- This topic has 86 replies, 41 voices, and was last updated 11 years, 8 months ago by
sergius.
January 31, 2015 at 5:34 pm #23145
ianrobo
Interesting article – http://cyclingtips.com.au/2015/01/tour-of-flanders-to-trial-disc-brakes/
When choosing my new bike I tried a disc brake one and did not like it. Think they are ugly and I am very comfortable with caliber brakes. However they have to sell us something new and this is it.
Once the pro peloton has them then callipers (except for Campag of course) will slowly die out at the top and medium end bikes.
Is it progress ?
andyp
‘Or you could try and feel
‘Or you could try and feel how hydraulic discs do after a day riding up and down hills, or trails, compared to rim brakes. You clearly haven’t. As I said, ride what you want, just stay off my rear wheel because I don’t want you crashing into me.’Plenty of experience of both hydraulic and cable discs, thanks. Run them on my mountain bikes because of rim wear. Can not see any reason why I would get arm pump, or want disc brakes for any other reason, on a road bike. YMMV. But, you seem to be confused – if you’re the one having trouble stopping, it’s more likely that *you’re* going to crash into someone else than vice versa.
mrmo
Welsh boy wrote:benevans
Welsh boy wrote:benevans wrote:Has anyone had there finger caught in a disc brake rotor? with mass pileups rather frequent in road racing, is this something that should concern the UCI?Has anyone been bitten by a sharp chainring, has anyone caught their finger in rotating spokes, has anyone hit their face/head on the floor? All considerations in bunch crashes so I dont think this is a real worry for the UCI.
And the UCI banned spinergy wheels and spinaci’s because of safety questions. (at least that was the given reason)
And you could say, why add more dangerous things to a bike? isn’t the risk of chainring gouges bad enough, why add the risk of burns into the mix?
Welsh boy
benevans
Has anyone had there finger caught in a disc brake rotor? with mass pileups rather frequent in road racing, is this something that should concern the UCI?Jimmy Ray Will
Unless the UCI change the
Unless the UCI change the rules for racing beforehand, I reckon I’m a good 3 years from using discs. As discs are now, I am not convinced… well I am fully aware of the benefits provided, but I think the hassle that comes with discs currently outweighs these.Moving forward however, once standard affair amongst the pros, these hassles will be ironed out, and I’ll be all over discs.
By hassle, I am specifically talking about the joy of pad corruption, rubbing discs, swift wheel changes, cables that are a ball ache to trim etc etc.
mrmo
arfa wrote:Whatever floats
arfa wrote:Whatever floats your boat but it’s pretty hard to find mountain bikes with calipers these days, so that might tell us something. I can’t wait for hydro discs to become cheaper for the wear and tear wheel savings alone, let alone the consistent braking in grim conditions (which sadly I get to ride in alot this time of year). My rims last less than a year commuting in London, so there’s 300 quid saving straight up. They’re coming anyway and let’s face it, what the pro’s ride is broadly irrelevant for the bulk of us.Quite hard to find a 26″ mtb these days as well. So to say the adoption of discs tells you something is impossible.
Last but one set of wheels on the road bike lasted 5 years, the last set got hit by a car!, that was c8k miles a year. In contrast i wore out a set of Mavic 217sunsets on the mtb in 9 months before i went to Ceramic rims, which after 10 years got replaced by a new bike with disc brakes.
Anyway i am looking forward to the can i bake my contaminated pads in the oven to recover them and the how do i bleed my caliper threads. Not forgetting the classic the compound has fallen off the baking plate thread.
crikey
Probably important to
Probably important to remember that the promotion of disc braked road bikes has very little to do with anything other than a desire to sell you new stuff to replace the stuff you already have and that you hadn’t realised was out-of-date stuff.
See various other things like the stuff regularly reviewed on websites…We’ll end up with ‘better’, for a given value of better…
crikey
I’m not actually as much of a
I’m not actually as much of a retro-grouch as I have been painted, and I accept a number of the advantages of discs.
I’m not fully sold on the frame issue; I think that the reinforcing required for discs will pretty much always mean that frames end up heavier at the rear end and at the fork ends.
The lack of a braking surface is …maybe… an advantage, but you’ll still have a rim which requires sides…
Bigger tyres is not a reasonable reason; I’ve got 35mm tyres on one bike with rim brakes.They are an advantage for some types of riding.
They are not a universal advantage.
As noted above; it’s a relatively small change in the ability to slow down, not a major advance in cycling tech.…they’ve also been available in one form or another for at least a couple of years; so why the big fuss?
crazy-legs
andyp wrote:’I like to be
andyp wrote:’I like to be able to stop, right now, in any condition, without arm cramp.’Sounds as though you need to learn to set brakes up, or do a bit of work on your arms. Or both.
