- This topic has 12 replies, 10 voices, and was last updated 6 years, 6 months ago by
roadbikepilgrim.
May 6, 2020 at 6:03 pm #30690
roadbikepilgrim
Hi all,
I have a B’Twin Triban 500SE road bike that is a 60cm (L) frame, and came with a 110 stem as standard. I have ridden it for two years and always have had the sense that I am always a little too far forward on the saddle. I cannot stay for long on my “sit” bones further at the back of the saddle (where I should be) unless I keep my arms long and straight to an unnatural degree. I think I could address this problem with a shorter stem, before I move on to trying a different saddle.
Question is, how short? Will 100mm be little shorter enough to make a difference or will 90mm be just too short? I know that you cannot give the definitive answer, but some of you will have come down in stem size before, and from your general experience with road bikes, what is your gut instinct for the correct size that I need?
Thanks,
roadbikepilgrim
roadbikepilgrim
Hi kil0ran,
Hi kil0ran,
Thanks to you and the others who have responded. It is useful to get the experience of someone who also has a Triban.
I am 185cm or slightly more in height, which according to Decathlon’s website put me on a 60cm frame. The bike was in clearance and there were no more 57 frames left to try. However, the 63 was obviously too big: I could feel strain in my lower back in the store.
I think that the bike is generally an okay size for me. I later measured myself according to Rose Bikes’ guide, which suggested my ideal is 58. This means that I would choose either a 57 or a 59 for Rose, because they do not do a size 58.
I actually have the saddle height near its limit (set to number 3 on the scale of 1 to 20, with the 1-2 markings on the post hidden away in the seat tube) to get the right knee bend, which does not suggest the bike is too big for me. The bike mechanic in the shop started me off with the saddle at 8. No pain, but once I started learning more about bikes, I realised it was too low. Getting the saddle height right transformed my uphill cycling.
The only pain I sometimes have is in the perineal area after a longish ride (ouch). I am pretty sure this is because I am moving too far forwards on the seat to be less stretched out at the front. The seat is perfectly level, by the way. The mountain will not come to Mohamet, so he will have to go to the mountain i.e. I need to get a little closer to the bars with a shorter stem, and keep those sit bones where they should be on the saddle :).
Cheers everybody,
roadbikepilgrim
kil0ran
Back when the 500SE came out
Back when the 500SE came out B’Twin’s sizing was a little odd – their 60cm frame was more like a standard 57, and they also specced quite racy stems. I normally ride a 56/57 with a 100mm stem and found I had to switch from the 110mm my Triban 3 came with to get comfortable.
As others have said, 10mm difference on stem length is noticeable. I had a basic bike fit done due to having some lower back pain on longer rides and the fitter specced a longer stem which sorted it out. Somewhat counter-intuitive but it worked and at least it’s easy/cheap/quick to swap stems
If you’ve got a turbo trainer or someone to hold the bike steady a good rule of thumb is to sit in the saddle with cranks and quarter to three and lean forward. The position you can support with just your lower back/core muscles is the right one, and then it’s a case of placing the bars/hoods at the point where your arms aren’t locked rigid.
Before you make changes to your position measure everything so you can get back to where you were if you go wrong. Given you’re playing with saddle fore/aft and stem length measuring from the tip of the saddle to the split between the stem and the faceplate is a good one to do. You mention you feel like you’re too far forward, that might be a saddle angle thing and easy to experiment with if you have a micro-adjust seatpost. If you make a change make sure you ride it a couple of times before deciding if it’s better or worse, and try to only change one parameter at a time.
Some riders are tolerant of key setup paramaters being in wide range, for me I find I’ve got a very narrow envelope of comfort. My approach without a bike fitter on hand would be to get my legs feeling right in terms of saddle height and fore/aft and then sort out the bars. Just note that it will be individual based on age, flexibility, body symmetry, and historical injuries. There are rules of thumb but they’re just that – they merely get you in the ballpark.
Small moves can make a huge difference. When I first started I was amazed how much faster I was after I’d put the saddle up no more than 10mm.
