- This topic has 29 replies, 23 voices, and was last updated 8 years, 8 months ago by
Boatsie.
January 26, 2018 at 7:06 pm #28077
paulrattew
I’m going to be several night rides this year. They will all be on mostly unlit roads, so I need a light that will be good enough to safely riding on the road in pitch black for 4-6 hours, but that has a beam pattern that is road specific so that I don’t cause any problems for other road users. Too many lights aimed at night riding seem to have completely innapropriate beem patterns for road use
Any recommendations on what the best available lights are at the moment?
My light of choice is the
Forget all that, can’t find the PAVA light anymore, best light I’ve found for high speed night time runs.
kil0ran
paulrattew wrote:oldstrath wrote:Battery or dynamo? Dynamo, pretty much any of the Gerrman lights will work tolerably well- I’ve had problems with the Luxos U, but the Supernova road specific light is ok. Battery – the Ixon IQ Premium, essentially the battery version of some dynamo light or other, is usable, although the battery compartment isn’t wonderfully built.To my mind, although these lights are generally ok, the beams are too narrow for some situations – on some bends one effectively has to ride into darkness – bit scary at times.
Battery. Not quite ready to invest in another front wheel with a good dynamo system (don’t think I could skeak that past my wife…)
Doesn’t need to be that expensive – and will probably end up cheaper than a battery light that will do the same job.
Take a look at Taylor wheels – you’ll get a front wheel, dynamo, and light package for around £130.
oldstrath
Simon E wrote:There are very few road-specific battery lights on the market. If you have deep pockets then consider USE Exposure models such as the Strada, which they say is “tailored for tarmac “. I find 400 lumens is plenty on country lanes, providing the beam spread is wide enough, which has always been a weak point of Cateye lights.Reviews and beam comparison via http://road.cc/category/review-section/accessories/lights-front
Cygolite Metro Pro 1100 looks good value. Lezyne claim the Macro 1100 will run for 4½ hours at 450L – is that long enough? http://www.lezyne.com/products-led.php
Another beam comparison page – https://www.tredz.co.uk/lights-comparison-test
At least 40 on the rosebikes website. Ok, not all great lights, but some choice. The Ixon IQ Premium will do about 5 hours on full, and uses AA batteries, so easy enough to extend that, and is adequate on most roads
cyclisto
Buy a multi-led xml-l2 light
Buy a multi-led xml-l2 light with 18650 batteries or battery pack from ebay and lower its beam as much as it is needed not to blind oncoming traffic.Canyon48
I have a Cateye Volt 800 that
I have a Cateye Volt 800 that is just fine for cycling on unlit country lanes. I’m not sure it would last 6 hours on full power though. My other half has a Cateye Volt 1200 which is even better, but ridiculously, blindingly bright.
RoubaixCube
You missed the massive sale
You missed the massive sale retailers were having on lights like the Moon Meteor Vortex Pro. They are normally around £80 or just under it but we’re selling for as low as £35 in some places. You can also pick up a spare battery for £15 to give you from dawn to dusk battery life so long as you’re not going at full bore all the time. For the dunwich dynamo ive used lights like the fluxient u2 mini, magicshine 858 and 872. Both of them are superb and very bright. i tend to run either on the lowest or medium setting and have them angled down at the road a little more to avoid blinding other road users, you can do this with pretty much any light
Welsh boy
I have a Fluxient F3 which is
I have a Fluxient F3 which is great, puts all the light on the road, not up in the tree tops. Not as much absolute output as some other lights but all the light it does produce is pointed where you need it. Have a look at http://www.torchythebatteryboy.com/p/bike-light-database.html for some good beam comparisons.
don simon fbpe
I came across an interesting
I came across an interesting side to the brighter is better argument last week. Oncoming cyclist was probably indicating to turn right when faced with oncoming traffic, I couldn’t see due to the 20,000 lumen (or whatever the cockfest says you must have) light they were using. Fortunately I’m a considerate twat when driving and didn’t mow them down. Rider must have assumed that I’d seen the indication as they pulled right across me, like I said, I’m a considerate twat when it comes to fragile cyclists.
oldstrath
paulrattew wrote:Grub wrote:Cateye Volt 1200 worth a look.The reviews section on here has loads of front lights reviewed with a beam pattern comparator.
It’s probably just me, but I find it hard to work out what the beam pattern shown on the comparator equates to on the road. The Cateye Volt 1200 for example just looks like it has a round beam – I can’t tell if I would have to have it pointing way down to not blind oncoming traffic or not
I’m nver convinced by the “it will blind peopke” argument, but if it worries you, STVZO compliant lights are the thing, from one of the German sites such as Rose.
paulrattew
paulrattew
oldstrath
Petsonally on dark roads I still prefer the Lumicycle 3si (now the Freeway) – the beam is less controlled, but (or therefore) mote generally usable on dark roads.
Grub
