- This topic has 16 replies, 14 voices, and was last updated 7 years, 7 months ago by
evans1001.
May 10, 2016 at 1:50 pm #25707
backflipbedlem
Hi All,
So recently after about 50kms I’ve started to get some outside knee pain.
Over the years I’ve managed to adjust my cleats, saddle height etc to compensate for different knee pains, as they are generally caused by a bad bike fit.
Now from what I’ve read and my handy little chart that I have, to fix outside knee pain you move your foot out or move your cleat in. This is where my problems arise, I have moved my cleat in as far as I can.
Does anyone know if there are any spacers you can get to push the pedal out a bit to maybe help alleviate the pain?
Or if there is anything else that I could do!
Thanks in advance guys!
evans1001
I had excactly the same issue
I had excactly the same issue. Everything ok up until 35-40miles then pain would arrive on outside of knee and gradualy get worse.
In the end i went to see a proper sports massage guy who informed me that my muscles on that side were all tight.
Had to take a month off the bike and a few visits to the sports massage guy to loosen it all up.
Took it easy for a few weeks building the miles back up along with stretches he gave me to do on a daily basis.
That was in April last year, 7 weeks later I done the Dragon ride (186m) with no issues.
Hope this helps.
Marven.J
same problem with me,adjust
same problem with me,adjust to 20KM now
IanEdward
I went through a lot of knee
I went through a lot of knee pain issues in the last couple of years, with lots of red herrings along the way!
I thought it was cleat position, pronation, seat height, crank length, riding singlespeed etc.
After wasting a lot of money on other solutions, I eventually paid for a bike fit (Dougie Shaw – Edinburgh Bike Fitters). He identified that I was ‘twisted’ in the saddle, and showed me this using a really cool saddle pressure mapper. The twist came from my hips, tight glutes, hip flexors etc. The result was that my right foot was always overreaching, which in turn stretched my left IT more, result was (different) pains in both knees.
He showed me the stretches and strengthening I should be doing, also some tricks with a massage ball, and also general advice on how to ‘hold’ myself on the bike until it became natural (basically being conscious of correcting the twist).
Long story short, I would never have figured this out by myself, and would have continued to waste a lot of time and money fiddling with other solutions.
The other thing I was doing wrong was just riding too much! I was training for a long distance event and was trying to keep to 10-15% extra mileage a week, but was ignoring intensity, e.g. 100km easy is very different from 100km as fast as possible. I didn’t build in any recovery time either, just kept increasing distance week after week. Once I started taking every third or fourth week off, maybe getting a sports massage at the same time, I started feeling a lot better on the bike.
bogbrush wrote:Not sure about spacers but a few years back I had a similar problem when coming back from injury and used inner soles cut in half to change the angle of my foot in the shoe. It seemed to help but it’s difficult to tell if it was that, physio or just healing process that did it. It’s not something I’ve ever seen recommended anywhere else so proceed with caution/advice from someone qualifiedOrthofeet’s shoes were recommended to me by a family member for my back pain problem. I was happy to find a wide selection of shoe choices and colors. I eventually settled on a walking shoe. I was expecting a “break-in” period but I was happy that, after about an hour, the shoes felt good on my feet. When I wear these walking shoes, I experience no heal pain whatsoever. I can highly recommend these shoes to anyone that suffers with back pain!
backflipbedlem
Jimmy Ray Will wrote:I think you’ve answered your question in that last post. You changed your shoes… I’d wager a fiver this will be the reason you are feeling pain.As mentioned somewhere else, I’d expect your new shoes are not compensating for / working with your foot pronation.
Out of interest, which shoes did you used to have, and wht have you moved to?
The shoe change may be the reason for the start of pain, but it may not be the cause. The pain is caused because your knee isn’t tracking properly. There are loads of reasons why this is.
So I had a cheap pair of Muddyfox shoes previously, served their purpose, and moved onto a set of Planet X 365 shoes.
http://www.planetx.co.uk/i/q/SHPXNYROS/planet-x-365x-composite-road-shoe
Still Using SPD-SL
Jimmy Ray Will
Also, I’m not a massive fan of diagnosed ITB problems… yes they exist, but they are often just a symptom of something else happening further up the chain.
Glute engagement, hip tracking are two big reasons why cyclist feel pain where you are highlighting.
Do some research on glute engagement exercises, do these for a couple of days, and assuming the knee symptoms have eased off the bike, go out on the bike and see if the pain returns.
I’ve more or less stopped stretching over the past two years, preferring to work on muscle engagement and core strength exercises to ensure muscles are working properly. Touch wood it works for now.
I didn’t ask what pedals you were using? Moving to SPD -SL pedals have helped me avoid pain.
backflipbedlem
Cheers for all your feedback
Cheers for all your feedback guys!
I never used to get the pain, but then I changed a few things at once, which was probably a bit foolish.
