Recommend me some road disc wheels.
  • This topic has 13 replies, 8 voices, and was last updated 10 years ago by Boombang.
  • #26495
    velochris
    Must be….
    Min 17mm internal width
    Centre lock hubs
    12mm thru axles and 142 rear old.
    For winter so no need for lightweight fancy stuff.
  • #882075
    Boombang
    Just to add when I had a
    Just to add when I had a warranty claim on the oem wheels on the bike, the store lent me Hunt 4 season discs.
    They were lighter off the bike but fitted I genuinely can’t tell the difference between the Hunts and the DT swiss.
    #882073
    Boombang
    My wishlist was the same for
    My wishlist was the same for my CX bike – use it for gravel, mud and winter road.
    DT Swiss R24 Spline disc now doing the job. £200 a set from Tweeks and came with all axle adaptors you could ever want plus tubeless bits. CL rotors standard but also has adaptors.
    They aren’t that light but zero flex and after a few hundred km of very rough riding still nicely round.
    Mighty impressed for the money, be interested to see how they do very long term.
    Only negative is alloy nipples, I’ve never had issues but have read about brass being better as do not corrode.
    #882071
    Johnnyvee
    I was looking for the same
    I was looking for the same and am still looking.
    Kinesis crosslight CX disc HD seem reasonable and also come with,  I believe,  end caps and adaptors.
    Bit heavier than the Novatech but they have brass nipples and seem very well made. Wynstanleys have then at a good price..
    May pull the trigger on these myself as for the money they seem the best deal.
    #882069
    kev-s
    If you can do without centre
    If you can do without centre lock rotors then Novatech cxd wheels are a good choice
    They have various axles and end caps and the rear can be run as 135mm or 145mm
    Tubeless ready too
    Weigh in at around 1500 grams and cost under £350
    Had mine for over a year now and have done 5000 all weather miles and have been faultless
    http://road.cc/content/review/121253-novatec-cxd-aluminium-clincher-wheelset
    Full specs here
    http://novatecusa.net/project/cxd/
    #882067
    velochris
    mrml wrote:
    mrml wrote:
    CXR94Di2 wrote:
    142mm is a MTB size hub.  135MM for disc brake road wheels
    I have used Just Riding Along from Sheffiled to make custom wheels. The world is your oyster for choice
    Lots of cross and gravel bikes have 142mm rear spacing.  E.g. Specialized Crux, Jamis Renegade, Rose Xeon CDX…
    Correct.
    Canyon Endurance, Giant Defy and my Cube all have 142 so think more options will be available soon.
    #882065
    mrml
    #882063
    CXR94Di2
    #882061
    mrml
    I bought a set of DT Swiss RR
    I bought a set of DT Swiss RR 21 DICUT db wheels for running 28mm road tyres on my adventure bike, and they are great.  Tubeless ready, lightweight, and they come with a full set of end caps for adapting to thru-axles or QR dropouts.  Look good too.
    I also have a set of American Classic 29 MTB Race wheels for my 40mm gravel tyres, but you might not need anything that wide.  In any case they have 6-bolt hubs and a 15mm thru axle at the front (not sure if that can be adapted).
    #882059
    Dicklexic
    guyrwood wrote:
    You might in for a tough search. AFAIK, most disc road bike have the standard 135mm rear hub spacing.
    Several brands (including HUNT mentioned above…ahem!) are now shipping with hubs which can be adapted using different end caps.
    #882057
    Dicklexic
    +1 for Hunt Wheels.
    +1 for Hunt Wheels.
    I’ve been running a pair of Hunt Mason 4 Season Disc since April last year and they have been fantastic. Great quality, superb ride feel, tubeless compatible, very light considering how durable they are and at a great price. They are designed for use in all weathers so cope with winter conditions no problem, with no sign of corrosion on mine, and bearings still smooth. Mine have been used on the road in all conditions, have done some mixed road/gravel events and have also seen service on my CX bike for races. A friend has since bought the gravel version which are even tougher for a small weight penalty.
    #882055
    StraelGuy
    #882053
    velochris
    Sorry, meant the thru axle
    Sorry, meant the thru axle length.
    #882051
    StraelGuy
    Not sure what you mean by
    Not sure what you mean by ‘142 rear old’ but have you had a look on the Hunt Wheels website? I’ve got a pair on both of my bikes (4 Season disc on my summer bike and the cheaper winter rim brake wheels on my winter bike) and I’m really pleased with them.
