- This topic has 21 replies, 9 voices, and was last updated 12 years, 12 months ago by
servicemycycle.
October 30, 2013 at 10:03 pm #20132
FreeTrainerSoftware
We put this little program together for our new high end (expensive) trainer, figured we could also give its software away as its less then 2MB works with Ant+ & Wahoo Kickr/Computrainer. does the same stuff as trainer road for free. Also has a Video route player, virtual speed, tcx export, watts derived from power curve of 100s different trainers. No installation needed….If your looking at a wall this winter & have a Ant+ speed sensor then this will at least get you some numbers to look at!
Would love any feedback no matter how bad & offending!
servicemycycle
Cool Thank you!!
Cool Thank you!!kostya416
servicemycycle wrote:Am I
servicemycycle wrote:Am I right in thinking this will communicate with my garmin speed and cadance sensor if I have a ANT+ USB stick?Thanks John
Yes
servicemycycle
FreeTrainerSoftware
Software update now has real
Software update now has real time Cadence & heart rate data curves along with the watts that was in already. Added a countdown timer for each interval segment also 😉Now busy with adding multiplayer & ability to share workouts
FreeTrainerSoftware
We are fixing up the UI for
We are fixing up the UI for the ride menu right now, then its adding the ability to ride against a saved tcx file, sharing performances & workouts in the next few weeks. Will probably leave the workout part alone for a while as its free & generates us nothing. With the Lynx trainer its much better to ride a simulated grade as there is full on inertia from its 2HP motor. If there was any coaches out there that wanted to donate some good workouts we can add to the workout generator section it would be the same as trainer Road for free.What do you do when on the trainer if your only looking at the numbers rather then a full blown ride simulation?
And please also buy a ride & try this part out, you dont have to have a Kickr we calculate the frame rate/visible speed from your watts so you have to hammer the hills hard to stop it becoming a slide show. Its a great way to kill some trainer time in a way that does not feel like watching paint dry. I recommend Flanders if you dont have the Kickr or Computrainer as the hills are very steep & you have to hit 53×12 & give everything to get the speed into double figures.. but your time up the Koppenberg or Paterberg will be close to real life (if it was smooth tarmac)
FreeTrainerSoftware
flobble wrote:A few
flobble wrote:A few thoughts:I love the idea of overlaying power output on a training profile – an easy to understand, accessible view of a training session using equipment I already have. Brilliant – thank-you.
If you’re going to give away the software, why not launch it as an open source project and bring the massed talents of the world’s cycling programmers to bear on it? It could rapidly become the best piece of power-based training software out there.
Similarly, I’d be willing to bet there are enough people with trainers and power meters who would happily submit their data and give you calibration information for the most popularly used non-power trainers. I’d certainly be happy to do this.
Not sure how this helps you sell Lynx trainers, but I’m delighted you’ve gone this far. Great stuff.
Thanks, Our software will grow very fast & im confident that if its not already the best it will be by next year. We don’t really need more programmers, really we just need a really good idea of what you want or need when training inside. We have only been busy with this for a few months. If its different display metrics or something then we can make them or give you the tools to make them. Right now the software is really small, fast & tidy, the last thing we want is a whole bunch of different programmers screwing with it 😉
We have a list of hundreds of different trainers & their power curves built into the exe (in settings menu – bottom right click the button under the trainer curve). If you add your own speed watts for a trainer thats not listed just do a print screen of your numbers & send it to us & we will add to our list.
FreeTrainerSoftware
Gizmo_ wrote:Forgive me the
Gizmo_ wrote:Forgive me the ignorance here, but I’m thinking of buying one of the simple Minoura B60 trainers. Am I right in thinking that I’d just need this software on my laptop plus an ANT+ cadence sensor?The trainer has variable resistance – I see from one of the screenshots that the software has pre-programmed data on resistance levels for some trainers, is the Minoura included? How does the bike’s gearing affect this?
Also I don’t quite understand how it works – are laptops ANT+ compatible? Does the video play at a rate equivalent to the speed I’m riding (as dictated by cadence * (gearing vs resistance) )
We have a whole bunch of Minoura trainers listed but I dont see the B60, maybe the name is different or its a new model? If you know someone with a power meter you can borrow you could easy add your own custom trainer. by selecting “user defined trainer” & just filling in the watts you see at a few different speeds. The software will draw a plot & fill in the gaps.
The idea once you have a virtual power curve selected is to pick a single resistance level & then use the gears of your bike to increase torque if you need it, like on a hill for example you could stick it on the 12 to get the torque high. We use virtual speed that uses well known maths to calculate the speed from the road grade watts weight/mass of the rider. So if you hit say the Koppenberg which the cross is doing today your displayed speed & frame rate will drop to a crawl & thats the moment to fight against logic & chuck it in the 12 & give it some effort if only to get the frame rate a bit faster! Over the top of the hill the frame rate will increase with the speed, but you get the speed with less effort so you can you reduce the gears & recover/spin. If you have our Lynx, KickR or computrainer then it will increase/decrease the grade or resistance level to replicate the hills better. As more high end trainer go open we can add them to the list.
If you have a Ant+ Speed or optionally a cadence/HR/Power meter sensor then you just need a Ant+ USB dongle from Garmin, Tacx, Bryton or Wahoo. Click the exe go to user settings & on the top right you will see anything you have inside range of the Ant+ & your laptop. You can click “learn” & then “Save” if you wanted to be sure these are linked, but really it will just work even without doing this. Just go near the software with a Ant+ HRS strap & a small box in will go green & you will see your heart rate in the settings etc.
Remember also that once you click that exe the first time a Data folder is created next to the exe. After your ride is finished all your data is exported into a Garmin tcx file which you can use in just about every training software.
flobble
A few thoughts:
I love the
morethansonglyrics
You’ll need to make sure the
You’ll need to make sure the trainer is compatable with any software you need.
Maybe these guys have got a list, trainerroad certainly have one.You’ll deffo need a usb ant+ stick which takes the data from your sensor and sends it to the PC rather than Garmin or whatever else.
morethansonglyrics
Can try this on the GFs
Can try this on the GFs laptopa actually. Score.FreeTrainerSoftware
giobox
giobox wrote:morethansonglyrics wrote:Would go nuts for this with mac compatability. Currently considering a trainerroad sub.I’m using trainerroad and reckon its worth the subscription price for their virtual power feature alone. I recently borrowed a PowerTap to compare the virtual power numbers and was shocked how close it gets if you have one of the turbo trainers they have a power curve for. Power based training for around £60 a year is a bargain, vs minimum £600 spend on a full blown power meter.
Well if you have windows & our little exe file you actually have spot on the same virtual power as trainer road for £0.00 / month for ever! We need to add some example workouts but you can easily make your own in seconds. We are adding the ability to share workouts also, so it could be a cool tool for coaches
FreeTrainerSoftware
HTTP404 wrote:I’ve pointed to
HTTP404 wrote:I’ve pointed to the vlrr folder.
I can see all the rides listed.
And I can see the two demo vlrr files.I click on a demo vlrr file.
The screen is still black.
I click start ride.
The four buttons and the new ride button are displayed at the top.
Below these – the screen is still black.
I start to ride and the four buttons and new ride button disappear to display a black screen.
I stop the ride and the buttons reappear, but no video is played and no sound is ever output.Sounds like you need to update your wmv codec. if you cant play the Demo videos you either have a corrupted codec or an old version of windows media player, You could try updating your wmv codecs? http://www.microsoft.com/en-us/download/details.aspx?id=507
kostya416
morethansonglyrics
You can run it on Mac using bootcampgiobox
morethansonglyrics
