Forum Replies Created
Viewing 15 replies - 151 through 165 (of 559 total)
  • in reply to: Drivers and their problems #999771
    Quote:
    Dorothy Denny, 65, drank vodka for six hours on 4 October last year before deciding to drive to the garage to get more alcohol at about midnight.
    When they say ‘the garage’, do they mean Strensham motorway services? Bizarrely, that is probably the only place in the area you can buy alcohol at that time of night.
    in reply to: Am I in the wrong? #1013429
    Be careful there – you’ll get
    Be careful there – you’ll get a driver saying they assumed you were indicating to join the cycle path!
    There will be exceptions, but I find myself being very careful of indicating on the bike these days. Generally, getting my road position sorted early and occasionally deploying ‘wobbly cyclist mode’ seems to serve me better than prescribed signals.
    in reply to: Am I in the wrong? #1013409
    If you indicated right here,
    If you indicated right here, it’s possible the driver got confused by it and pulled out.
    I don’t indicate when moving between secondary and primary, it’s not necessary – that movement is within the envelope of road space a cyclist should be given anyway.
    in reply to: Thoughtful Driving Ad #1013347
    Can’t find the same kid seat
    Can’t find the same kid seat on the internet, but this one is similar and looks to be well engineered and safe…
    https://www.urbaniki.com/en-gb/child-bike-seats/folding-bike-child-seat/
    in reply to: Thoughtful Driving Ad #1013345
    The ‘honk’ was the only
    The ‘honk’ was the only reference that you might have to share the road with drivers. Not a single moving vehicle visible in the entire video – very reminiscent of a car advert, carefree empty roads etc…
    They had the helmet angle covered, but no high vis and riding at dusk without lights!
    Also – why such a ropey looking old bike and a lethal looking kiddie seat that you could quite easily slip off the back of! Not even anything solid for the kid to hold on to! Scream if you want to go faster?!
    https://road.cc/wp-content/uploads/roadcc/Screenshot 2023-05-15 at 16.50.11.png
    Looks ok. I’m not convinced
    Looks ok. I’m not convinced it’s actually 4k though. Looks like it’s upscaling from a 1080p sensor. I’d try running it at 1080p to see how legible numberplates are, you might find it’s about the same and would save storage on the SD card and increase battery life.
    I’d also try without the stabilisation if using it just as a safety camera. Again, you might find numberplates are just as clear with stabilsation off, it would increase battery life and crucially, any swerving or movements you made would be captured real-time, rather than with stabilisation lag, which would produce better evidence if required.
    in reply to: electric bikes go #1013031
    Yep, for most cyclists going
    Yep, for most cyclists going to an e-bike, pedalling is something they’d want to do anyway. But for those who couldn’t/wouldn’t consider pedalling a bicycle, but might choose a throttle e-bike, there’s a chance that they might start pedalling and develop better fitness/mobility. Certainly got to be better than an e-scooter.
    The downside is it encourages ‘motor scooter’ style e-bikes, where the pedals are barely functional. But again, probably better than an e-scooter.
    It’s frankly surprising that Rees Mogg has overlooked the potential Brexit benefit of removing the EU throttle restrictions from e-bikes sold in the UK! I’m pretty sure the only reason they’ve had to create the 250W LPM class and mandate a £55 MVSA inspection is to comply with the EU legislation.
    in reply to: electric bikes go #1013023
    Rendel Harris wrote:
    Actually it’s still legal to have a “walking pace” throttle as long as it propels the bicycle at no more than 6 km/h; with any bike built before 2015 a throttle that can go up to the limit of 25 km/h is permitted.
    and if you’re prepared to pay £55 for a DoT inspection, you can have a throttle that will propel you all the way up to 16 mph – whilst still being classed as a bicycle.
    in reply to: electric bikes go #1013013
    You can get away with
    You can get away with electric assist up to 16 mph in the UK:
    https://www.gov.uk/government/publications/motorcycle-single-vehicle-approval-inspection-manual
    https://road.cc/wp-content/uploads/roadcc/Screenshot 2023-05-04 at 09.50.44.png
    in reply to: 1 x chainring 11-36 #1012853
    Sriracha wrote:
    Sriracha wrote:
    HoarseMann wrote:
    I can’t vouch for the accuracy of this site… seems to indicate…
    It’s not some voodoo shit, surely? It’s front teeth divided by rear teeth times rolling diameter. Where’s the latitude for inaccuracy?
    I couldn’t be arsed to do the math just before before bed?!
    in reply to: 1 x chainring 11-36 #1012847
    I’d look at putting some
    I’d look at putting some numbers into a gear calculator – I can’t vouch for the accuracy of this site: https://www.bikecalc.com/gear_inches but it seems to indicate that the lowest gear on the setups you quote is the same at 37.10 inches. So the only downside to 1x would be bigger jumps between ratios and spinning out slightly sooner downhill.
    https://road.cc/wp-content/uploads/roadcc/Screenshot 2023-04-23 at 23.27.23.png
    in reply to: Attitudes to road casualties #1012021
    Yep, it seems the potholes
    Yep, it seems the potholes are completely unrelated to the collision.
    This is an old Roman road, it’s very straight and whilst the speed limit is 60mph, speeding is common. It also undulates and there are many blind crests (although I don’t think that was an issue here).
    I can understand the coroner not wanting to emphasise the misjudgement of the deceased to overtake, but things like a reduced speed limit, double white lines or improved enforcement would surely have greater effect.
    in reply to: Attitudes to road casualties #1012015
    A sad case this one. Two
    A sad case this one. Two killed in a head on collision during an overtake. Yet the coroner highlights potholes in the report, even though there’s no mention of potholes having anything to do with the collision.
    https://www.bbc.co.uk/news/articles/c3g5x2gqy8po
    in reply to: Drivers and their problems #999141
    “Time and again you expect us
    “Time and again you expect us to sit here and accept that our freedoms, our history, and our heritage are all to be sacrificed on the altar of woke extremism.”
    Ah yes, ancient Britain, where everyone lived on a satellite housing estate a good 10 miles from the nearest facilities and preferably further from their place of work.
    Free to spend a good portion of their day battling the traffic, cocooned in perfect isolation, the occasional wave at a passing motorist their only interaction with the local community.
    in reply to: Drivers and their problems #999123
    Pretty sure you don’t need an
    Pretty sure you don’t need an MOT if you are just driving to and from a test centre. Maybe they are making use of this exemption
