Forum Replies Created
Agree with all you’ve said
Agree with all you’ve said Ian.
I would also say that I do understand Ashley’s position, he is an educator and therefore is naturally trying to fix problems on the road through education. That is not a bad thing and a lot of his advice is spot on (cycling stuff excepted).
However, he places too much emphasis on this and has the opinion that it is not the vehicle that is dangerous, but the driver. He constantly draws false equivalences between the actions of cyclists, pedestrians and drivers, with the unrealistic aim that if everyone acts within the law and with respect for others, then safety is guaranteed.
Anyone who has spent any length of time cycling on our roads knows that with the absence of crumple zones and airbags, cyclists need legislation and infrastructure to protect themselves. Just riding legally and respectfully is not enough.
I only see positivity:
– Sympathy for your injuries and predicament
– Empathy for the effect a scary close pass can have
– Solidarity in taking a stand against the idiots, whether they be on a bicycle or in a motorised vehicleThere was some constructive feedback that painted lines are probably not worth pursuing, as they are rarely adhered to by both pedestrians and cyclists. A tip to keep to one side of a shared path and walk in a predictable manner. To keep looking back for approaching bikes and maintain good situational awareness.
Some reassuring that you should not feel bullied off the path, as whilst it was a frightening incident for you, the statistics show that you are far more likely to be injured by a motorised vehicle on the pavement than a bicyclist. That a cyclist is at as much risk of injury as you in a collision, so they’re likely to do all they can to avoid one.
Finally, a tip to do what a lot of cyclists do, use a camera and record these incidents. You would have far more sway with the council if you could build up some evidence to support your complaint. You don’t need to come up with the solution, just document and evidence the problem, then make it the councils job to fix it.
July 6, 2022 at 4:42 pm in reply to: 2 Pin freehub removal tool for freehub on mavic cx222 rim from specialised? #994527HoarseMann
No probs. You might need both
No probs. You might need both! Some freehubs are removed from the opposite side as per this example: https://youtu.be/dfZ8BZLrfT4?t=406
There’s a lot of variation and can be a right pain to work out which one you have. I needed a 14mm key for one of my wheels!
July 6, 2022 at 2:32 pm in reply to: 2 Pin freehub removal tool for freehub on mavic cx222 rim from specialised? #994523HoarseMann
hmm, not sure about this
hmm, not sure about this particular wheel, but usually the freehub body can be fully removed with a large allen key.
That 2-slot lock ring is for disassembling the freehub body, which is inadviseable, as some have lots of tiny ball bearings inside and it’s a whole load easier just to buy a new freehub body. It also usually has a reverse thread like a left pedal (clockwise to slacken).
good video on it here: https://youtu.be/W3O_1P8EMiE?t=34
here’s the tool (check dimensions) https://www.amazon.co.uk/CYBTM-Disassembly-Installation-Flywheel-Cassette/dp/B08S386GVX/
I’d also make sure the belt
I’d also make sure the belt is not too tight. I can imagine there’s not much margin in getting the tension just right. An over tensioned belt won’t skip, but will likely place undesirable loads on the BB.
Probably not this, but worth
Probably not this, but worth checking the front and rear mech cables haven’t got twisted around each other inside the frame. Unbelievably a collegue had this on a brand new high end bike.
Another thing to check is that the cable guide under the bottom bracket is bolted in the right place. On my bike there were two mounting holes and as it was supplied new from the manufacturer, they’d bolted it in the wrong place! This meant the cable line was slightly out and gear shifts were sluggish to say the least.
July 4, 2022 at 4:06 pm in reply to: Removing rear wheel (road/stirrup brakes and full chaincase) #994421HoarseMann
Those bikes were built to
Those bikes were built to last forever, nice save!
I did a similar thing with an old Triumph Palm Beach that had been tossed in a skip. I refurbished it and used it for several years for knocking about town on. Only really stopped using it because the brakes were so bad and getting tyres and rims for 27 1/4 wheels is not easy!
July 4, 2022 at 3:02 pm in reply to: Removing rear wheel (road/stirrup brakes and full chaincase) #994403HoarseMann
If you’re just patching a
If you’re just patching a flat, then defo try and do it without removing the wheel. Working on the non-chain side for better access. Once the tube is out, you do get quite good access to it by sliding it down towards the hub.
It’s good to practise this at home in case it happens to you when you’re out on a long ride. Far quicker and less risky than getting the wheel out!
Is it a woods valve? These are a pain as you have to take the valve core out to get the stem through the hole in the rim. Plus the rubber sleeve type tend to leak when they start to perish. So if you struggle to find the hole in the tube, it could be the valve that’s gone.
June 22, 2022 at 9:17 am in reply to: Driving School advises students they can close pass cyclists! #993201HoarseMann
Nice one! That’s a lot better
Nice one! That’s a lot better.
I feel credit should be given to one of the photos on that webpage too, which shows a car giving appropriate room when passing a bike in a “murder strip” cycle lane.
June 11, 2022 at 10:29 pm in reply to: Nothing like a critical injury RTC to bring out the FB trolls. #993239HoarseMann
srchar wrote:Mandatory intelligence tests for all Facebook users!!They used to do this (indirectly!). You had to have an email address affiliated with one of a list of 21 universities in the UK in order to create an account in the early days!
June 10, 2022 at 3:34 pm in reply to: Driving School advises students they can close pass cyclists! #993187HoarseMann
yep, maybe we could re-write
yep, maybe we could re-write the whole page for them! I especially cringe at the opening line “cycling on the road can be dangerous”, how about “driving on the road can be dangerous, especially in urban areas and around vulnerable road users”.
June 10, 2022 at 1:18 pm in reply to: Driving School advises students they can close pass cyclists! #993183HoarseMann
They’ve added the minimum
They’ve added the minimum advised distances, but not changed that troublesome last paragraph. Maybe they could cut-and-paste this:
You could receive points and a fine for failing to observe minimum passing distances when overtaking cyclists. Many cyclists ride with cameras to capture evidence of inconsiderate and careless driving. If you were found at fault for knocking a cyclist off their bike, injuring them or worse, you could get a lengthy driving ban or a custodial sentence.
June 7, 2022 at 3:23 pm in reply to: Nothing like a critical injury RTC to bring out the FB trolls. #993215HoarseMann
I wonder what the chances of
I wonder what the chances of Marty Spalding passing a mandatory highway code test are?
Ah, if it’s an issue with
Ah, if it’s an issue with Garmin Express, it’s worth just checking in Settings>Security&Privacy, that the app has access enabled to removable drives…
hmm, just checked on my mac
hmm, just checked on my mac and my Garmin Edge is showing up. Can you see it in finder like this:?
