- This topic has 52 replies, 25 voices, and was last updated 7 years, 6 months ago by
CXR94Di2.
November 29, 2018 at 9:02 am #29169
cycle.london
Over the past three months, I’ve cycled maybe once per week, maybe two weeks out of each month. My job allows me to work from home pretty much whenever I wish, and I’ve been abusing that privilege.
The issue is exacerbated by my wife’s hours. If I cycle in, I’m out of bed at five and on the road by 05:15, and so usually back home by 4 PM, whereas she doesn’t even finish work until about seven. The time she gets to the station, home by train and I drive to pick her up, we’re usually both home by about 8:30 PM, and by nine, I’m usually in bed. So if I want to spend any time with her, I’ll hang on until about 11 before going to bed, which effectually f**ks my chances of getting up at five the next morning. I could cycle in later, but London drivers are insane enough at 5:30 in the morning. At seven or eight, it’s downright impossible. Plus, the later in the morning, the more cycle commuters there are, many of whom have as much an idea of ‘road sense’ as I do of quantum physics.
Let me just throw in an edit here to say that I’m not blaming my wife. I’m the lazy one, not her.
So I’m sitting in front of the Mac at home now, ‘working’ from home but of course am on Facebook. My boss doesn’t really care, as despite everything, I do get the job done. But this is having a detrimental effect on my mental health.
How do I force myself to get up and out in the mornings?
CXR94Di2
Once you’ve got one side of
Once you’ve got one side of the tyre on the rim, inner tube inside just slightly inflated to give a little shape. Next step is to start levering other bead on taking care not to nip inner tube. The last bit is always awkward, but made much easier, by going all the way round the rim and pinching the beads together. What this does is, it places the tyre on the smallest diameter of the wheel. Allowing the last 6″ inches of tyre to be levered into place. Keep pressing tyre regularly together for the last bit. It makes all the difference. Infact you don’t even need levers if you can keep tyre centered most of the time. Bit of thumb strength 🙂
cycle.london
Duncann wrote:cycle.london wrote:Found the blighter:I’m pretty disappointed that the tyre didn’t stand up to that, but anyway, the new tube is in (and I scanned the rest of the tyre from a distance of about two inches to see if there were any other little ba5tards that were going to surprise me). Of course, there was the standard twenty minutes of heaving and straining to get the rim back on (and I have one of those ‘wishbone’ type levers, can’t remember what it’s called), along with the obligatory blood bruise on the heel of my right hand. Ah, well. Now’s to pump it up and hope that I’ve not pinched the bloody tube. 😀
Just a slight caution from experience that being convinced you’ve found the source of a recurrent puncture doesn’t always have the ending you expect! Give it a couple of rides before claiming victory!
Probably lots of us have pinched new tubes with tyre levers… I’ve found that kneading the tyre down into the well of the rim, all the way around, helps things hugely. It basically reduces the size of the circle it has to stretch around. I almost never need levers to fit a tyre now.
Can’t claim credit for this technique – I think someone send me a Spa Cycles video of someone fitting a Marathon Plus tyre (famously hard-to-fit when new). There’ll be others.
Everyone tells me it’s easy. The very nice bloke at my LBS once, after I’d brought him a wheel on which it was utterly impossible to get the tyre back on, I asked him to show me how he did.
‘Sure,’ he said.
Pop .. pop .. pop.
Job done. Five seconds, tops.
Thing is, I can do it. I can use brute force to get the tyre onto the rim, but way back in the day, I destroyed a rim and a tyre doing that.
Anyway .. pumped up to about 3 bars. The missus and I are off to the country this weekend, so the bike will stay in the living room, and when we get back, I’ll use my track pump to get the correct pressure, and then try for a hat trick on Monday. 😐
Dnnnnnn
cycle.london
Found the blighter:
Found the blighter:
cycle.london
Very much appreciating the
Very much appreciating the support here, fellas.
Right. Am I going to grab this rear wheel off now, or what?
Wish me luck…..
Dnnnnnn
PRSboy wrote:Before taking the tube out, mark with chalk the orientation and position of the tube relative to the tyre so that when you find the puncture you can go back to the wheel and tyre to see wot did it.Might be worth leaving a more permanent on the spot on both the wheel and tyre so you can compare locations if it happens again in a couple of days, etc.
