H2 and Rule 170 … who is in the right here
  • This topic has 23 replies, 17 voices, and was last updated 4 years ago by Yorkshie Whippet.
  • #32260
    Oldfatgit
    https://youtu.be/tPXXPkUNuDw
    Tonight, while commuting home I’ve stopped to let a pedestrian cross the road, and had a bit of an angry blast on the horn from the guy behind me.
    Traffic light controlled roundabout; I’m taking second exit.
    I’ve waited  until my lights have changed to green and rolled on … as I’m rolling the next set of lights have turned green; this set is immediatley before my exit.
    I’m rolling through the green, and there is a pedestrian waiting to cross my exit.
    I roll to a stop to let the pedestrian cross.
    Van behind me is not very impressed and gives a long blast on the horn.
    I’m not impressed or intimidated by the van, and shout back “What?” followed by “Read the Highway Code”.
    There is no further communication between myself and the van driver, other than the driver raising both is hands in the exasperation gesture, and shaking his magic beans at me.
    Driver then turns right at next roundabout (approx 67m) and goes and sits at a fuel pump.
    My interpretation of H2 and Rule 170 is that I was correct to stop … I was turning and the pedestrian was waiting to cross, ergo, I was correct to give way.
    However … all the illustrations relate to a side road off, and not an exit from a roundabout .. which makes me wonder if I was correct or not.
    The junction has no traffic control for pedestrians, however there is drop down kerbage and tactile paving, and is also a shared pathway.
    Now .. the question is … was I right to stop?
Viewing 15 replies - 1 through 15 (of 23 total)
  • #997427
    Yorkshie Whippet
    You clearly have not read the
    You clearly have not read the right Highway Code.
    Rule 1 The Highway Code does not apply to me.
    Rule 2. The Highway Code applies to everyone else.
    Rule 3. Anyone who follows the Highway Code is an idiot and needs to learn to drive proper like.
    Rule 4. If in doubt refer to Rule 1.
    My work here is done ????
    #997425
    Bungle_52
    Thanks for the link.
    It has been suggested that police are more likely to take action for careless driving at roundabouts so I looked through them. One was reported but had no feedback, one in Birmingham had no further action and Thames valley police sent a letter. Those were the only three reported.
    Any plans for a similar analysis for other types of near misses and different forces?
    #997423
    Simon_MacMichael
    Interesting discussion and we
    Interesting discussion and we have the definitive answer here – it is a junction. But as mentioned above in the comments, whatever the Highway Code says, you can’t assume drivers remember what they had to study to pass their driving test however many years ago, nor – due to the woeful lack of communication by the government – that they will be aware of the changes.
    And then you have the issue that drivers entering a roundabout are focused on their exit, meaning that many simply will not be looking out for cyclists, or if they do, will often put their foot down to make the exit ahead of the rider … see here for some examples
    https://road.cc/show/tags/nmotd-roundabout/151017
    The roundabout I encounter most often while riding in London is Shepherds Bush, and even though it is traffic light controlled, there is no way am I cycling across that – eastbound, heading towards Holland Park from Shepherds Bush Green, I’d be cutting across the main motor vehicle flow, which heads onto the A3320, effectively an urban motorway.
    So what I (and many other cyclists) do is take the bus station slip road, ride across it to the ramp up to the pedestrian crossing on the A3320, or take the underpass, then join Holland Park Avenue the other side.
    Similar going westbound, where I need to be on right-hand-side of carriageway to get into the cycle lane.
    #997421
    PRSboy
    What you did was courteous.
    What you did was courteous.  An attentive driver following should be looking in the direction of travel.  I don’t see an issue, aside from the fact that ‘allowing’ a pedestrian to cross the road does expose them to danger, and I will generally only do it if I can effectively block the road to prevent someone from over/undertaking.
    #997419
    Yes, it’s considered a
    Yes, it’s considered a junction.
    I did think the scenario where a very slow cyclist was using the outside lane of the roundabout to turn right is quite similar to a pedestrian crossing an entry/exit. Cars are supposed to slow/stop on the roundabout and allow a cyclist to cross their path.
    The highway code has always said to ‘watch out’ for pedestrians crossing the entry/exits. Just like it says drivers joining the roundabout should look forwards and ‘watch out’ for vehicles already ahead of them on the roundabout. But it makes it sound like you’re ‘watching out’ for a rule breaker!