I got some new shoes, and new cleats, tried to match up the position as best I could.
And also got a new saddle. again tried to match it up.
I think next I’ll ry and rotate my toe out a bit first, see how theat gets me.
Then might try adjusting saddle height slightly, but I think that it is in wuite a good spot already.
Maybe drop it down a tad.
Thanks again guys!
StraelGuy
I had a really bad do with
I had a really bad do with outer knee pain for a few months last spring – felt like someone sticking a hot screw driver into the joint and grinding it around. I eventually solved it by lowering my seat an inch or so (new bike) which helped but the thing I think really sorted it was doing some hard quad stretches – the ones where you stand on one leg and bend the other one up behind you and grab the foot and pull hard and really stretch the quad muscles. My knee’s been fine since, touch wood.
nadsta
notfastenough wrote:If you afford it, get a bike fit. Where are you? I can recommend two in the north-west of England.If you can’t stretch to that right now, video yourself pedalling on a turbo (from directly behind or in front), and post it on here. You’ll get a bunch of good suggestions. And we’ll laugh at the dodgy curtains in the background!
Posting a video is good advice-although I ride with 2 guys who have terrible knee and ankle motion on just one side only but suffer no pain -yet can ride to Cat 2 standard! So what may look weird may not be painful and vice versa- but a good place to start. As is having someone follow you as you cycle and compare your l/r knee motion
I have no medical background, just recent knee surgery, but I’ve learnt a little along the way via physios and surgeons.
It might be an issue that stems from somewhere else eg. not recruiting your glutes (as someone else has mentioned) which can cause quad over compensation, ITB syndrome and knee tracking issues. Call this a technique problem and you can retrain your brain and muscle to fix this with squats etc as previously advised . Look up glute exercises and proprioception
It it could be due to knee trauma. Have you twisted the knee in an accident for example?
Or it could be a degenerative knee, possibly exacerbated by bad technique or set up, lots of rugby etc
Or it could just be a physiological difference that is more obvious on the bike after a few miles, different leg length, a misaligned hip or spine.
if you’ve reached the limit of your equipment adjustment it’s definitely it time to talk to a very cycling specific Physio or Osteo . The Octopus Clinic in London has physios who race crits/tris etc. Or a bike fit studio that really know their stuff. Good luck
it could be
notfastenough
therevokid
foot in/out isn’t always the
foot in/out isn’t always the cause of lateral pains.
foot rotation can be the cause too …
http://www.bikeradar.com/gear/article/take-care-of-your-knees-part-2-17445/
Fish_n_Chips
How is your I.T. band
How is your I.T. band/flexibility?
I would see a physio first for a diagnosis and then sort out your ride position with a pro-fit.
HalfWheeler
It might be IT band syndrome.
It might be IT band syndrome. Mucking about with cleats and pedals may no longer help and it’ll take something more fundamental. My own case of ITBS started out like that, pain after 30-40 miles. That number came down and down until there was pain after a few miles and for hours and even days after a bike ride.
There’s loads of stuff you can google for ITBS. They all broadly recommend the same thing; activate and strengthen your glutes. Stretching your ITB is more problematic. Some say do it, others say don’t bother, it’s impossible.
My advice would be to keep an eye on when the pain starts. If that number of miles starts to come down see a physio, preferably one that’s a cyclist. An intial appt will cost £40 but they can do all sorts of tests (Obers test, Nobles test, etc) as well as take a detailed history (crucial) to see if you have ITBS . If it’s confirmed then you’ll know where to go. Nothing worse than flailing about on your own trying to figure out what to do (let me tell you).
Good luck.
Scottish Scrutineer
I have a similar problem
I have a similar problem after about 40 miles. It was pain below the knee on the outside and was diagnosed as a tight ITB. Once it progressed on a ride, my knee was collapsing inwards towards the top tube and I felt I was losing power in that leg. It was also very painful.
I completed the Etape Loch Ness a couple of weeks ago relatively pain free. I did lots of ITB stretches and I also changed my pedals from Shimano M520 SPDs to the A520 Touring SPDs which gave some lateral support and stability to my foot.
Last weekend, I went out on my cross bike, which I’d had a bike fit on and had used for a 100Km Audax, and was in agony after about 40 miles. I hadn’t continued with the streches and I’d also fitted the M520 paedals (as my wife had pinched my M424s that had previously been fitted).
So in summary, try ITB streches and more supportive (wider platform) pedals. That seemed to work for me 🙂
Ive not had it from cycling
Ive not had it from cycling but from running I know I get pain on the outside of the knee (ITB problems) when my knee falls inwards too much. Check when you are cycling if your knee brushes along the top tube or dips in closer than the opposite knee. If so there are exercises you can do to help strengthen the muscles such as squats / one legged squats ensuring that the knee doesnt fall inwards – should stay inline with the foot or out a bit. -
