11 comments
Nice enough outcome, now that you know the seals are crap, service accordingly.
Thanks for all the feedback.
I ended up getting Evans to fit a like-for-like replacement headset. At first the guy attempted to fit a "better" HS with sealed bearings, before finding (as I did) that the standard sized bearings for 1 1/8" tube don't fit the Laterite head tube for some reason only known to Pinnacle.
At least they were able to do it while I waited and without needing to book it in, and only charged £15 labour, so not too bad.
What does the top bearing look like? If it is equally rusty then you need a new headset. If the top is all good and the bottom race is not pitted then simply fill it up with loose ball bearings (and good quality grease). Get some high quality ones - these won't rust as easily. You'll be good for another 5000 miles.
I'd clean everything, including the cage, replace the bearings, grease up everthing and rebuild, but it won't be great and will not last long, especially with the recent soggy weather. Then plan on getting the whole headset replaced, something with good seals. Buy it through your LBS, organise a day for them to install and you minimise hastle. Bike shops are a bit quieter this time of year too.
New headset is definitely the right answer. Fix it properly.
Get a new headset. Rust and missing balls mean any surfaces will be ruined anyway.
Just use loose ball bearings - and I dare say that is what any shop mechanic would do too.
So long as the balls are the same size it makes no difference.
Book it into Evans to get it replaced. Their bike, their mess to fix.
Personally I'd have no hesitation about scrapping the ball-cage and using loose balls instead. Pack in as many as you can, then remove just one, they will quickly find their own positions. Waterproof grease is a good idea, as I suspect you have already realised. Best of luck.
OK. Thanks for the suggestion.
If they don't keep them, then an option given the age is to find the parts and then use a shop or mechanic who is happy to fit for labour.
Or try another shop!
