- This topic has 183 replies, 42 voices, and was last updated 11 years, 3 months ago by
700c.
March 8, 2015 at 11:58 am #23439
ianrobo
Mail on Sunday today has gone big on the TVM scandal of late 1990’s and Sky’s current sports director’s involvement in it, the evidence seems clear. So why is Brailsford denying it ?
http://mobile.nytimes.com/reuters/2015/03/08/sports/cycling/08reuters-cycling-doping-sky.html
Paul J
Obree had a significant aero
Obree had a significant aero advantage, saved him tens of Watts at least.Not quite sure I’d place full confidence in Boardman having been clean, given he’s had at least two different problems that could be related to hormone abuse (indeed, one of his problems is staggeringly rare in fit young men, outside of hormone abuse).
ianrobo wrote:This story says
ianrobo wrote:This story says why people are cynicalfaster than LA ?? you have to query if you can be after what he did
If Quintana matched it would you say the same thing?
In 2013 Froome climbed Ax-3 Domaines quicker than Armstrong had done. Does that mean he must therefore be doping? If only it were that simple.
He was not fastest up Alpe d’Huez in the Tour that year so were all those in front doping?
This article discusses Nibali’s similarly high w/kg climbing in the 2014 Tour, so was he doped?
Boardman and Obree both eclipsed Moser’s (blood-doped) Hour record set at altitude. Boardman later beat records set by Indurain and Rominger. Nicole Cooke raced against and beat dopers. Does that make them all guilty? I’m sure it’s happened in other sports too.
It’s fine (and healthy) to be sceptical and I understand being cynical but your ‘evidence’ doesn’t even qualify as flimsy IMHO.
ianrobo
On a slightly different
On a slightly different tangent it appears Tinkoff may have a new team boss soon, nothing to do of course with an imminent doping report from Denmark of course.Contador may mis his valuable advice.
Paul J
On a bad day on my CAAD10,
On a bad day on my CAAD10, I’m slower at climbing than I have been on good days on an old, late-70s, mid-end steel racer, which weighs nearly 3 kg more. On the flats and even mildly rolling roads, the 70s bike was pretty much as fast as the CAAD10. E.g. on a 7ish minute rolling road segment, the 70s racer was within 24s of the CAAD10 – and I had many more attempts on the CAAD10 to get lucky with the wind. The 70s racer also had a front wheel that likely hadn’t had its front hub regreased in one or two decades!I’ve since got a high-end v early 80s Italian steel race bike, which (amazingly) weighs only 1.2 kg more than the CAAD10. It’ll be interesting to see how it compares to the CAAD10. Shouldn’t be anything in it on the flats, and probably only a little behind on climbs.
Don’t discount the old bikes! 🙂
bashthebox
Reading books about Fignon,
Reading books about Fignon, LeMond etc, they all complained that when the EPO era started in the early 90s, suddenly big classics guys and no-hoper domestiques were climbing with them, sometimes dropping them. Hardly a scientific test, but I reckon you could approximate a big guy (e.g. LA in his pomp) climbing at the same rate as a skinny clean climber today. Probably. Maybe.
It’s really hard to test, isn’t it? Better training, nutrition, tech today vs turbo blood yesterday. The tech one must be a big thing. Totel anecdata, but I’m about 2kph faster on my summer fast bike (extremely lightweight carbon, stiff as fuck race machine) vs my winter bike (fairly lightweight carbon, not as stiff).
fukawitribe
ianrobo wrote:It is possible
ianrobo wrote:It is possible he could do it naturally, that is why I am cynical but not saying they dope. He may have been at peak form then, all going for him etc.However LA had that extra 10% or so from EPO etc in his system to help him.
’99 was when they were getting the jitters about testing and the power was going down (for a bit), he potentially had more distance to cover, as mentioned by others it was not ‘timed’ in any accurate sense, he was probably carrying over 15% more weight on a different bike, different day yadda yadda yadda. I’m cynical about a lot of things – this, not so much.
ianrobo
fukawitribe
ianrobo wrote:good question
ianrobo wrote:good question on weight but Porte in Paris to Nice looked very thin and thinner than before.OK – but to go back to the original point; do you really think that there is something deeply suspicious about a modern, climbing oriented (normally shorter) professional rider, who is local to the climb and can pick when he rides, possibly starting from further down the road and weighing (as near as I can find out) about 10kg less actually going about 65 seconds than Armstrong did in 1999 (when power was, briefly, going down) ?
Must be Mad
Quote:What – that he beat
What – that he beat Chris Froome by abut 1.5% or Lance by about 3% ?
not really. There was no race, no proper timing (LA did his effort well before GPS logging), and they were certainly no riding the same day, so you really cannot use this as evidence for doping.ianrobo
fukawitribe
ianrobo wrote:Armstrong ….
ianrobo wrote:Armstrong …. Some of the power readings people are working out are better than at the height of EPO etc,Do you think we should be cynical at this ?
Maybe, maybe not, there’s clearly still doping going on – any particular example… person, climber, sprinter ?
That said, as you know, it’s not all about raw power output, particularly climbing – how much weight would Armstrong (in 1999) give away to Porte just before the Tour in 2014 do you reckon ?
Edit : BTW, I assume these times are taken from the same place. LA apparently started his timing from a supermarket on the way out of Menton, whilst Sky (not necessarily Richie) start a bit further down the road by the bus stop.
ianrobo
fukawitribe
ianrobo
daddyELVIS
stumps wrote:Info request
<:Pstumps wrote:Info request submitted to WADA and UCI. Just preparing a freedom of info to Sheffield Uni.I’ll wait to hear back then.
