Forum Replies Created
wycombewheeler wrote:two vehicles appraoching a mini roundabout, if the one coming from the left he can get there first and be “established” on the roundabout before the one from the right enters the roundabout 0.2s later.But this is mitigated by the potential for a vehicle to emerge in front. So there is a limit to how fast you can approach a roundabout, because you need to factor in vehicles coming from 2 directions.
It’s certainly a game of chicken if you only consider that you have to give way to your right. If you can see that direction is clear, then the faster you approach the roundabout, the sooner you get ‘priority’ over vehicles emerging from the left.
There are some roundabouts
There are some roundabouts where you can enter without giving way. It’s not common, but some have give way markings for circulating traffic, such as this one… https://goo.gl/maps/m7hfcXFgoVGVYCZW6
On a mini-roundabout, the thick/short dashed lines and the double-dashed give way markings hold the same mandatory ‘MUST’ requirement to give way to traffic circulating on the roundabout. They mean exactly the same thing, but the ‘give way’ lines are sometimes chosen to make the junction more prominent; it lets them throw up a give way sign as well as a blue circle of arrows.
The white circle marking also has this mandatory requirement, so is effectively a give way too!
“no vehicle is to proceed past the [white circle] marking in a manner, or at a time, likely to endanger any person, or to cause the driver of another vehicle to change its speed or course in order to avoid an accident”
wycombewheeler wrote:Effectively allowing an interpretation that leads to a game of chicken.It’s not really a game of chicken, it’s ensuring that you give priority to the right to vehicles on the roundabout AND don’t crash into any vehicles already ahead of you on the roundabout.
That effectively means you need to be prepared to deal with traffic coming from the right AND emerging from the left before you reach the roundabout. Which is what any competent driver would do.
The trouble is, the highway code doesn’t emphasise this enough, ‘look forward before moving off’ sounds like you only need to look forward if you had stopped!
yep, it’s possible the ‘tenon
yep, it’s possible the ‘tenon’ bit is too fat. Are the surfaces of the toothed adjustment ring painted? A bit too much paint there would account for the tolerance issue. It’s also worth having a look at those mating surfaces for any debris that could be trapped in there. I’d also try adjusting the stem to a different angle, to change those mating surfaces a bit and see if that has any effect on the clamp bolt gap.
Having a look at the drawings
Having a look at the drawings for this stem, it looks like it is split at the front as well as the rear. So with that in mind, perhaps the order with which the front and rear bolts are tightened matters?
I’d try slackening off the clamp bolts, then torque the raise adjustment bolt first followed by the clamp bolts.
October 2, 2022 at 7:02 pm in reply to: Katie Kookaburra incredibly close pass from bus in Manchester #997827HoarseMann
Totally agree, but it’s a
Totally agree, but it’s a bike lane that puts cyclists in greater danger than if it wasn’t there. I would not use it and take the lane instead.
October 2, 2022 at 5:58 pm in reply to: Katie Kookaburra incredibly close pass from bus in Manchester #997823HoarseMann
Yep, it’s past the point of
Yep, it’s past the point of being able to report. That bus doesn’t normally do the 156 service, but it did a couple of trips on the 12th of September. Although the bus dot matrix sign looks to say 56, perhaps strobing effect of the camera has dropped the 1 off.
Anyway, point is, she *could* have reported it, as the white number in the windscreen (10844) uniquely identifies the bus.
October 2, 2022 at 12:48 pm in reply to: Katie Kookaburra incredibly close pass from bus in Manchester #997815HoarseMann
AlsoSomniloquism wrote:She didn’t report it as she didn’t get the registration plateShe got the bus number though (10844), which thanks to that great website bustimes.org, you can then deduce the registration! Plus, get a photo of it…
https://www.flickr.com/photos/aswans1234567/52029435165/
I think this incident happened quite a while ago though. According to bustimes, the 56 service was withdrawn in July and replaced with the 156 service.
October 2, 2022 at 12:33 pm in reply to: Katie Kookaburra incredibly close pass from bus in Manchester #997813HoarseMann
This is a terrible bike lane.
This is a terrible bike lane. Not only is it not wide enough, it disappears without warning.
Not that this excuses the bus driver. Unless it was their first run on that route, they surely must have known the bike lane would end as the road narrows.
Yes, it’s considered a
Yes, it’s considered a junction.
I did think the scenario where a very slow cyclist was using the outside lane of the roundabout to turn right is quite similar to a pedestrian crossing an entry/exit. Cars are supposed to slow/stop on the roundabout and allow a cyclist to cross their path.
The highway code has always said to ‘watch out’ for pedestrians crossing the entry/exits. Just like it says drivers joining the roundabout should look forwards and ‘watch out’ for vehicles already ahead of them on the roundabout. But it makes it sound like you’re ‘watching out’ for a rule breaker!
ooh, and page 87! Which
ooh, and page 87! Which describes the carriageway of a roundabout as circulatory and exiting as ‘leaving the junction’…
I refer you to page 119 of
I refer you to page 119 of the ‘Manual for Streets‘*; a junction is still a junction even if there are no road markings…
*(it’s redacted, but it explicitly states that there is no statutory requirement to mark a road junction)
100% you were within your
100% you were within your rights to stop for the pedestrian. A roundabout is considered to be its own circular carriageway, distinct from the adjoining roads and each entry/exit is a junction.
However, this has been poorly communicated in the recent highway code updates and people have different opinions on this. Whenever something can be debated, it usually means the rules are not clear enough.
So, with this in mind, I would say next time make the pedestrian wait. You are a vulnerable road user too, plus you do not have the mass nor the width to offer any protection to a pedestrian should a motorist fail to stop.
I’m just going off the wheels
I’m just going off the wheels I’ve had in the past, most rims have had a lower rating than the tyres. But I suspect there’s a healthly safety margin in there.
edit: here’s a good spec sheet from DT Swiss, definately rims less than tyres I’d say from that. 28mm contis reckon 120psi max, the swiss rims are 113 for hooked and 73 for hookless with a tube.
https://www.dtswiss.com/pmt/00/00/00/00/00/00/00/10/00/00/00/86/6/MAN_WXD10000000866S_WEB_ZZ_001.pdf
lol, clearly needed more
lol, clearly needed more sleep (or should have waited until the first coffee had taken effect)!
But the key is the max pressure the rim can take will vary depending on tyre width.
