- This topic has 14 replies, 10 voices, and was last updated 6 years ago by .
I’ve just made the switch to tubeless and encountered an issue when setting up the tyres.
When pumping one tyre up air is leaking from the valve stem and is audible on the inside of the rim. I’ve tried tightening the Presta valve nut more, and pushing the valve down to ensure it is seated as far down into the rim bed at possible, but still no luck.
The other wheel has the exact same set up and is holding air fine.
Any suggestions would be appreciated.
Viewing 14 replies - 1 through 14 (of 14 total)