I’ve done the Three Peaks CX 6 times now, all around about the 4hr, 4.10 mark.
Did it this year on a new CX bike with disc brakes.Fastest time by 20 minutes simply cos I was able to let it rip down the hills and know that I could stop without hauling on ineffective mud/rain-soaked cantis and rims all the time to moderate my speed without losing control.
And I wasn’t getting arm or wrist pump.That said, while I appreciate discs and think that they’re a huge forward step for road & CX bikes, I can’t really see what the fuss is about – it’s just a slightly different way of stopping a bike. Don’t want them? Well that’s fairly simple, don’t buy them!
hampstead_bandit
There’s a little more to this
There’s a little more to this than the wheel being slowed down using a different mechanism. After all, a rim brake can be considered a ‘disc’ brake with the rim as a large disc.The real difference is not the brake mechanism itself, but the physical packaging (mounting) of a modern disc brake caliper and rotor, which means industrial designers and engineers at bike companies have many less constraints when designing frame sets and wheel sets. No caliper on the seat stays means the stays can be designed with compliance for rider comfort.
As we saw in mountain biking with the introduction of disc brakes, many companies simply adapted existing frames/forks and laced wheels with disc hubs. It was not uncommon to see bikes with both v-brake and disc brake mounts, these were heavier. It was also not uncommon to see a number of frames suffer failures from the stress the brake caliper placed on the stays. Frames were made heavier to resist the loads.
With time, companies started designing disc specific frame sets and wheel sets with no brake surface. This is where the secondary advantages surfaced of making stronger/lighter/stiffer products, the primary advantage being the improved control and safety of disc braking in bad conditions.
As discs become more widespread on road bikes, the frame sets and wheels will improve.
Many have just adapted existing frames, adding weight to strengthen and resist the stresses of the brake. Its expensive to tool up a new frame.
But, if you do it right you can make a lighter frame – Giant claim their Defy Advanced SL is the lightest road frame they’ve ever made.
Wheels can be weight competitive whilst being much stiffer under load as discs require cross lacing, but weight is reduced in the rim itself. With a caliper brake wheel the braking surface limits design, meaning a reduction in spoke count / rim section to reduce weight often leaving wheels feeling flexible when pushed hard.
You can also run bigger volume tires as there are no brake callipers to foul. I’m running 28c on my bike. Performance rubber in 32c is coming on some 2016 bikes.
jacknorell
crikey wrote:Er, that’s
crikey wrote:Er, that’s Prince retro-grouch actually…Nah, I’m only poking fun; as above I can’t see the point in getting so excited about slowing down, and certainly don’t understand the zeal with which some are expounding the ‘benefits’…
..worse than the Campag Zulus…
I didn’t specifically mean you anyway! But there’s a large group of cyclists (of any denomination) who are basically against anything new.
The dividing line between yay/nay for discs seem to be former MTBers & commuters vs. leisure & sport road riders. I agree that for the latter group, they make less sense.
For me, as I do nearly all my riding among traffic and most miles commuting, discs are vital for control and reliability. Calipers aren’t bad in the dry, but I tend to kit up for the worst I anticipate, not the best.
crikey
Quote: don’t think there’s
don’t think there’s any need for these kind of comments. Just because someone prefers disc brakes, doesn’t mean they’re ‘easily scared’, ‘knobbers’ or ‘nazis’. Let’s keep the discussions focused and civilizedYou are, of course, correct.
I was trying to point out the sense of evangelism which creeps into these kind of discussions, but I did overstep the mark and I apologise.ianrobo
Simon E wrote:[
Even if a newSimon E wrote:[
Even if a new caliper mounting system is established current brake types will still be replaceable if needed. I’m a true tightwad but I’d stump up and pay the extra for disc as the benefits outweigh the initial cost.this is what I weighed up and I concluded at this time the benefits for someone like me was not really worth it.
In other areas like Garmin stuff, PM, type of bike etc I weigh each up as similar.
Reg Molehusband
crikey wrote:
Great oncrikey wrote:
Great on mountain bikes, great for commuters, great for the easily scared, but no big deal in the grand scheme of things.crikey wrote:
Definitely seeing the emergence of a new kind of cycling knobber; ladies and gentlemen, I give you the disc brake Nazi…I don’t think there’s any need for these kind of comments. Just because someone prefers disc brakes, doesn’t mean they’re ‘easily scared’, ‘knobbers’ or ‘nazis’. Let’s keep the discussions focused and civilized.
crikey
Er, that’s Prince
