- This topic has 8 replies, 7 voices, and was last updated 11 years, 2 months ago by
stevent2955.
August 25, 2015 at 2:33 pm #24696
stevent2955
Hi there, I am currently riding on a 53T/39T chain ring.
I like riding the 53 ring for speed but struggle on the hills on the 39T.
Is it possible to swap out my 39T for a 34T or will the gear jump be too big and the chain come off?
Any other advice welcomed.
Thanks
Steve
stevent2955
Thanks for the feedback. I
Thanks for the feedback. I apologise that I am not a member of the chaingang or in the old boys club. Cutting through some of the sarcasm and general rants there is some really helpful feedback here. I am a triathlete (sorry!) and recently moved up from olympic to 70.3 distance and really struggled to not burn my legs out. For 40km I can grind out maintain 23mph average on flattish road and still have enough in my legs to run 10km. However this isn’t so good when the distance is 90km and there is 21km to run after. I have been working to try and get my cadence up but really struggled on long hills, literally ran out of gears. Some of it is probably my engine and riding style but I think from the advice here a compact would probably do me fine and will look to chain over at some point.
ThanksYorkshie Whippet
Couple of things come to mind
Couple of things come to mind some already said before.What type of rider are you? Sounds like you have a “big” engine and can hold high speeds on the flat for long distances. Therefore you may not be able to climb that well anyway regardless of the gearing. Think Boonen, Tony Martin and Cancellara.
No it will not be possible, chances are you have 130mm bolt pattern, 34 tooth have a 110mm bolt pattern. Even if you could, the limit for the mechs would be exceeded and the chain would either be too long for the 34 or too short for the 53.
What are you using at the back? It maybe possible to change the cassette to give you a lower gear without compromising the speed element. But it all depends on what gradiants you climb as you could be seeking something that doesn’t exist, gears that get you up 20% and allow you to do 50mph. This goes back to what type of rider are you?
If you can afford it, trying a 52/36 with 12-30 cassette, as suggested, might be the best compromise.
crikey
Aww, you’re another one,
Aww, you’re another one, desperate to be offended on someone else’s behalf.My point, which in your urge to froth you have missed, is that you can learn to ride on smaller gears. It may not be a direct answer to the original question, but it does follow the thread which has moved on to discuss the idea that one can ride quickly without big gears.
HalfWheeler
crikey wrote:In the old days,
crikey wrote:In the old days, if you rode with a club there were various rules/guidelines about. One of them was ‘never use the big ring before March'Absolutely. I remember a lot of the guys using a 42×18 fixed or single right through the winter.
Big chain ring use seem to be de rigueur now regardless. Personally I never use the big ring unless I’m racing or out with the chain gang. A 39×15 or 14 is still plenty big for club run speed. Mind you, my inside ring is like a ninja throwing star as a result…
crikey
Jesus….
In the old days, if
Jesus….In the old days, if you rode with a club there were various rules/guidelines about. One of them was ‘never use the big ring before March’; which to todays youth might sound a bit silly, but it encouraged people to learn how to ride at a high cadence.
You read the occasional stupid who will insist that he needs a bigger gear because he just can’t go fast enough with 52-12 or 50-11 and the correct response is to laugh. One of my team mates snapped his front derailleur cable in a race and still got in the top five with 39-12.
TL:DR; learn to ride.
Kim Chee
Yeah, def. work oh smooth
😀 Yeah, def. work oh smooth spinning. A 50×11 is way faster at 100 rpm than most folks can sustain-get a cadence meter and actually measure your cadence. If you actually can sustain 110 rpm in a 50×11 you should go pro and let your mechanic do the job. Otherwise, 1) the ramps on the 53 are optimized for the inner ring it came with, so there will be no assist from the 34T radius to the 39 tooth radius (poorer shifting bottom line); also if you use the stupid 34 front x any of the rear 5 gears the chain will grind between the rear deraileur pulleys as this combo will almost certainly greatly exceed the official capacity to carry chain-but like I said, the noise is just a reminder to not use the (silly anyway) 34x rear low tooth count gears.Leviathan
Try reading this
Try reading this thread:http://road.cc/content/forum/130788-who-uses-mid-compact-5236
could be your solution. You can make up for big ring with a bit more cadence. I’ve not looked back.
CXR94Di2
Depends what you call fast
Depends what you call fast for the 53t. If you mean north of 26mph consistently on the flat then a comapct 50/34 chainset will do you perfectly. 50×11 is 32mph @90rpm -
