Change of gearing – big difference?
  • This topic has 12 replies, 13 voices, and was last updated 8 years ago by Anonymous.
  • #28781
    daveed80
    Looking at a new bike and realised there is quite a difference in gears.
    currently have Shimano 105’s, 11-32 cassette on 50/34 chainring.
    upgrading to a bike over 1.5 kg lighter, runs on Ultegra 11-28 cassette on 52/36 chainring.
    with this change, will I notice a big difference on hills? I know the majority of the potential new bike is an upgrade but just concerned that with hills around me that I like the challenge of on current set up, will this make what I find are challenging climbs verging on impossible?
  • #924413
    fukawitribe wrote:
    FWIW – the 6800 GS RD will take an HG-x00 11-34 without any issues. Fitted a HG-800 and it didn’t even need an adjust on the b-tension screw (new chain was fitted at the time)
    Ultegra 6800 and DA 9000 SS both can do a 32T with the B screw right in IME, I tried (for the sake of testing) big big and it was no bother at all, I tried again on the road and still no issues. Personally wouldn’t use big big but for that situation when you are tired or simply forget where you are it’s great to know it’s not going to knacker up the drive train or worse.
    #924411
    sergius
    My bikes vary between:
    50/34 – 11/32
    52/36 – 11/32
    52/36 – 11/28
    I barely notice.
    Admittedly I’m a climber, but the only thing I notice between my bikes is having to get out of the saddle for a couple of really steep bits which I can spin through on the other bike.
    #924409
    Griff500
    Big difference, but not as
    Big difference, but not as much as the numbers suggest. I made a similar step a couple of years ago, moving from a decent alu bike, to a carbon 3kg lighter. I did the maths, 34/32 to 36/28 loses me 21%, and 3kg reduced my all up weight by around 4%, leaving a 17% numerical difference. Given that the steps between your bottom gears is about 12%, the new setup effectively raises you by a gear and a half. On the road, it doesn’t feel that much to me. Maybe it’s the stiffer frame transmitting more power to the road instead of twisting the frame twice per rotation, or maybe it’s the psychological advantage of riding a nice bike. I still ride both bikes, but on a tough ride I’d take the new bike every time, despite its higher gearing.
    #924407
    matthewn5
    Canyon48 wrote:
    Switching from having a low gear of 34:32 to a low gear of 36:28 is a massive difference.
    Yes, 21% higher lowest get, by my calculations.
    #924405
    VeloUSA
    Use Sheldon Brown’s gear
    Use Sheldon Brown’s gear ratio calculator. We don’t know what gears you curently use, but you do, so by comparing ratios between the two sets you’ll have a good idea what to expect.
    http://www.sheldonbrown.com/gear-calc.html
    #924403
    ibr17xvii
    Exactly the same as what I
    Exactly the same as what I have – compact & 11/32 on the winter bike, 52/36 & 11/28 on the best bike.
    Believe me you will notice at both ends of the scale, both your lowest gear for the hills & the larger big chainring for crusing along.
    That said I like to try & use bigger gears in the summer when the weather is better & lower gears for the winter.
    #924401
    Canyon48
    Regardless of the loss of 1.5kg, you’ll notice it’ll make hills much harder, it’ll be like losing the 3/4 easiest gears on your current bike.
    I’d suggest buying a larger cassette and matching derailleur.
    #924399
    J886atv
    I’d go a halfway house on
    I’d go a halfway house on this.  I had exactly the same issue but ended up only needing to put an 11-30 on the nicer / ligher bike running the 52/36 crankset – the 1.5kg weight was the difference up the hills so I just end up climbing (and cruising) faster
    #924397
    CXR94Di2
    yes you will notice a 36t
    yes you will notice a 36t chainring compared to 34t. Fit a 11-34 cassette to offset the loss of the smaller chain ring. Alternatively fit a 34t inner chainring. It will work fine, iv e seen 53/34 set-up work perfectly
    Try your current bike on 34*25, which is near enough 36*28 on the new bike. if you struggle then you will need to fit 11-34 to return the same easy gear ratio
    #924395
    fukawitribe
    #924393
    kil0ran
    That’s a pretty big
    That’s a pretty big difference. Try your hardest local climbs using the 26 or 27 cog, as that’s the rough equivalent of 36/28.
    Find out whether the cage on the new bike is SS or GS – if GS you can go up to a 32 cassette (Ultegra 6800) or 34 (R8000), but might need a new chain.
    Do you ever max out 50/11 on descents/flat?
    You might also take a while to adjust to the right cruising combination, I’m very used to 50/34 and found I was falling between combos when I ran a CX 46/36 chainset. Constant swapping of cogs around 18mph average was annoying for a while.
    On the plus side, if you’re handy with a spanner all this is changeable for not much outlay. Sell/swap the group and fit the bits yourself, couple of hours work tops.
    #924391
    rdmp2
    How often do you use your
    How often do you use your current lowest gear? Try going up the hills in the next lowest and see how that feels. Plenty of online gear charts (Google html gear calculator) for my preferred. New ultegra can take 34 tooth cassette so swap cassette, derailleur and chain and you’re nearly back where you were for ~£100
