Forum Replies Created
Maybe the cyclist had a
Maybe the cyclist had a version of that close pass detector mounted on the bars – but the one that instantly disables the offending vehicle with an electromagnetic pulse!
Sriracha wrote:
Sriracha wrote:before it drowned did your Fly12 at least catch the idiot who drenched you?It will have written the video data to the SD card, but it’s likely the file will be corrupt.
I’ve had success using HandBrake to repair a corrupt Cycliq file and recover most of the video footage.
November 11, 2021 at 9:07 pm in reply to: What would you say to the Institute of Advanced Motorists in response? #985779HoarseMann
Quote:
They should be as considerate a road user as the motorist.On the mode of transport scale of considerateness, the choice of the motorist is pretty low down the list in my view (well, unless your only consideration is yourself).
For short commutes you could
For short commutes you could probably make the insta work ok (battery life is only an hour and file sizes are huge). It will be a bit more faff than a Cycliq (no loop record, so having to open app, wipe, start recording prior to each ride).
But for longer rides (or less faff regular commuting) you can’t really beat the convenience of the Cycliq. It’s a simple as adding lights to your bike.
To get longer from the 360 you’d need an external battery pack, or stop to swap batteries every hour, not to mention a large SD card and regular manual wiping of footage.
November 7, 2021 at 8:45 am in reply to: Driver walks free after hitting six cyclists, killing one in Liberty County #985613HoarseMann
Sriracha wrote:
Sriracha wrote:Struggling to understand the narrative. Was his “failure to maintain his speed” a consequence of colliding with so many cyclists, or did he hit the cyclists because he slowed down?I thought that was strange wording, but it’s just what they call speeding in Texas…
https://mcminnlaw.com/texas-refresher-failure-to-maintain-speed-law/
hawkinspeter wrote:I’m now wondering if I should have bought a 105 in replacementWell, it’s not a wrong choice to favour performance over durability and as you say, you’ll know what to look out for now.
Good idea for reflective
Good idea for reflective placement!
Perhaps Shimano have gone a step too far in the quest for lightness with epoxy bonding a crankset.
Blimey, that could have been
Blimey, that could have been very nasty. Seems to becoming a common problem with these cranks, well explained in this video https://youtu.be/FkEkQV-zK0s?t=181.
What are those black dot stickers near the pedal end? Did you get cracking there?
For a long descent, it’s
For a long descent, it’s worth doing some finger grip strength exercises with something like this.
We think about braking technique (not dragging the brakes & alternating front/rear to allow rims/rotors to cool), but not often about training hand muscles to prevent cramp, which can be a problem on a very long descent.
Also, I’d have a practise somewhere safe at the emergency braking technique of putting your heel on the back wheel.
Damn I’m jealous!
In the DM too – and to be
In the DM too – and to be fair to them (can’t believe I wrote that), they’ve embedded the whole youtube clip, no editing like the BBC…
As you say, they’re estimates
As you say, they’re estimates based on an algorithm. But they can help if you are trying to lose weight by calorie counting, as on days when you’ve done a big ride, you will be able to eat more and still be in deficit! I have managed to lose weight a few times doing this, though it’s a pain logging all your food intake! I’ve used both Fitbit and Apple Watch successfully to track calories – they seem to be ball-park accurate enough for this purpose. (I found this interesting article about it online)
One key thing to make sure is your weight is set accurately in the Strava app and also in the Apple Health app. This can have big effect on accuracy. Also, the use of a heart rate monitor (or power) will improve accuracy (obvs. the apple watch has HR built in). Did you use a bluetooth HR monitor to link to the Strava app?
I saw an apple promotional video a while back (can’t find it online), where they explained the research they’d put into developing the calories burned algorithm. It did seem quite extensive and the Apple watch usually does quite well in reviews when compared to other similar devices.
that’s a good tip – got some
that’s a good tip – got some in the garage (somewhere!)
Good news that has sorted it.
I reckon the thing that causes my valve cores to work loose is the head on my track pump. It’s a clamp on type and just the process of attaching and removing this is enough to work the core loose after a while.
chocim wrote:As Podc above has suggested, the problem may be insufficiently tight valve cores. This was also something that we thought of yesterday evening, so we retightened them (using latex gloves gives better purchase than using bare hands, and they are pretty tight now) and we’ll see what happens.Conti tubes have flats on the valve core so you can get an adjustable spanner or plier on them. They only need to be nipped up, not really tight, but I suspect finger tight might work loose or not quite seal.
I got caught out by this the other day, ended up taking the wheel off and hunting for a puncture that wasn’t there. Wasn’t a new tube either – been on years!
September 5, 2021 at 7:36 pm in reply to: Portishead cycle club fits cameras to bikes to protect from ‘dangerous’ drivers #984035HoarseMann
Nah – that’s just messing
Nah – that’s just messing around, the only way to do EMP properly is the nuclear option…
