- This topic has 22 replies, 17 voices, and was last updated 12 years, 11 months ago by
mattsccm.
November 21, 2013 at 4:28 pm #20243
Neil753
Just wondering how cyclists feel about this, so any opinions would be welcome.
I’m sure that ASLs were originally invisaged as an aid for cyclists turning right, and not to facilitate a “massed start” for those cyclists intending to go staight on, all jockying for position, sometimes across the entire width of the ASL.
So, I suggest a visible division within the ASL zone, encouraging cyclists to only place themselves in front of another vehicle if they intend to turn right, but for all other cyclists to remain near the kerb, and no more than two abreast.
The aim would be to enable right turning cyclists to be well to the front of any lorry, and to help minimise conflict between cyclists and other vehicles when travelling straight ahead.
mattsccm
The ones I have seen don’t
The ones I have seen don’t give much time. You need to be across the junction to not be venerable. ASL’s don’t half wind up a lot of car drivers and they race to get past.
I pass one daily. Its has some stupid little lane up the LHS which encourages people to filter rather than wit and then they go straight on, ignoring the left turning cars.
It struck me that these cycle lanes should take a more gradual corner with a sodding great big post between the bike lane and the car lane. A nice right angle for cars etc would slow their turn whereas a more gentle curve would allow cycles to turn faster and easier.
Would solve rights I know but one step at a time.harrybav
Turns out ASLs are good for
Turns out ASLs are good for pedestrian safety too. There are stats online, on wikipedia ASL page iirc.a.jumper
Adding a 10 seconds cycles
Adding a 10 seconds cycles only phase would add 10seconds to the cycle, not 40. Simultaneous greens from all directions works:look at the Netherlands!mattsccm
I have always assumed that
I have always assumed that they are aimed at reducing the number of cyclist by putting them in front of a mass of impatient traffic. Unless cycles have a different set of lights even more mods won’t help.
I cannot believe that anyone will filter, cycle lanes excepted up the left of vehicles.
Asking to be killed. Why not wait?
antigee
My opinion is that a lot of
My opinion is that a lot of ASL’s are badly designed and my gut reaction is that they create as many dangerous situations as they fix – some well designed ASL’s do work and my impression is that these are ones where the entry lane is wide and not always to the left and approaching vehicle speeds are relatively low – narrow feeder cycle lanes are only formalising riding that shouldn’t be encouraged – some cyclists seem to insist on the right to filter in queues irrespective of the danger – of course that ignores the real issue which is reducing vehicle volumes and speed – less vehicles = less issues at junctions – lower speed limits in built up areas = less conflict at junctions – trying to deal with continued increases in vehicle volumes, maintaining vehicle flow aka speed and dealing with increased cyclist numbers without changing vehicle use patterns is a no winMy anecdotal experiences with a couple of junctions that have had early green lights recently added for cyclists is that they reinforce bad driver behaviour – after the cycle green light has finished drivers seem to believe that it is “their turn, at their speed” and that cyclists still crossing or wanting to cross with the traffic flow no longer have normal traffic rights
Goldfever4
No!! ASL is fundamental for
No!! ASL is fundamental for slower cyclists getting away safely, whether going straight, left or right at the junction. It prevents a car moving alongside you when you are moving slowly and therefore least stable. (i.e. clipping in, or a slow unsteady rider getting up to speed).Personally, I’d say splitting the box into L/S and R halves may help prevent cyclists moving too far across the box and therefore in the way of the traffic behind, but that’s not practicable when you consider overflow of cyclists.
Staggered lights aren’t ideal either. 10 full seconds at every junction?! Not a chance of that being accepted by other road users. A great idea for busy times at particular junctions (e.g. cycle superhighway routes in London at rush hour), but any other time of day would be stupid and most junctions don’t need it. By that point it’s so complicated that it’s confusing and counter-productive.
horizontal dropout
I believe ASL’s amongst other
I believe ASL’s amongst other things were intended to prevent left hooks by putting the cyclist ahead of left turning vehicles.I would like to see:
1) entry for cyclists at any point, ie cyclists may cross the first stop line to enter the box even when the light is red.
2) no entry to the box for drivers unless your exit is clear – like yellow hatched boxes.
3) enforcement
4) (expensive) move motor vehicle traffic lights back to the first stop line with cycle lights at the front.
[5) low front lorry cabs, like buses, to get rid of the killer blind spot in front that is the same size as the ASZ]Neil753
jova54 wrote:I’ve recently
jova54 wrote:I’ve recently done a trials session at TRL on junctions with ASLs and cycle traffic lights.During the session, which consisted of about 30 cyclists plus cars, they modified the phasing of the cycle lights and main traffic lights so that cyclists were not only in front on the ASL but actually got up to 10 seconds head start on the motorised traffic.
Agree with Northstar that a change to the Dutch style road layout would be better but intelligent introduction of cycle traffic lights giving an advantage when moving off over motorised traffic would seem a good reasonable cost interim alternative. The physical structure, electrical supply and control mechanisms are all in place, all that’s required is the additional cycle specific lights and changes to the software.
That’s very interesting. Ten seconds would be more than enough time for cyclists to get ahead and sort themselves out. I can see some disadvantages, however.
1. Another ten seconds effectively reduces traffic flow, potentially launching a thousand punishment passes as drivers see their delays as a result of unfair prioritisation. We must remember that the delay for each driver would be 10 seconds times however many phases there were at each junction. In other words, a four way junction would create a 40 second delay for everyone passing through that junction, including cyclists, many of whom demonstrate an inability to wait currently as it is.
