Lower gears for climbing, Shimano 105
  • This topic has 12 replies, 7 voices, and was last updated 6 years ago by 996ducati.
  • #31266
    Huckfinn
    Hi,
    I’ve got some good advice here over a year ago and so here I go again: planning to buy a cx bike from 2016 and slightly hack it. It currently has a Shimano 105 rear/front derailleur. Cassette is an 11speed 11/28 Shimano. Crankset FSA Gossamer Cross, 36/46. Do I have any options for going below the 1:1 ratio?
    Thanks.
  • #973015
    996ducati
    Get yourself a Wolftooth and
    Get yourself a Wolftooth and use a medium cage 105. Got a 36T SRAM WiFli sprocket fitted to the rear of my Shimano set up, running well.
    #973013
    I see it in the “Picture of
    I see it in the “Picture of my Bike” thread,  you wont lose it with bar tape that colour, ha ha.. i posted mine in there only this weekend just gone.   I use the rear rack mainly but i do have the front racks hanging in the garage ready..!!    Cheers…
    #973011
    Rich_cb
    Yep.
    Yep.
    You should be able to switch that model rear derailleur for yours quite easily.
    #973009
    I think I’ve used it twice,
    I think I’ve used it twice, and only when loaded with 50+ lb of gear. It is a touring bike.
    #973007
    Chris Hayes
    It’ll mean major surgery: a
    It’ll mean major surgery: a 34 inner ring, a 34 cassette and a long-cage derailleur – or a wolf tooth hanger to lengthen it. You should be able to get up most things on that…
    #973005
    Huckfinn
    Really?
    Really?
    Any idea on how to locate it?
    PS: is this the one?:
    https://road.cc/content/feature/how-get-ultra-low-gearing-gravel-bike-adventures-246424
    #973003
    Rich_cb
    Yes.
    Yes.
    There’s an article on road.cc about setting that up to run something like 11-40.
    #973001
    Huckfinn
    #972999
    That’s a 0.70 ratio, WOW,
    That’s a 0.70 ratio, WOW, that must be cool.? I love my Cinelli at 0.75. Huckfinn hope you get it below….
    #972997
    Rich_cb
    The old 105 derailleur
    The old 105 derailleur probably won’t go too far past its published capacity but if you get yourself a Wolftooth Roadlink or something similar you should be able to fit a far bigger cassette.
    Alternatively switch out for a new 105/grx/ultegra Rx deraillieur and you should be able to get 11-40 working easily without too much bother.
    #972995
    Steve K
    There was an article on here
    There was an article on here saying you could run 11-40 on 11-speed 105. Personally, I’ve got a 50-34 compact and 11-34 11-speed 105, which generally does me fine (and I’m rubbish at climbing 🙂 )
    #972993
    My Jamis touring bike came
    My Jamis touring bike came with 105, circa 2013.
    24/32/42 front triple.
    12-30 10-spd cassette, changed to 11-34 when it wore out, no shifting issues. 24-34 is good for vertical walls or pulling tree stumps.
