- This topic has 11 replies, 7 voices, and was last updated 5 years, 10 months ago by
wtjs.
January 25, 2021 at 2:34 pm #31386
Singe69
Having had some really helpful responses to a question about lights for Garmin mounts, I wonder if anyone has recommendations for day front lights that fit a GoPro mount – they are REALLY difficult to find.
Thanks in advance.
Thanks, WB
Thanks, WB
Balthazar
If this is any use to you,
If this is any use to you, here’s the scenario on my (grubby) bike. A stem-bolt garmin mount with a GoPro mount underneath. A cheap GoPro-to-Moon bracket attached to that, and a small Moon light clipped to that. As written, it sounds like a lot of mounts! But it looks minimal and doesn’t add up to much in either expense or weight. All the off-brand bits were bought cheaply from the usual places.
if you use a stem-bolt mount, it’s important that you recognise the mount has become an integral part of the handlebar/stem interface. Any material failure could be disastrous. Don’t install one if you aren’t confident to risk-assess it. For my peace of mind, I replaced the unmarked bolts that came with mine, with load-rated steel bolts.
Welsh boy
I have never used a GoPro but
I have never used a GoPro but the eBay listing says it does
Welsh boy
I have been using mine for a
I have been using mine for a couple of years, fit and forget but just to be sure I have fitted the light with slightly smaller O rings than the ones which came with the mount now I am using it to hold a £100 plus Exposure light. I also have a similar setup on another bike but it is a handlebar mounted version and I have modified it (super glue and epoxy resin) to take a different light. No hesitation in recommending it to anyone
Thanks to all concerned for
Thanks to all concerned for these helpful links- I am rather ashamed to admit that I did not know about these stem bolt mounts at all. Welsh Boy: the mount on eBay is cheaper than suchlike devices on Amazon. I take it you have found this to be durable and functional?
kamoshika
I use a Exposure Sirius front
I use an Exposure Sirius front light, and they make a GoPro mount for that and, I suspect, other lights in their range. Really good light too.
OnYerBike
Several brands have adapters
Several brands have adapters available for certain products e.g.
https://exposurelights.com/products/bike/brackets-and-mounts/3prong-action-camera-to-exposure-cleat
https://www.giant-bicycles.com/gb/recon-light-adjustable-gopro-mount-2019
Sometimes you can find third-party adapters e.g. https://www.r3pro.co.uk/collections/cree-light-mounts
Singe69
Great – thank you
Great – thank you
Singe69
Thanks – does that light have
Thanks – does that light have a gopro fitting?
Welsh boy
This (or should I say These)
This (or should I say These) are what I use on one bike:
And
https://www.evanscycles.com/brand/fwe/rechargeable-front-light—300-lumen-931672#colcode=93167203
vincenslo
Hi,
Hi,
Moon do a Gro-Pro adaptor that fit some of their lights (adaptor is around £6) Google: Moon Light Adapter for GoPro Mount. For a day light they do e.g. the Nova 80 for under a tenner.
Cat-Eye have a bracket that works with Go-Pro mounts: https://cateye.com/intl/products/parts/1604110/ (for some of their light although not all)
Garmin Varia UT800 (Expensive though).
