- This topic has 4 replies, 3 voices, and was last updated 6 years, 10 months ago by .
Hi, I have Vision team 35 wheels and need to replace the sealed bearings. The problem I have is the axle tightening cup is stuck on the drive side. I can remove the non drive side cup using a 5mm Allen key but not the drive side. This must be removed to access the bearings. The free hub is the screw on type so the axle has to come out to remove the free hub using a 12mm Allen key. Does anyone have a way to get this drive side cup off.
Hope you can help.