2. Once cyclists on red become familiar with the ten second “car free window”, we would be likely to see more RLJs.
3. There is some evidence of confusion, amongst both drivers and cyclists, when faced with this type of staggered start junction control.
4. Cyclists would be encouraged to squeeze up the inside of hgvs, to fill the gap vacated by those cyclists already moving forward.
5. Pedestrians would be more likely to cross the road, against the flow of traffic, if they were expected to wait ten seconds longer than they do now.
6. There is a risk that frail or partially sighted pedestrians may interpret stationary vehicles as a sign that they may cross, and collide with a fast moving cyclist in the feeder lane.
7. I suspect such infrastructure would be much more expensive than adding some paint within the ASL zone, money that might be better spent elsewhere within the cycling infrastructure budget.
jova54
Neil753
@ northstar – I agree that
@ northstar – I agree that would be better in the longer term, but I was thinking about any temporary improvements we could make right now, that wouldn’t cost much, and might have the effect of cutting the KSI rate.@ Jack Osbourne snr – I agree that few cyclists know how to use ASLs. I also agree that they should be removed eventually but, while they’re here, there may be some lives to be saved. When I’m in my lorry, and sitting directly behind the ASL zone, the antics of some cyclists are almost comical, if it weren’t so serious: there’s often lots of jostling for position, with cyclists setting off at different speeds and, crucially, sometimes there are cyclists who want to go straight ahead positioned to the right of cyclists who want to turn right. Even though the paint would only last a few weeks, one chap with a spraycan and a couple of templates could get make a junction safer in about 60 seconds flat.
@PJ McNally – You’ve just illustrated my point. You’re jockying for position within the ASL zone, and refer to slower cyclists as idiots, even though those other cyclists are also jockying for position, and they probably regard other cyclists as idiots too. And all this is happening directly in the path of drivers who are probably looking at the traffic light, rather than the cyclists in front of them. Barking! This is exactly why I’m suggesting some extra demarcation within the ASL zone.
@ Argos74 – I agree with you. It is what I do too. My suggestion is really for those cyclists who are less experienced, or have a propensity to squeeze into an already crowded ASL zone. If the proposed demarcation line was in line with, and visible from, the feeder lane, it would help reduce the instances of cyclists stuck in that feeder lane as the traffic starts to move. My suggestion would be that there would be space for just four cyclists in the “straight ahead” part of the ASL zone (ie 2×2), and cyclists behind them should hold back to avoid being on the inside of an hgv. My proposal has the potential to substantially reduce KSIs at junctions, but it needs cyclists to adopt a more concilliatory approach to the ASL, for the common good.
@ teaboy – I share your long term view, but to radically alter a junction can cost several million pounds. My proposal (as an interim measure) would help cut KSIs immediately, and cost just a few pounds per junction.
@ northstar – That would be great, but until then we have to see what else we can do to cut the appalling KSI rate at junctions, which is where many incidents occur.
@ Colin Peyresourde – I agree. ASLs are responsible for more examples of poor cycling than anything else, but I suspect they are here to stay for a while. But if we can cut the KSI rate, even by one, simply by adding a little paint, then we should be doing it, shouldn’t we?
Colin Peyresourde
NIrish wrote:
1. where do youNIrish wrote:1. where do you position yourself when some are in both lanes, not yet committed to one or other but indicating left. often get the cheeky one who cuts you up to get in.
2. the cheekier ones who see this as an opportunity to double out before the bus lane resumes. Bit stuck if you sit on the white line between them thinking they are going left.
Not sure if you are talking about static traffic or not. But if the car in front is signalling left and slowing, pull into primary behind it, so that cars are not tempted to overtake, you and know that you are going straight-on (and it is only the traffic which is slowing you). If it is a HGV I would be tempted to pull to the right so that you can see his wing-mirror and he see you. But reduce your speed to go with the traffic that is in front is the main thing – give yourself time and space to pull the manoeuvre that is safest for you.
Colin Peyresourde
ASLs just encourage poor road
ASLs just encourage poor road behaviour by cyclists desperate to get into them. I don’t really like them much and you can still pop into blind spots on HGVs even when you are in front of them (and it is likely that more than few bad accidents have happened that way).I don’t think they really do the job they intended, or improve anything. Would love for someone to pull up the stats that either prove a safety improvement from them or not. But I think they are really a cheap half-way house that looks like they are a help when they are not (e.g. cycle superhighways).
NIrish
I must say ASL appeared out
I must say ASL appeared out of nowhere, certainly I never heard of any legislation until I heard about cameras in LDN snapping the encroachers. I’ll be honest if the light is Red and im a bit a way ill cruise up the inside and get my prime spot ‘center’ in the ASL. If other cyclists are there I tend to shadow the one that looks strongest (often get caught out by a rogue MTB rider). On the other hand at junctions where there is no ASL i will stay inline with traffic.BUT
The bigger challenge I find in Glasgow is buslanes that are interupted by left turns. Motorists pull in early and sit all over a big thick white line, including the boys in blue (check it on youtube in Edinburgh). This poses two problems:
northstar
Quote:Keep them until we can
Keep them until we can have proper Dutch infrastructure.You are in for a long wait…
northstar
northstar wrote:Get rid of
northstar wrote:Get rid of them and put in exact same paths they have in the netherlands, problem solved.Again for the people who are myopic.