If you have a good
If you have a good relationship with your LBS, they will have a few different stems sitting about in their workshop, try a few, see what feels best, before you buy the one you really want.
Alternately, buy a cheap second hand one on ebay to see if it feels good, before you invest in the pricey one.
Secret_squirrel
I had exactly this dilemma
I had exactly this dilemma last month but on an endurance bike with quite a race position that left me uncomfortably stretched out. Had the bike for 2 years but finally decided even the relatively minor discomfort was lessening the time I wanted to ride that bike.
Long story short – I dropped 20mm from 90 to 70 and inspite of some trepidation about making the bikes handling more twitchy I haven’t looked back.
The nice thing about stems is that as long as they are removable faceplate designs they are one of the easiest parts to fit and change.
Looks like there’s a few KOPS
Looks like there’s a few KOPS advocates on here, so it’s time for the late, great Sheldon Brown: https://sheldonbrown.com/kops.html (although written by Keith Bontrager)Peted76 – 10cm is way too big an increment.
roadbikepilgrim
Thanks everyone for your
Thanks everyone for your feedback. I shall check the saddle fore/aft position and then start with a 100mm stem and see how it goes.
Yes, a professional bike fit would be nice, but I can afford to buy one stem too many that I shall not use in the end for a fraction of the cost of the fit :).
Cheers,
roadbikepilgrim
peted76
1) You want to have your seat
1) You want to have your seat bones on the wide part of the saddle ideally, that’s literally what it’s there for. Yes the pro’s and the ‘racy types’ will move onto the rivet when they are pushing themselves into the red.. however for the most part that’s not about fit and more about how they are riding at that moment. It’s the wide part of the saddle which is where you ‘fit to’.
2) Check your fore/aft saddle position. With cranks level, lower a plumb bob (tie a 30-inch piece of string to a rock if you don’t have one) from the front of your kneecap to where the pedal spindle connects to the crank arm. If the line falls in front of or behind the spindle, slide your seat forward or back, then recheck.
3) Stem length should come after those two checks. Stems are cheap enough that you can experiment with and there’s always loads for sale on facebook or ebay. Try 10cm increments, 10cm does make a difference.
Without seeing you no-one can
Without seeing you no-one can really say – and there’s no obligation to sit back on the bum-shaped part of the saddle while actually riding (look up the phrase ‘on the rivet’). Before buying a shorter stem though, it’s usually easier just to move the saddle forward by 20mm (or buy a seat post with less setback).
My usual tip for the ‘correct’ reach to the bars is that the tops of the handlebar obscures the front axle. But obviously that depends on how long your arms are compared to your body, etc… all things are variable and a professional bike fit (when possible!) should solve all these issues.
Sit on the bike where you
Sit on the bike where you feel is right, then reach forward to the bars – where do your palms “naturally” land? Try It a few different times. Adjust the stem length accordingly.
Welsh boy
There is no science behind
There is no science behind the knee over spindle guide so see what works for you. I also take issue with Peter’s comments, 10mm will make a huge difference in feel and moving your saddle backwards and forwards is not the way to adjust your reach, saddle position is to do with your leg length, your toso/arm length is adjusted by altering your stem. Get your saddle position fixed first then play around with stem length, you can get stems fron Chainreaction from £6.99 and from PlanetX from £2.00 so shop around, it is not too expensive to make 10mm changes until you are comfortable.
10mm isn’t a big difference
10mm isn’t a big difference in stem lengths, so I’d try a 90mm one.However, I’d be more likely to play with the saddle position first – try moving the saddle forwards and experiment with the height a bit (measure the setup first so you can easily get back to your starting setup). If you don’t have much success with changing your position, then the best bet is to pay for a proper bike fit though I don’t know if they’re still in business at the moment.
Nat Jas Moe – I’ve heard those recommendations before, but although they’re a handy rule of thumb, they don’t take into account different body shapes (e.g. long thigh bones) and flexibility.
Nat Jas Moe
From what I have read
First sit on saddle, cranks at 3 oclock, a plumb line from the front of your knee cap should be in line with the pedal axil.
Now hold the drops and the tops should be in line with front axil.
Apparently.
