Forum Replies Created
Viewing 15 replies - 451 through 465 (of 559 total)
  • in reply to: Life Expectancy Of Shimano Sintered Pads? #974115
    Same compound. The middle
    Same compound. The middle number relates to the pad compound type.
    in reply to: Life Expectancy Of Shimano Sintered Pads? #974109
    You’re right in thinking
    You’re right in thinking sintered last longer than resin – and that could well be a typical wear rate for your use case.
    The L04C start at 2mm and are good down to 0.5mm, so you could maybe get another 600 miles out of them.
    If your descents are not that long, you could probably get away with the non-finned pads, which are cheaper. Particularly over winter when it’s cold anyway.
    I’m not aware of a harder compound pad, but anything harder is likely to make more noise, cause greater wear to the rotors and result in less powerful braking.
    https://bike.shimano.com/en-EU/product/component/shimano105-r7000/BR-R7070-R.html
    in reply to: Tyres for country roads and icy starts… #974027
    +1 for studded tyres.
    I commuted on Schwalbe Winters for 4 years. I put them on first frost and they stayed on until the spring. I think if you are commuting, you don’t want to bother with the faff of switching wheelsets. Plus, if you’re at work and unexpected bad weather rolls in, it’s no good having the studded tyres back home.
    They are obviously slower and heavier than summer tyres, but for me it was well worth the 2 mph-ish drop in average speed for the confidence they give you – especially when riding in the dark. I’m based near Milton Keynes and similarly used country roads and a cycle path, but with some quite busy sections.
    They also work well when there’s no ice, as the deep tread cuts right through mud and leaf mulch. You get used to the sound they make in the dry – a bit like riding on rice crispies. They go quiet when you roll onto a patch of ice.
    I used the ‘winters’ rather than the ‘marathon winter’ as it’s available in a 30mm which meant I could still get mudguards on, plus has half the number of studs, so a bit lighter and rolls better in the dry. Just make sure to use gloves when fitting so you don’t rip your hands to shreds!
    in reply to: car smashes into the back of horse #973671
    How on earth can no offence
    How on earth can no offence have been committed?!
    I mean really, if the driver was not anticipating meeting a horse around a bend on that road, then there’s no hope for anywhere else…
    https://road.cc/wp-content/uploads/roadcc/Screenshot 2020-11-28 at 10.51.28.png
    in reply to: Width of a 27 1-1/4 inch tyre #973493
    Well I popped out to the
    Well I popped out to the garage and grabbed the calipers – an old 27-1-1/4 came up at 29.5mm and some newer Conti GP4000 28C’s came up at 30mm.
    I would say though, that the old bike is more comfortable than the new one – even with the 28C’s run down at 50-60psi. But obv. a lot slower!
    Like you say, there are more factors than just tyre size – chromed steel rims vs alloy. Steel fork with a huge trail and loads of flex. Then there’s just the sheer weight of the old bike – that seems to deaden road buzz.
    I’d go with the frame that can take 32C’s, then you’ve got the flexibility to up a tyre size or fit guards. I’ve had 32C G-One’s on the newer bike and they’re probably closer to the ride quality of the old bike.
    https://road.cc/wp-content/uploads/roadcc/Screenshot 2020-11-25 at 16.15.07.png
    in reply to: Fazua drive unit #973279
    Apparently you need to use
    Apparently you need to use the ‘correct finger placement’ as per…
    It seems a bit of a faff to have to remove the drive pack from the frame and then the battery from that pack in order to charge it. I guess it means they can save a bit of weight by utilising the same connector for drive and charge.
    Also looks a bit too easy to fumble and drop, especially after a long winter ride when hands are cold. I’d be putting something like a foam pad under the bike before attempting the extraction procedure! Especially as I think the only way to make it easier is to make the battery slippery by giving it a polish (just normal pledge/mr sheen if suitable for plastic should be good enough, silicon polish better if you’ve got some).
    Glad to hear it’s made riding more enjoyable. I am really tempted by an ebike.
    in reply to: High Performance Cars #973107
    OnYerBike wrote:
    I would add c) The cause of that collision was not that the car driver failed to accelerate fast enough, the problem was that the lorry driver failed to look properly!
    for sure, but with a lot of left hand drive HGVs on our roads, it happens more than it ought to.
    I’m careful not to put myself in that position, only passing a HGV when I can get past in one swift overtake, but it’s not always possible. I always watch for drift when passing too.
    in reply to: High Performance Cars #973097
    rjfrussell wrote:
    I’m genuinely trying to work out what sort of collision could be avoided by the 15mph boost?
    This is the sort of thing that’s quite common where a short burst of acceleration could get you out of trouble…
    https://youtu.be/c2eNallSXUc?t=178
    in reply to: Truing Wheels: how important with disk brakes? #972931
    I’ve only noticed my rear
    I only noticed my rear wheel had got a slight wobble when fitting mudguards recently. I’m ignoring it unless it starts rubbing on anything. Another low-maintenance win for disc brakes!
    in reply to: Mist and Fog? #972845
    side lights and front fogs…
    side lights and front fogs… but only because you at least needed the side lights on for them to work! (I changed my ways a long time ago blush)
    in reply to: Mist and Fog? #972831
    Sriracha wrote:
    Sriracha wrote:
    So they are not really a problem if they are used sans-fog.
    Well I once got pulled by the police for driving around with front fogs on at dusk on a clear day, I was an unwise teenager using them for their proper intended purpose; to display to all that you are not driving the poverty spec. model yes – oops.
    The sun was very low and behind me, so I explained to the officer, would make me more visible. Offered advice and sent on my way.
    in reply to: Thoughts on the Whyte Suffolk #818583
    Well I’m chuffed to hear that
    Well I’m chuffed to hear that! That’s a fairly quick turn around in the current circumstances too. Props to Whyte for excellent customer care and standing by their product.
    After your comment caused me to inspect the undercarriage of the bike a bit more closely than I’d ever done before, I noticed that the gear cables were being pulled a bit severely to one side, almost rubbing against the braze-ons. I also noted there was another hole that the cable guide could be bolted to, so I shifted the cable guide over towards the chainrings. What a difference! The gear shifts are now much lighter and snappier – can’t believe I’d ridden 10k miles with it like that!
    https://road.cc/wp-content/uploads/roadcc/Screenshot 2020-11-09 at 14.31.39.png
    in reply to: nigel farage has gone mad. #972883
    I do wonder what portion of
    I do wonder what portion of the Kent lorry parks’ costs are covered by Nigel’s VED contribution?
    Maybe he’s setting the scene to blame the predicted post-brexit traffic chaos at the ports, on a bike lane somewhere in Dover.
    in reply to: Mist and Fog? #972819
    ktache wrote:
    I had put it down to incompetence, utter disregard to theirs or others safety
    It’s definately that too; the ones moaning about being dazzled by fog lights ’cause it’s not foggy enough are also the ones tanking along with no lights on ’cause it’s not *that* foggy – until suddenly it is that foggy and they’re going too fast.
    in reply to: Mist and Fog? #972815
    0-0 wrote:
    0-0 wrote:
    I think it depends if the driver is smart enough to switch their lights on when driving in fog. Some I past today, whilst riding in the fog, weren’t.
    Given how much moaning there was on our works forum about people having fog lights on when it wasn’t foggy enough, I think it’s a badge of honour for some drivers to not put their lights on!
    If the fog’s that bad, I would only rely on very bright lights being an effective safety measure (> 75 lumens).
    For the ankle bands, I’d just stick with reflective in the dark and fluro when it’s light.
