Forum Replies Created
Viewing 15 replies - 496 through 510 (of 559 total)
  • in reply to: Practicalities for E-Bike puncture repair #959085
    sounds like you need a good
    sounds like you need a good quality double kick stand
    https://ursus.it/shop/urban-city/big-foot-87/
    in reply to: Mask for Cycling? #957691
    He did talk about hand
    He did talk about hand washing two days prior to that:
    But it is an example of complacency in the face of a largely unknown danger and who knows if he followed his own advice.
    Just like the 2m rule merely reduces the risk a bit, but would not ordinarily constitute an effective safety measure (can you imagine a workplace safety assessment passing that off as acceptable practise?).
    A lot of these measures are better than nothing, but largely a compromise given the situation with the lack PPE meaning little else can be done.
    At this present time, I would look favourably on anyone taking PPE precautions for either the benefit of themselves and/or others.
    in reply to: Mask for Cycling? #957685
    In countries where mask
    In countries where mask wearing is more culturally accepted, the rate of infection seems to be lower.
    The thing I think is a bit of a red herring is the hand washing. The PM was a great advocate of that, but didn’t seem to help him avoid getting it. Sure, it’s better to have good hand hygiene, but this virus is mainly airborne. It’s the only way it could have spread so quickly.
    If you have a P3 mask at home, you are not depriving the NHS. They are nearly impossible to source now, so if you see anyone wearing one, it’s unlikely they’ve deprived the NHS of it.
    It’s not hard to use them properly and ensure you have a good fit. Even the surgical type masks have been shown to have some benefit in protecting others.
    I think we are going to have to get comfortable with the sight of people wearing masks. It may even become mandated.
    in reply to: Mask for Cycling? #957679
    I should say this sort of
    I should say this sort of mask will protect the wearer from aerosol bourne viruses, but not anyone else, as the out breath goes straight through a one way valve with no filter at all (sometimes with a dribble of condensation to boot – nice). I guess you could wear a buff over it to mitigate some of that.
    You can ride in it. It’s noticable but I don’t find it uncomfortable if I go at a steady pace, both in terms of additional breathing effort and temperature/fit.
    In the winter, when it’s proper cold, it’s actually more comfortable to wear it than not. Kind of a https://coldavenger.com but with filtering.
    in reply to: Mask for Cycling? #957677
    I’ve tried all sorts of masks
    I’ve tried all sorts of masks over the past year and a bit. I’ve got a narrow airway and it doesn’t like cold air or diesel fumes.
    I basically found that anything other than a P3 respirator didn’t filter out fumes properly. Also, if the mask is loose fitting, then the moist air you breathe out ends up fogging up any eyewear (with the exception of ski goggles – yes I’ve tried it).
    They also get moisture inside of them after a while, so you really need a proper rubber P3 jobby with one way valves to keep the filters dry. Then after your ride, you can just pop the filters out and give the mask a good wash in warm soapy water ready for next time.
    I’ve settled on the Trend Stealth as the best one. It’s upper fabric strap fits well under a helmet. The vent port is at the base of the mask, so your out breath is directed away from eyewear. It is quite good at allowing condensation to purge from the lower valve, but also has a drain plug you can pull out. The filters are covered with a protective plastic guard, which offers some protection from rain etc.
    But you’ll be lucky to find anything in stock at the moment.
    https://www.trenddirectuk.com/stealth-ml-air-stealth-half-mask-small-medium-apf20
    in reply to: Lockdown Cycling – Speeding Motorist Epidemic #957611
    I’ve been out once for a
    I’ve been out once for a short local loop since the lockdown and noticed the same. A lot less traffic, but people seem to be driving like nutters or saints, there’s no inbetween.
    in reply to: Almost choked on my coco! #954657
    …and here’s his car on
    …and here’s his car on streetview – looks like an accident waiting to happen…
    https://goo.gl/maps/XDa5WreciY7wtP89A
    in reply to: Almost choked on my coco! #954653
    The trouble with these sort
    The trouble with these sort of statements is the assertion that if you wear the protective kit, you will be safe. Sure, the more protective kit you wear, perhaps the better your chances, but it’s far from a given. What is a given, is avoiding collisions like this by not driving like a moron.
    in reply to: Longest Feasible Commute #952439
    For routing, I don’t think
    For routing, I don’t think there is one platform that does it all. Komoot probably gets closest. But a combination of that along with Ride with GPS, CycleStreets, Google Streetview/Satellite view to check road classification, and crucially, cross-checking against the Strava Heatmap https://www.strava.com/heatmap#11.44/-0.09951/51.52752/hot/all
    With that length of commute, you ought to be able to get a bit of variation with a few different route options to keep things fresh.
    in reply to: Longest Feasible Commute #952393
    Had a good experience with
    Had a good experience with https://2gocycling.com in Puerto Pollensa a couple of years ago…
    in reply to: Mud on the road – irresponsible farmers #951567
    kil0ran wrote:
    Most tractors are limited to 30mph so overtaking a road cyclist is tricky, particularly on tight country lanes. I tend to pull over and let them past, otherwise you just end up with a tractor plus a huge queue of pissed off drivers behind it.
    Yep, I pulled over for one of these when I saw it approaching in my mirror the other day. Possibly the most intimidating vehicle I’ve ever seen!
    in reply to: Downhill braking #950265
    Definitely go for the
    Definitely go for the hydraulic brakes. The tiagras have a cooling fin on the pads and as long as they are bled correctly you should have no issues with fading. You could upgrade to vented rotors too in the future (actually I think they might already be vented).
    If you are doing long descents and dragging the brakes, it’s best to alternate between dragging the front and then the rear, to allow for some cooling and give your hand a rest. The advantage of hydraulic is they require a lot less effort, so a much reduced risk of hand cramps, which can be a problem on long descents.
    I think the main reason tandems sometimes have mechanical drag brakes is because they use a friction thumb or bar end shifter to actuate the brake, and I don’t think you can get a hydraulic version.
    in reply to: Now it’s architects having a go at cyclists #949753
    She’s used to cycle paths in
    She’s used to cycle paths in the UK, where peds bimbling around is par for the course. It’s the cyclist that has to keep their wits about them.
    Cycling in Denmark is a ‘proper’ form of transport. Walking in a bike path is akin to taking a stroll in the middle of a motorway in the UK.
    in reply to: Tandem braking #949561
    If it’s a nice retro Mercian,
    If it’s a nice retro Mercian, I’d be inclined to keep it as close to original spec as possible.
    It’s unlikely that you would be able to safely braze on disk brake mounts, as the frame and forks will not have been designed to take the extra load a disk brake puts on the tubes.
    I’ve taken a 1980’s Peugeot tandem down the honister pass in the Lake District, had the mafac cantis and drum drag brake. Hairy but doable, even on the steel rims!
    If you are getting new tandem spec. wheels anyway, then the new rims will likely have a better braking surface. So the canti’s will perform better, and you can always upgrade to v brakes.
    There are good reasons why hub brakes are good as a drag brake. Yes, they are heavier than disks, but they won’t overheat and fade as quickly. They are usually operated on a friction thumb shifter, so you can set-and-forget it on long descents. I’m not sure a hydraulic thumb lever exists? So, you would be looking at cable operated disks, which are less powerful and more faff maintenance wise.
