- This topic has 86 replies, 41 voices, and was last updated 11 years, 8 months ago by
sergius.
January 31, 2015 at 5:34 pm #23145
ianrobo
Interesting article – http://cyclingtips.com.au/2015/01/tour-of-flanders-to-trial-disc-brakes/
When choosing my new bike I tried a disc brake one and did not like it. Think they are ugly and I am very comfortable with caliber brakes. However they have to sell us something new and this is it.
Once the pro peloton has them then callipers (except for Campag of course) will slowly die out at the top and medium end bikes.
Is it progress ?
jacknorell
Shep73 wrote:You can also go
Shep73 wrote:You can also go past the braking power/limits of discs, anyone who may have ridden down the radio mast climb near Marlborough at high speed will know that discs have their limits.Sounds like a descent you’d only do very slowly on rim brakes… just saying.
And Shimano brakes are very easy to bleed, though never had much luck with SRAM / Avid ones…
Shep73
I am just not prepared to
I am just not prepared to spend over £600 for the same bike that is also a kilo heavier, my new bike is for dry weather only so I don’t feel I need discs. just like 29er wheels, it’s another fad to see us buy more stuff we didn’t know we needed.MTB disc brakes have their issues, boiling the oil on long fast descents, pad wear can be high in the right conditions. They will need sanding when they get contaminated with road film, grit and substances. They are not the easiest thing to bleed either.
big mick
Welsh boy wrote:ciderman_100
Welsh boy wrote:ciderman_100 wrote:I think the main thing is that we need a definitive rear spacing measurement and disc diameter otherwise you’ll be locked to certain makers due to differing standard just look at the amount of bb sizesWhy do we need those things standardised? We are locked into a manufacturer in so many other ways already. Have you got Shimano gears? If so, you are locked into their rear mech, shiters and brakes already. Same goes for SRAM and Campag. You pick your component manufacturer and go with their offerings.
Yea but all axle spacing are the same on all those groupsets you’ve listed.All the groupsets fit any/all frames for now hence the need for standard sizings so all frames pair with new disc brake groupsetsjacknorell
mrmo wrote:jacknorell
mrmo wrote:jacknorell wrote:
Yes, Ultegra & Dura-Ace or Record or whatever calipers are pretty good in the dry, no argument. But in the wet, with the grit, with the oil & diesel from road muck on the rims… ugh :(And when the oil and diesel from the roads gets on the discs and into the pads???
I hadn’t thought about this before, but Is there actually a potential issue with pad contamination? I know from experience that it doesn’t take much oil/lube/gt85 to screw up the discs on the mtb. Nothing like the gentle howl of a set of discs, assuming they work at all!, when your riding cheeky trails to ruin the ride.
Actually, yes, there is. There’s a lot less road muck that reach the pads than the entire rim wall though, so a rim brake will be affected so very much more quickly. I’ve had rims go from clean to sliiiiiidey in a few hours 🙁
But oils etc do build up over months and makes the brakes a bit less effective. New pads after a winter seems to be my frequency, they’re getting a bit less power now which with new organic pads will be sorted.
Quick fix is to get some clean wet sand or grit and chuck onto the disc caliper and disc, same as for MTBs.
mrmo
pants
PaulBox wrote:If they are
PaulBox wrote:If they are approved for the pro’s we’ll all be riding them in a few years. This is the reason I currently can’t pull the trigger on a new bike. I’d happily buy another with normal brakes, but will that limit my options on replacement wheels in three years time?Try buying a rim brake wheel for a mtb these days, yes you can, but not any of the best models.
if you can still get square tapered BBs I am sure you will be able to get rimmed brake parts in three years time.
jacknorell
andyp wrote:YMMV. But, you
andyp wrote:YMMV. But, you seem to be confused – if you’re the one having trouble stopping, it’s more likely that *you’re* going to crash into someone else than vice versa.My mileage, or rather stopping distance, doesn’t vary very much at all, that’s the point: It’s quite short and sharp when I need it! Just like you on a MTB.
Look, I remember how shit XT v-brakes were in mud and wet, and those were the good ones. I blew through rims every winter. I don’t miss those times one bit, and I’m not putting up with that shit on a roadbike either if I can avoid it.
Yes, Ultegra & Dura-Ace or Record or whatever calipers are pretty good in the dry, no argument. But in the wet, with the grit, with the oil & diesel from road muck on the rims… ugh 🙁
fukawitribe
Simon E wrote:portec wrote:He
[/quote]Simon E wrote:portec wrote:He only asked a question. No need to resort to personal abuse.That kind of sh*t seriously devalues their contribution to the point where I don’t bother reading anything else they say.
WTF ? As the person who wrote the question can I now ask you what on earth you thought I was getting at and why the fuck you think it was some ‘kind of sh*t’ that ‘seriously devalues [my] contribution’. Frankly I don’t care whether or not you ‘don’t bother reading anything else [I] say’ but it beggars belief you found something in there that let you know my position on discs one way or the other.
Simon E wrote:ianrobo wrote:Who knows in 3/4 years time what the situation will be then ?With that kind of thinking you could put off many purchases, possibly indefinitely, and never experience the benefit.
Even if a new caliper mounting system is established current brake types will still be replaceable if needed. I’m a true tightwad but I’d stump up and pay the extra for disc as the benefits outweigh the initial cost.
So would I, I happen to be pro-disc due to my experiences with them on and off road. I just wanted to get the OP to clarify why they didn’t like discs as I was thinking it had little to do with a realistic test in mixed conditions – which is sort of the point of discs over rim brakes. That said, if they say they just don’t like them, that’s fine too, it’s their bike and their money.
Yorkshie Whippet
Like a few others I thought
Like a few others I thought Roubaix 2016 was going to be the test event. I’ve been told that Shimano can not make enough systems to match demand.As for my preference, I can remember splashing £100’s on new shiny Hope brakes, ten years later still can not get them any better than a properly set up v brake. However the old XT discs are scarely good and miles better. Give it a few years I think on the whole we may no longer have a choice for new bikes it will be either disc or disc. By then any bugs and the standards will have been ironed out.
Until such time, I’ll have to stick with the old tried and tested as I’ve splashed too much cash on a new bike to consider replacing the whole lot again.
PaulBox
Welsh boy
ciderman_100
I think the main thing is that we need a definitive rear spacing measurement and disc diameter otherwise you’ll be locked to certain makers due to differing standard just look at the amount of bb sizespants
My only problem with disc
My only problem with disc brakes is that at the moment they are not compatible with a lot of existing things and costs, but if that wasn’t an issue i’d have disc instantly, everything else have evolved to disc brakes for a reason.therevokid
new stuff, new standard
new stuff, new standard (flat mount !), more profit … it’ll happen, but not on my dole
cheque ;), so deal with it.
I’d love some but as neither of my frames are disc ready then I’m stuck in the dark
ages of rim brakes.big mick
I remember people not wanting
I remember people not wanting STI gears clip in pedals etc but now no one would ride without them.Things change for the better get over it.There not adding things to make the bikes worse.The same thing happened when disc brakes were first used on MTB’s and motorbikes.It will add to unsprung weight to high tech etc.Same story here too.You would’nt buy a MTB or m/cycle with drum brakes. -
