Forum Replies Created
ouch, that’s a bit pricey – I
ouch, that’s a bit pricey – I think I’d take my chances crashing into a bear, they look quite fluffy and soft, probably not too bad a landing!
Well I gave the bear bell a
Well I gave the bear bell a shot – rubbish.
I can see it might work for a mountain bike, but on a road/town bike there’s just not enough motion to cause it to ring. I have to dangle it from the end of the handlebar and wiggle the bars to get a reasonable ring, which isn’t going to work.
So I replaced my broken bell on the town bike with the venerable Widek 80mm ding dong. It’s big, heavy and loud. Plus doesn’t sound too agressive.
In my internet travels, I came across this shop that had the widest selection of bells I’ve ever seen – most with a sound clip too.
https://hollandbikeshop.com/en-gb/bicycle-accessories/bicycle-bells/
September 15, 2020 at 7:54 am in reply to: Cyclists find wallet and $4,000 in $100 bills that fell from man’s truck #970389HoarseMann
going to buy a trailer later.
going to buy a trailer later… shaking when he got the money back…
thanks guys, now I won’t get my legs broken – I mean, can go and buy that trailer…
hirsute wrote:
hirsute wrote:Hmmmm Is there any cycle path that will satisfy the posters of roadcc ?
hirsute wrote:
hirsute wrote:It is signposted and easily joined from the small roundabout and from the traffic lights.Only easy if you know it’s there.
If you are concentrating on traffic on a roundabout, it’s easy to miss dropped kerbs to join cycle paths. They’re usually not easy to join from the road either – being primarily designed to facilitate where a cycle path crosses the road at right angles.
There’s been many a time when riding in an unfamiliar area I’ve thought, oh, that would have been a nice bike path. But I’d already missed the dropped kerb and not easy to stop in traffic to lug bike over kerb and verge.
Interesting to know how you
Interesting to know how you get on with the bear bell. I’ve considered a Timber! bell, but not sure how well it would work on a road bike vs MTB.
September 11, 2020 at 10:38 am in reply to: Car crashes into building – please post your Local news stories #963583HoarseMann
This is from a few years ago.
This is from a few years ago. If my average speed had been a smidge quicker, I would have been stood exactly where the car is. Saved by being a bit unfit.
Call me superstitious, but I don’t use that crossing anymore!
If her only reason for having
If her only reason for having a car is the weekly supermarket shop, she needs to work out how much she would save by shopping online and getting it delivered.
Bet she could switch from Aldi to Ocado and still make a huge saving.
If you get the back wheel
If you get the back wheel spinning up fast with the cranks on the stand, then stop the cranks you should see the chain droop if this is the problem.
It was a weird one to fault find as it wouldn’t happen when I was coasting at my usual pace, only when I’d got some speed up and stopped pedalling. Freehub still worked, but there was just that bit of drag that was enough to cause the chain to go slack.
I’ve had something similar
I’ve had something similar with a failed freehub, but thankfully didn’t get spat off.
It only started to happen when the speed picked up, the pawls were not allowing the freehub to spin when I eased off the power on the cranks (it didn’t completely not spin, but there was significant drag). This caused the upper part of the chain to go slack between the cassette and front mech. It felt a bit weird, I looked down and saw the chain slopped on the chain stay and dangerously close to the rear wheel spokes.
It’s possible you had something similar, but were unlucky enough that the chain jammed the rear wheel. Hope you heal quickly.
could be caliper alignment?
could be caliper alignment? worth unbolting the caliper and re-adjusting just to see if it makes a difference.
try a different pad compound? sintered?
try a *very* small amount of high temp grease thinly applied to the back of the pads where they contact the pistons.
I use cycliq cameras front
I use cycliq cameras front and back. they’ve been reliable for me and of all the options I’ve tried, the least faff.
I did have to replace the fly6 battery after 18months (approx 4000 miles) as it started to just cut out mid ride without warning. I had used it a lot though and in all weathers.
I’ve not noticed any scratching of the lens, but I do run mudguards in the winter (you need to with a post mount camera or it’ll soon be obscured by filth).
Don’t engage. There’s a
Don’t engage. There’s a reason they are driving like a tw@t – it’s because they are one. You are unlikely to change their behaviour by remonstrating. Some people are just nutters that cannot be reasoned with.
As much as a faff charging cameras is, it’s the only proper way to counter this behaviour. Glad you are ok.
I tend to ride just left of
I tend to ride just left of the centre of the lane too (the middle has too much debris).
I started doing this after a few incidents where I reckon my moving from secondary to primary prior to a pinch point had been taken as an offensive ‘up yours’ type gesture by the ignorant motorist behind me.
I think just being in that position when I come into their view is less likely to provoke a reaction. I then purposely move over to secondary when it’s safe for them to overtake. I’m not impeding anyone by doing this.
Whether it’s ‘you don’t pay road tax’ abuse or a close pass, it all boils down to ignorance; of how the roads are funded, of how to overtake safely. But there’s nothing in the highway code about why cyclists ride in primary and the overtaking guidance is woefully inadequate and open to interpretation.
So if a government advertising campaign coupled with changes to the highway code, could communicate this effectively, then I think it could improve things. I think it would also have to be aligned with presumed liability being brought in and more effective enforcement from the police; as you still need to tackle the few motorists that really do actively hate cyclists or are just reckless nutters.
But it’s probably as likely to happen as the gov ‘build build build’ spinitiative including segregated cycling infrastructure.
this approach hasn’t been
this approach hasn’t been mentioned yet
