Why are rack mounted rear lights rubbish!
  • This topic has 12 replies, 13 voices, and was last updated 8 years ago by LastBoyScout.
  • #29000
    Fizzy77
    Why is it that when you can find somewhere that stocks lights for rear racks they tend to be pretty poor compared to other lights on the market. I think I’ll have to make a custom bracket to fit a decent LED light on the back.
  • #928105
    LastBoyScout
    Another vote for the Cateye
    Another vote for the Cateye rack mount – I have a couple of Cateye rear lights that fit it.
    #928103
    fenix
    +1 for the Seesense Ace.
    +1 for the Seesense Ace. Great little light.
    #928101
    Dingaling
    I have 2 philips safelights,
    I have 2 philips safelights, one on the rack of my tourer and one on the seatpost of my road bike (when needed). I was so impressed with the first one, I went out and bought a second one. I find the larger format puts out more light and has a better range. LED’s are an intense light source and may dazzle at arms length but many don’t put out enough light to be see very far off.
    PS I learned here that Spaninga took over making the Philips Safelight.
    #928099
    CXR94Di2
    Busch Mueller lights are very
    Busch Mueller lights are very good, get a dynamo wheel hub for a great setup
    #928097
    aegisdesign
    Another vote for the Spaninga
    Another vote for the Spaninga Elips. Spanninga bought up the rights to Phillips’ Saferide lights when they pulled out of bike lights a few years back. The Elips is a newer version of the Phillips rear light.
    I had a couple of B&M rack lights – one battery, one dyno powered before getting the Phillips rear dyno light. The B&M lights just don’t compare.
    #928095
    vonhelmet
    I use one of those cat eye
    I use one of those cat eye brackets with an omni 5 rear light. It does the job just fine. The square on the back of the light has started wearing out after like 5 years use, so I’ve cut a loop from an old inner tube to go round it and stop it rattling over rough roads.
    #928093
    Cateye has a rack mount that
    Cateye has a rack mount that is compatible with their standard LED lights (the ones with a square ‘foot’ that slides into the bracket). I’d be more than happy to use it with the LD600 or LD610 for example (both use 2xAAA, are bright and have excellent battery life).
    Smart have a bracket too, the LB608, which I bought for my kids to use with their 0.5w Superflash rear lights. It works fine but the build quality of the light itself (and the standard seat post bracket) is significantly inferior to all the Cateye units I’ve tried, which have all been excellent.
    #928091
    DoctorFish
    Cateye do a mount
    Cateye do a mount
    #928089
    Bmblbzzz
    Another vote for the B&M
    Another vote for the B&M Toplight Line Plus. Wordy name for a decent light.
    #928087
    I have used one of these
    I have used one of these packed out with some spare plastic spacers from older lights (or you could use an old inner tube).
    https://www.rosebikes.co.uk/cateye-sp12-replacement-bracket-for-tl-ld611g-787960
    Can also use cable ties depending on the diameter of the light.
    #928085
    kil0ran
    The new See.Sense Ace will
    The new See.Sense Ace will mount to a rack
    Also have a look at the B&M Toplight Line – I’ve got a dyno version but they do battery ones too. Available in 50mm or 80mm fitting
    http://en.bumm.de/produkte/akku-ruecklicht/toplight-line.html
    #928083
    Spaninga is your friend
    https://www.amazon.co.uk/Spanninga-BRASA-Pannier-Carrier-Light/dp/B009MVME0W there’s also the Elips which has an oval shape to the light.
    I actually used athleteshop last year but they ceased trading earlier this year leaving many people high and dry without their orderssurprise
