- This topic has 25 replies, 14 voices, and was last updated 8 years, 5 months ago by
Jetmans Dad.
May 30, 2018 at 6:34 pm #28577
viv
I’ve wasted 12 hours trying to get my Garmin 820 working. Being on hold, trawling through useless support pages to access help numbers and emails etc etc
I also wasted 20 quid buying OS High Sierra to make certain it was compatible.
Is there a non-Garmin bike GPS that does not require a smartphone?
Jetmans Dad
viv wrote:Jetman – great that yours works, but mine doesn’t. Rather than keep spending time troubleshooting with an atrocious support network I’d rather cut my losses, send it back, and buy an alternative that doesn’t require my time and energy to discover work arounds to access the functions it promises on the box. Rant over.Apologies … didn’t make my point clear.
There are clearly issues with the newer Garmin devices, and those with more complex/mapping features, whereas I have always found my older Edge 200 and Edge 500 to be basically bulletproof. I have only lost data on one occasion in 6 years, and have never had issues with synchronising rides to GC or Strava or routes to the device from GC. Neither of them have maps.
For me the combination of Express and Connect has always just worked … friends with newer devices or devices with maps have always had issues that are difficult to resolve.
That said, my two buddies with Bryton devices spend most of their time cursing their computers too. The others I cannot comment on.
viv wrote:A few people are suggesting Garmins or devices that need a smartphone. I don’t think the topic title is unclear – not Garmin, not for use with a smartphone. Simple.Have to say, the Mio devices look promising.
Also – I’m not disputing that others find Garmins good or enjoy using Wahoos with their phones – but this is not (and isn’t currently) going to work for me. Jetman – great that yours works, but mine doesn’t. Rather than keep spending time troubleshooting with an atrocious support network I’d rather cut my losses, send it back, and buy an alternative that doesn’t require my time and energy to discover work arounds to access the functions it promises on the box. Rant over.
Mio, Lezyne and Bryton on the list….
Cheers all!
Good luck with the Bryton software (if you buy one)…. awful, just awful. And if you think Garmin support is dire just wait until you havve issues with a Bryton device.
HoarseMann wrote:The Garmin PC software is dire. Sounds like this is the problem rather than the GPS itself.The connect express application seems to work reliably for uploading rides to strava… but downloading routes using their software is hopeless. Don’t even try to use the mapping tools!
The only way I’ve found that works is planning routes with ridewithgps.com website, exporting as a .tcx and then saving the .tcx in the NewFiles folder on the Garmin SD card.
Trying to get the Garmin to plot a route itself usually ends up a long way round disaster of unsurfaced paths.
i’ve used garmin eTrexes (eTrices?) for years. I started using the cheapest eTrex as a get-out-of-jail-free device for long-distance walking with map & compass. I’m on my 4th now, having bought updated versions as they come out. The software works, but not necessarily in the way you’d expect… and it takes a lot of suffering and frustration to understand its warped little mind.
One of the things that used to frustrate me was plotting a route with other, easier software, squirting it into the Garmin, then finding that the Garmin wanted to go its own way. When I eventually gave in and started to use Garmin Express I found that you can use it to plot the route with the map that you have in the device, so when you are actually out there, it goes where you told it to.
OR_biker
I have a Magellan (Mio) 505
I have a Magellan (Mio) 505 that I bought used last year from a riding buddy. Haven’t been super impressed with the navigation (big part I think is that maps aren’t updated very frequently, so unable to keep up with all the changes in the city). But for all the normal ride/data tracking, it works great. Doesn’t seem to work with the newer Garmin magnet-less speed sensor (the one that wraps around your wheel hub), but I really only got that to use with my trainer anyways, and I use an app on my phone to track my trainer rides so for me it’s not a problem. I haven’t had any issues with GPS signal even in bad weather, unlike some guys I ride with that use Garmins. I also just discovered (even though it’s been available for like 2 years now) that I can get two months of Strava Premium for free with the 505 so I can use Live Segments. Although I think I’ll go for a computer with side buttons next time (just my personal preference), the touch screen isn’t bad, and I can usually get by even with thick gloves during winter. Another thing to note, it doesn’t have a lap button/function, so if you like to be able break up sections of a ride or track intervals that way you may want to look elsewhere. I typically just break things down once I get the ride into Strava, so no issue for me.
viv
Hi David, no – I’m not
Hi David, no – I’m not sending Strava segments. Just segments I’ve plotted in Connect on my routes.
But I’ve already wasted a few afternoons on this. I’m not here to find a solution. I’m here to find an alternative.
David Arthur @davearthur
That is a strange one! Take
That is a strange one! Take it you’re sending Stava segments to the Edge? That’s not something I’ve tried I’m afraid, so don’t really know what to suggest to help. This ‘might’ help https://support.strava.com/hc/en-us/articles/216918277-Strava-Live-Segments-on-Garmin-Devices-Premium-#edge
viv
David – Express is installed
David – Express is installed and recognises device when plugged in. This was a bit hit and hit and miss at first but now seems fine. Connect log in is fine too. My rides show in Connect. However, and this is where it doesn’t add up, Connect does not recognise my device. When I send a segment to the device it tells me there is nothing connected – despite Express showing the device at connected, sync’d up AND Connect showing me my rides after I plug it in.
Garmin told me to uninstall-reinstall etc. I’ve done that. Connect also seems glitchy. A local climb showed up as 4500 ft. It is not.
What’s your problem with the
What’s your problem with the 820? I’ve been using one for the past year, and after lots of issues early on, the latest firmware update has made it a lot more stable and usable.
Hearing good things about the Wahoo Bolt, I’ve not tried one personally but Mat Brett seemed impressed judging by his review http://road.cc/content/review/222249-wahoo-elemnt-bolt-gps-cycling-computer
viv
Cheers all!
Jetmans Dad
viv wrote:I’d like a Garmin, but seeing as the Connect platform cannot send anything to the device I doubt an 810 will be any different.I have an Edge 500, which I moved to from an Edge 200 and have never had a problem sending stuff from Connect to the device … in fact I sent a route to the 500 from GC this very morning.
alansmurphy
He didn’t say he wanted the
He didn’t say he wanted the best, he said he wanted one that didn’t need a smartphone – bit of a fail suggesting the Wahoo!
CXR94Di2
Wahoo Elemnt, Ive got one,
Wahoo Elemnt, Ive got one, all my cycling buddies have them now. World wide maps, easy to configure(via phone), regular updates/firmware.
A dream to use compared to Garmin.
Hey if you dont want the best, buy a Garmin
DoctorFish wrote:nniff wrote:I know it’s a Garmin, but a Garmin Edge Touring or Touring plus doesn’t need a phone. All depends if you want loads of data or a record of where you’ve been, route guidnace, maps and basic data, or the full monty of power and all that. Mine’s done me well for years, but has the occasional melt down, which it gets over in due courseNo, not this, I woun’t wish a Touring plus on anyone. Best cycling based decision I ever made was to trade the piece of crashing worthless trash in for a Wahoo. I would suggest a Wahoo but setting it up with a smartphone is a doddle, but I have no experience of trying to set it up without a smartphone.
I think a smartphone is essential for setting up a Wahoo. I’d recommend getting a Wahoo and find a friend with a smartphone to set it up and download maps etc.
DoctorFish
