:17 pm in reply to: What’s the weirdest thing you’ve had to swerve to avoid? #976655HoarseMann
pic
pic
Yep, the SQR would be ok as
Yep, the SQR would be ok as it’s more of a mount than a rack and the weight is kept quite close to the post – it’s those long seatpost racks like a huge lever that would not be a good idea.
I’d say forget a standard or
I’d say forget a standard or seat post clamping rack. Both could risk damage to the post or frame. If they’re mudguard only mounts, they won’t be designed to bear a load. There are better options for a bike like that…
£ – a backpack
££ – a seatpack
£££ – a tailfinFebruary 14, 2021 at 11:26 am in reply to: Car crashes into building – please post your Local news stories #963939HoarseMann
David9694 wrote:Legally?I don’t anticipate they’ll be any criminal conviction for this ‘accident’, so is it illegal?!
