- This topic has 24 replies, 21 voices, and was last updated 9 years, 1 month ago by
Anonymous.
August 28, 2017 at 11:09 pm #27569
darrenleroy
I love the simplicity of 1x and Sram has almost seduced me (although I’ll wait until they bring out an eTap version as that would be fantasy perfect).
Would anyone else consider switching from a double to a single chain ring or is that just plain hersey?
im 1×9 on my gravel/cx and F
im 1×9 on my gravel/cx and F/S bikes 32t oval and 12-36 cassette. However Im sure I would miss the extra range on my road bike so use 34/50 and 11-32.
If I only had one bike, Id probably have a gravel/cx bike and use a 36t oval with 11-40 gearing.
exilegareth
Must admit, if I was building
Must admit, if I was building a TT bike from scratch for most of the roads we use up here a 1x setup would do the job, but not for the more sporting courses. I can imagine plenty of guys who could do, say, the Gibbet on a single ring setup, but what are the benefits?
I don’t ge the frantic urge to ditch the front mech – it adds a little more weight (less than a pie, and less than you thionk since the casssette with bigger rings for 1x weighs more) ) and a little more complexity (but I can’t imagine how you break one) so besides fashion, and go faster stripe potential, why the big noise?
AKH
A cynic would say SRAM couldn
A cynic would say SRAM couldn’t get their front shifting as slick as Shimano’s, so they tried to sell the lack of a front derailleur as a feature. What’s so bad about a front derailleur anyway ? Surely the answer is better front derailleurs, not throwing the baby out with the bathwater.Jimthebikeguy.com
Front mechs are dead, they
Front mechs are dead, they just don’t know it yet…. At the moment though, for road, the perfect 1x setup doesnt exist and there are issues with extreme chainlines. Prob the closest ideal right now is the SRAM 11-36 wifli cassette, or even the 11-42, with maybe a 48t upfront, and just expect a bit of spinning out downhill. But your rear mech needs a longer cage.crazy-legs
For a crit race bike,
For a crit race bike, absolutely. 48 or 50T chainset coupled with an 11-25 cassette for super close ratios. After all, you only ever use the big ring in a crit race!
For a CX race bike then again, 1x working off a 36 or 38TT chainset with a 12-42 cassette would be perfect. Less problem with big jumps in a CX race and much less to clog up and go wrong.
For a more all-round bike – gravel bike, road bike etc I still prefer 2x.
Crampy
Nah mate – the big jumps in
Nah mate – the big jumps in gearing really do my head in. I find it very uncomfortable not being able to find the “right” cadence.
My road bike is 2X11, my CX is 2X10 and my mtb is unashamedly 3X10.
Plus when I was out at the weekend in the nature, I saw a big bunch of XC guys with 1X12 setups and the tiny small chainring with the pie plate cassette just looks… well wrong in my opinion.
Strathbean
I used an old 10sp 11-34 mtb
I used an old 10sp 11-34 mtb cassette (11-13-15-17 etc) with a compact chainset on my road bike for a while when i was recovering from an injury. The low gears were great and that side of things worked well, it got me thinking i could get away with a 1x setup.
But I also found that when cruising along on the flat the jump from a 13 tooth to an 11 tooth gear was often too much i.e needed an intermediate gear. Even the jump from 13 to 15 was inconvenient sometimes.
For me, thats the limitation of a 1x setup for fast road use, you might get away with it if its just for pootling about, but not if you want the option to go as fast as you can.
surly_by_name
Don’t understand why you
Don’t understand why you would do this for road. (MTB and cross yes, road no.) Gaps at the end of the cassette (or lack of small enough cog) will drive you mad. Front shifting on a road bike not all that hard, esp with etap. I think you can now programme Di2 so it runs through gears sequentially, so no need to change front shifter yourself at any point (certainly you can do this with DiXTR and DiXT).
kev-s
Have used 1×11 on the mtb for
Have used 1×11 on the mtb for a few years now
I would have it on the road bike but it would prob be 1×12 sram eagle (10-50t cassette)
Would love not to have trim the front mech (something i used to love about my old Di2 setups is that it trimmed for you)
Only problem is from an aesthetics point of view nothing looks as good as my current groupset (campag super record)
cyclisto
Now I run 3×9 gears so I have
Now I run 3×9 gears so I have big range and I use them all in my daily commute. With a small chainring I guess I would be able to survive and just spin a little more when downhill. I really like the simplicity of 1x but they are still unjustifiably expensive and not very sure about how cross chaining will affect my wearable items and effort spent. So 1x stays as a fantasy, I don’t have any actual reason to change my old trusty 3×9Redvee
I’m running a 1×10 5700 set
I’m running a 1×10 5700 set up on my commuter bike, 42 12-28, and sometimes feel the need for the inner ring but manage to get up the hills, just. I did run with just a RH shifter but it didn’t feel right, one hand full and the other comparitively empty when riding on the hoods so I now have 5700 shifters on both sides but have ‘locked’ the LH shifter with a 3″ piece of gear cable.
alansmurphy
Darren, have a look at a gear
Darren, have a look at a gear ratio calculator:http://www.bikecalc.com/gear_ratios
Example link above. If you know what you’re happy with on your current set up you can look to match…
BBB
Get a 44-46T narrow wide
Get a 44-46T narrow wide chainring and try it. It’s as simple as that. You don’t need any dedicated groupset for that.
Personally, having run 44 and 46 rings with 11-25 to 11-32 10 sp cassettes for a few years on my commuter and Sun best, I can’t see any reason to go back to a front mech.
It’s all about the experience of simplicity.
darrenleroy
grmtylr wrote:I’ve been running a 1×11 for the past 18 months or so on my road/gravel bike.I was originally running a 42t up front with either an 11-28 or 11-32 cassette. It wasn’t too bad but rides with lots of climbing could be hard work. I also tried running the 11-28 with a 50t up front which was good for flat rides but bloody tough on the hills.
Since the start of the year I’ve been running a SRAM Force 1×11 set up with a 42t up front and a 10/42 cassette. It’s been fantastic. Managed a week in The Alps and was never short of gears. I was originally concerned about the gaps between gears but in all honesty it’s not bothered me at all.
I think that a 1×12 set up with the 10/42 gear range and closer ratios would be great. Hopefully SRAM will be moving it across from the MTB groupsets onto the road ones soon.
I’ve been looking at going back to a double set up with Etap this weekend but decided that it’s probably a waste of time. Etap 12 speed could change my mind though!
I think you may have convinced me! I know 10/42 may be as aesthically pleasing to the purist as an 11-26 but if you were in the Alps and didn’t run out of gears that is good to know. eTap 1x 12 speed would be my ultimate set-up. I guess we’ll have to wait…
darrenleroy
ianguignet wrote:i use SRAM cx1 force on road,gravel etc. Brilliant. Wouldnt go backWhat gearing is it? Do you find you ever need more low gears?
