Continental GP5000 TR wear
  • This topic has 7 replies, 8 voices, and was last updated 2 years ago by Jaijai.
  • #32958
    nickba
    I have just replaced my GP500TR tyres with like for like replacements. The original tyres were approaching but not yet on the limit as indicated by the wear indicators. I was surprised that the new tyres seemed to be dramatically better in terms of comfort and rolling resistance which surprised me. Have others found that these tyres performance deteriorated noticeably during their lifetime? Is this the case with all tyres or just the GP’s? Interested to hear others experience.
  • #1023859
    Jaijai
    I’ve just recently moved to
    I’ve just recently moved to PZeros due to the rapid degradation that the new STR 5000 have they just don’t seem to wear well
    #1023857
    Matthew Acton-Varian
    I would imagine that the age
    I would imagine that the age of the rubber also makes a difference – used tyres are subject to air exposure, heat cycles and UV light during its lifespan, which in turn degrades rubber over time. The compound on a used tyre will be slightly less elastic and more brittle with age, making it harder and less grippy.
    I would imagine that the last claim may only be from tests carried out on a smooth steel drum, not a textured surface that BRR, Silca and other companies do for real-world simulation testing. This will offer different results as the tyre contact patch isn’t deforming to imperfections – the biggest acid test for a tyre’s grip and rolling resistance coefficients. On a smooth surface, low grip = low rolling resistance, hence the thought behind the last claim . However rougher surfaces, even reasonably smooth tarmac, throws the curveball that the tyre’s rubber does not deform as well to the imperfections, leaving the tyre to bounce back ever so slightly. Not enough to lift the tyre off the ground, but enough to add drag to slow you down, just as running tyre pressures that are significantly higher than optimal. Another downside is that the tyre also has a lower point of breaking traction, although the grip loss is not usually significant enough until the tyre is worn well past the tread wear indicator, or the tyre is of an extreme age (over 10 years old).
    The Silca data shows only slight difference in aero drag, but no doubt all the different factors combined make a more noticeable difference overall. It’s not really a saving worth chasing unless you are racing.
    #1023855
    OnYerBike
    rookybiker wrote:
    And yet objective measurements seem to show that worn tyres have less rolling resistance (as expected, as there is less rubber to deform, being thus closer to the pneumatic ideal). Another instance of subjective perceptions being wrong.
    I’m all for objective data, but if you’re going to make such a claim please actually provide evidence.
    The main source of objective data for bicycle tyre rolling resistance that I’m aware of is the aptly named Bicycle Rolling Resistance website, who have done a long term test of the GP5000 (not the TR version that OP is using) and they clearly found lower rolling resistance with newer tyres:
    https://www.bicyclerollingresistance.com/specials/grand-prix-5000-endurance-test
    BRR had previously rested the GP4000 S II, the results of which were a bit more equivocal but still tend to indicate the new tyres have lower rolling resistance, when inflated to real world air pressure:
    https://www.bicyclerollingresistance.com/specials/new-vs-worn-gp4000s-ii
    (the test tyres were 28mm, so 60 or 80 PSI seems more realistic than 100 or 120 PSI).
    Another consideration is aerodynamics – Silca have data to suggest that new tyres are more aero (presumably because they are still rounded):
    https://silca.cc/en-gb/blogs/silca/part-5-tire-pressure-and-aerodynamics
    (although this assumes you have an aero tyre-wheel combination to begin with – it’s unclear how big the effect would be on a non-aero tyre/wheel system.)
    This forum post has a graph that purports to support the claim that worn tyres do have lower rolling resistance, but can’t find the original source to back it up:
    https://forum.slowtwitch.com/t/rolling-resistance-crr-new-vs-used-tires/755226/7
    #1023853
    New rubber always feels
    New rubber always feels better.
    Also shiny bits make you go faster.
    #1023851
    NotNigel
    I’ve always found too that
    I’ve always found too that replacement tyres always felt more comfortable and always assumed, as I haven’t settled on one particular model,  that my latest ones were better in the comfort department.  Reading your post, maybe the side walls of tyres get stiffer with age, gradually so you don’t notice until you fit new ones.
    #1023849
    rookybiker
    And yet objective
    #1023847
    matthewn5
    Yeah I’ve found that with my
    Yeah I’ve found that with my bike on Vittoria Rubino Pros. The bike feels much faster and livelier with a new set on.