    #997417
    You assume that there is good
    You assume that there is good visibility, the pedestrian could be hovering behind a car, halfway across the road – though to be fair this would always have been a stop scenario. More typically, a driver will be intent on traffic gaps and in chancing a gap will not really be in control. It is more recognising that a suitable gap has to include considering pedestrian (and cycle) activity and the reality is that is beyond many drivers and their patience.
    But mainly,as you say, it is about adjusting thinking from cars having absolute right of passage where all others are expected to clear their path. It definitely does change driving style to actively seek out pedestrians to prioritise.
    #997415
    KDee
    So it’s a junction then. I
    So it’s a junction then. I suppose the old phrase “approach with caution and prepare to stop” is the best policy anyway.
    #997413
    ooh, and page 87! Which
    ooh, and page 87! Which describes the carriageway of a roundabout as circulatory and exiting as ‘leaving the junction’…
    https://road.cc/wp-content/uploads/roadcc/Screenshot 2022-09-15 at 22.51.26.png
    #997411
    I refer you to page 119 of
    I refer you to page 119 of the ‘Manual for Streets‘*; a junction is still a junction even if there are no road markings…
    *(it’s redacted, but it explicitly states that there is no statutory requirement to mark a road junction)
    https://road.cc/wp-content/uploads/roadcc/Screenshot 2022-09-15 at 22.40.24.png
    #997409
    Probably going to need
    Probably going to need Hoarseman to comment but a lot of these technicalities are buried in the regs or highway markings detailed regs.
    #997407
    KDee
    Doesn’t this have to do with
    Doesn’t this have to do with the road markings? A side road will have the dashed white lines for both lanes. A roundabout will only have the dashed white lines indicating traffic joining the roundabout must give way. The lack of dashed white lines at the exit of a roundabout suggests a continuation of the carriageway.
    #997405
    The whole point of
    The whole point of roundabouts is a) high capacity for motor vehicles with b) good safety for that capacity.  So I agree.  Too much traffic – even just at peaks – the roundabout is not suitable for any vulnerable road users and a grade-separated alternative route for them should be provided.  This situation seems common in the UK.
    Roundabouts can work with vulnerable users at the same level if they’re designed right but there are then fairly low limits on their capacity.
    #997403
    OldRidgeback
    I stopped to let a pedestrian
    I stopped to let a pedestrian cross the side road I was about to turn into just last week and got an angry beep from the driver behind me. I was on my motorbike, a large sportsbike, and while still a vulnerable road user, rather more visible than if I’d been on my Cannondale. You did the right thing, but as others have pointed out, the changes to the HC haven’t been well communicated and many drivers didn’t have enough knowledge of the HC even before these changes came in. As a vulnerable road user, you should also make sure you’re safe. Not every driver drives as they should, as we all know.
    #997401
    Sriracha
    I’d agree. Roundabouts “work”
    I’d agree. Roundabouts “work” for the same reasons motorways work, because they ignore all other road users besides motor vehicles, for which they work very well (mostly). But it all falls apart once you have traffic stopping unexpectedly. There was a good piece in the Guardian…
    https://www.theguardian.com/cities/2015/oct/19/traffic-lights-roundabouts-way-out
    [I]“Roundabouts are brilliant at moving car traffic, but not a safe space for people who cycle or are crossing on foot,” says Grant, who, mindful of the emotional nature of this issue, is careful to talk of “people who cycle” and “people who drive” rather than “cyclists” and “motorists”.[/i]
    #997399
    wycombewheeler
    Simon E wrote:
    Rroundabouts, rule 185: “In all cases watch out for and give plenty of room to pedestrians who may be crossing the approach and exit roads”
    The impatient bell-end behind you can shove his aggressive use of the horn up his arse.
    https://www.highwaycodeuk.co.uk/roundabouts.html
     rule 187, and in the case the pedestrian was not crossing but waiting to cross, this is different guidance to the rule 170
    “watch out for and give plenty of room to
    pedestrians who may be crossing the approach and exit roads” (187)
    vs
    “give way to pedestrians crossing or waiting to cross a road into which or from which you are turning” (170)
    If the rules for roundabouts were intended to be the same (as some are arguing) then the text would be the same. It is not, because they do not want drivers stopping on roundabouts where following drivers are splitting their attention between the vehicle they are following, any traffic lights, their exit, and most importantly traffic coming round the roundabout from their right
    However your last sentance is still correct, in all cases aggresive use of the horn due to impatience is wrong
