Can I build a single speed mountain bike…!?
  • This topic has 22 replies, 15 voices, and was last updated 9 years ago by SingleSpeed.
  • #27607
    hoffbrandm
    So the wife has agreed.
    I can build the single speed utility bike that I desire.
    But she has now decided she would like to go mountain biking with me…
    You think its possible to build something that might be able to handle both? like a CX single speed frame, aslong as it could take chunky tyres.. Or am I being too ambitious.
Viewing 15 replies - 1 through 15 (of 22 total)
  • #901761
    SingleSpeed
    hoffbrandm wrote:
    So now I just need to examine finding the correct frame to purchase…
    Start here:
    On-One, Surly, Niner, Salsa, Curtis, Singular
    #901759
    SingleSpeed
    Sniffer wrote:
    So your comments about going faster don’t apply to Pros, but they do apply to you?
    Yes, because I’m not paid to ride a bike, get them donated but I’m not paid to to ride ’em thats for sure! Nor am Iriding on UCI XCO courses, I’m riding Bontrager Twentyfour12, Torq 12 races etc where there it makes a degree of sense.
    I’ve just built up a new steel SS road bike, carbon 50mm wheels 38:16 gearing it’s my Fred Whitton 2018 bike 🙂
    #901757
    hoffbrandm
    Concurrent with SingleSpeeds
    Concurrent with SingleSpeeds 10 point plan.
    I THINK the kind of riding we would end up doing is much more cross country/cross bike capable.
    Some youtubing makes me think its possible on a cross bike and hey, shes slow. so maybe this might just give me a challenge!
    The fact that I’m used to road bike geometry makes me think I’ll be quite at home on a cross style bike. just with knobbly tyres.
    #901755
    Sniffer
    SingleSpeed wrote:
    Al__S wrote:
    Presumably pros riding XC racing could go SingleSpeed if they wanted? Any rule against it?
    No rule against it, but you’ll never win against geared riders unless the condition favoured it, i.e. conditions so bad that gears simply fail to work.
    D
    I do accept there is some merit in some of your arguments, but I won’t be joining you anytime soon.
    #901753
    SingleSpeed
    Most 12 & 24 hour Races will have a Singlespeed Category, short track XC races won’t as the advantage is simply not there.
    #901751
    Al__S
    #901749
    SingleSpeed
    1) Going up Hills – Standing
    1) Going up Hills – Standing up and mashing up a hill in 34-18 is invariably faster than twiddling around in 34-42 assuming…
    2) You’ve got the legs for it – no gears means you have work harder
    3)Going down hills –  unless you are going down a super long fireroad you’re not going to spin out on most descents plus it improves your…
    4) Technique… because you’re not changing gears you tend be a smoother rider relying on pumping and not braking into corners so you carry more speed plus because your chain is pulled taught you will…
    5) Never drop a chain.
    6) No gears means no chainsuck or clunking gears in terrible conditions.
    7) Weight … my Niner One RDO is a pure SS Race machine it weighs 7.5kg and is stiffer than my Cento Uno
    8) Improvements in cadence – I can happily bob along on my MTB at 27-9kmh on the flat running a high cadence, even dropping into some MDCC rides on a SS MTB 🙂 Translate that over to a geared road bike and the results are noticables
    9) Whole body conditioning – you have to be strong none of this emaciated disgraced cyclist Bradley Wiggins upper body. you’ve really got to pull hard and feeding back into technique of how to really pull a powerful stroke when standing up
    10) You’ll never find yourself in the wrong gear because you’re never in the right gear in the first place, no missed shifts, no bad gear choices you have to be a master of momentum and smoothness
    #901747
    Sniffer
    SingleSpeed wrote:
    CygnusX1 wrote:
    The answer to can you build a MTB with SS is of course you  can, but as Sniffer says, you would be silly to do so.
    Give me one reason why and I’ll give you ten good reasons why I’m quicker than you on my SS MTB
    Hills?
    On the trails I ride I don’t use the front mech much (and could do without it) and I use the rear cassette plenty.
    MTB for completely flat areas did sound a bit silly to me.  If it has hills then changing gear keeps a sensible cadence and I would expect it to be faster.
    I look forward to be educated on the 10 reasons why I am wrong.    cheeky
    #901745
    SingleSpeed
    #901743
    CygnusX1
    Sniffer wrote:
    A single speed MTB, or a bike with a single chainring?
    A single speed sounds a bit silly. 1x for MTBs, plenty of those.
    A lot of comments assume, by single speed, the OP means 1x (single chainring, but with a range of gears on the wheel).
    However he was talking about a utility bike so a single speed  (1 chainring, 1 rear cog, with either a free or fixed wheel) is a sensible set up – low maintenance, perfect for just nipping to the pub/shops (unless in a hilly area).
    #901741
    Richard1982
    One of my favourite bikes is
    One of my favourite bikes is my single speed MTB, I say go for it 🙂
    https://www.pedalroom.com/bike/raleigh-m-trax-ti1000-1994-27740
    #901739
    Yes you can.
    Yes you can.
    I too have seen a single speed surly at swinley forest.  I was very impressed.  I need most of my 3×9 xtr.
    #901737
    MonkeyPuzzle
    What do you mean by utility
    What do you mean by utility bike? I’m unclear what it would be used for other than MTB…
    #901735
    Why not hire a pair of bikes
    Why not hire a pair of bikes for you and the wife to do a MTB ride?
    If she doesn’t like it or feels she has scratched the itch then you won’t have splashed out. If she decides she wants to do it regularly then you could either play the n+1 card or build a really nice do-it-all ‘cross/gravel/MTB machine.
    #901733
    StraelGuy
    When I got back into cycling
    When I got back into cycling about 4 1/2 years ago I did the first 2,000+ miles on my 1990’s Dave Yates running 1×9, it was awesome.