I did feel for you after reading your previous post. Had the same thought as HawkinsPeter re. the possibility of the rim causing it. Durano Plus are damn good tyres IME. Check whereabouts on the tube the hole is. I had a similar hard-to-diagnose issue with my son’s cheapie, a sharp edge on the valve hole was wrecked 2 tubes before I got a file onto it.cycle.london wrote:Not going to let this get me down. Although I did get pretty pissed last night, so am nursing a hangover. 🙂Remember things like this are not personal, it’s just one of those things that happens to everyone. Shit happens, it’s how you deal with it that makes the difference. Hope you get rolling again soon.
PRSboy
cycle.london wrote:HawkinsPeter wrote:The puncture fairy can be a cruel mistress indeed.One thing to check with a puncture is whether it was caused by a mis-placed rim tape i.e. the puncture will be on the inside of the inner tube rather than the outside. If the rim tape is not quite covering a spoke hole, then a bump can be enough to rupture the tube from the exposed edge.
Yeah, I thought of that. The bike is sitting barely ten feet from me as I write these words (from home, of course!), leaning against my wife’s piano. I’m going to get the wheel off today and see what’s what. Not going to let this get me down. Although I did get pretty pissed last night, so am nursing a hangover. 🙂
At the risk of teaching granny to suck eggs etc, inspect the tyre really carefully. I had a similar spate of repeated punctures, to find in the end a bit of flint that couldn’t be felt or seen in a usual check of the inside of the tyre, which only stuck out when under pressure from the outside (i.e when riding over a bump).
Let us know what you find.
I always get suspicious when I get multiple punctures over a short period of time, so it’s worthwhile identifying if there’s anything still stuck in the tyre etc.
cycle.london
cycle.london
So, after my last post, I
So, after my last post, I made the most of the Christmas period to veg out at home. Near the end of the hols, I brought the bike in, swapped the rear tube out.
Monday morning, up at five AM and on the road to London. Every bump in the road, I was convinced that the tyre was flat, but whenever I got a chance to stop, I’d force my thumb onto both tyres, and they were both rock solid (insofar as my thumb has the strength to push into the rubber).
But my God, am I out of condition! No chest pain or nuffink, so I wasn’t worried, but the last three miles into the office were bloody hard. The ride home was worse, but I made it (walked up a couple of hills, though).
I worked from home Tuesday as we had deliveries, and then this morning, back on the bike. To my utter shame, that was the first time I had done two cycle commutes in the one week, since the first week of August last year.
This afternoon, knocked off and headed home. Halfway into the ride, I go over a bump and feel a definite ‘crunch’ from the back. Yep. Another puncture.
It can’t be something in the tyre because then surely, it would have given up the ghost before today?
Anyway, I give up. I f*****g well give up. My belovèd was at work in central London so couldn’t come to get me. I called a taxi, tossed the bike into the back and twenty minutes later, was £25 poorer, but at least I’m home.
I don’t get it. When I got the bike, it was running really fast, supple tyres and I was averaging about two punctures every three weeks. So I swapped them out for Schwalbe Durano Plus. And the tyres on the bike are no more than a year old.
Well pissed off.
I’m having a beer.
wingmanrob
Why not change your turbo to
Why not change your turbo to one that doesn’t have spinning rear wheel so a bit more cat friendly. A wahoo kickr opens up a whole spectrum of training, zwift or trainer road.
bigbiker
I would suggest going for a
I would suggest going for a lunch time ride. Better light and temperatures, and people are in a hurry to get to work in the morning while half asleep – so it is likely safer at mid day.
I also found having a big event/sportive to train for helps with motivation. You know that if you don’t keep up the training the event is going to REALY hurt, but if you keep at it the ride will be a good experience
Jetmans Dad
This is one of the reasons
This is one of the reasons that the turbo trainer becomes important to me during Winter. As a teacher, this term is by far the busiest and most pressurised, with parents evenings, options evenings, mock exam prep etc. I am in school for 11-12 hours most days, so cycling in at 6:30 in the dark and cold comes second behind trying (and usually failing) to get a good night’s sleep ready for the next day.
Being able to hop on Zwift for an hour late in the evening is a godsend. It’s not getting me out in the fresh air, but it is getting the pedals turning and cutting the time needed to get the same level of workout.
