- This topic has 29 replies, 23 voices, and was last updated 8 years, 5 months ago by
Boatsie.
January 26, 2018 at 7:06 pm #28077
paulrattew
I’m going to be several night rides this year. They will all be on mostly unlit roads, so I need a light that will be good enough to safely riding on the road in pitch black for 4-6 hours, but that has a beam pattern that is road specific so that I don’t cause any problems for other road users. Too many lights aimed at night riding seem to have completely innapropriate beem patterns for road use
Any recommendations on what the best available lights are at the moment?
Boatsie
Im wrong. I meant those
Im wrong. I meant those watch battery strap lights that barely weigh that of a coin. Not really useful on dark roads if viewing is required.
I always ride with a set because at $1 per delivered light, the budget wasn’t stretched and they basically easy. Note. I rode off creek paths a lot during full moon night because they ain’t primary purpose as seek reads. Great spare light though.Craigus Farticus
I have BikeHut ‘Cats Eyes’ (I
I have BikeHut ‘Cats Eyes’ (I think they’re called) that are so bright on their brightest setting that I get flashed by cars! Great for lighting my way on early and late ride to and from work. The front light has a rechargable battery bank that straps to the frame. 🙂
Boatsie
hawkinspeter wrote:Hensteeth wrote:I have a Lezyne 600xl on my bars set to full / dip at a touch of the button. Also have a Chinese torch with 18650 battery on my helmet which is like a full beam headlight. Any oncoming traffic I switch it off and the Lezyne is sufficient till they have passed. Headtorch would last about 4 hours but you can easily swap batteries. Lezyne about the same on dim setting. Have a look at BangGood or Gearbest. Very good flashlights for very little money. I think mine was about £8 on offer Inc. Battery. Had it for a year now and it is still fine.I’m a big fan of cheap Chinese 18650 torches. I tried using one (attached to handlebars) that takes a single 18650 and found that it wasn’t quite bright/wide enough for my liking, so I hunted around for ones that take 4×18650 batteries. Now that’s plenty bright enough, but you do have to be careful to aim it at the road, but then what do you expect for a torch that costs £15?
You do have to be a bit careful with buying the batteries as there’s a huge difference in quality and the power rating (mAh) can’t easily be tested without specialist equipment – have a look at http://www.torchythebatteryboy.com/ for more info.
I like the 18650 battery torchs too. I usually just use the very tiny cat eye type lights on front but not any good to tour unlit paths on. Torchs are great. Recently battery died. Was working perfect until after a plane ride.
Nowadays battery storage capacity is 4* what I had. Lithium ion batteries last ages if kept cold and at about 40%. Eg half charge in fridge.
If I had some earnings to spend I would look at the triple or quad led light arrays that are cased to suit handlebar mounting. Seen a mtb the other night and he had plenty to view with.On road I’m watching with assumption that I’m not seen coming. Dark tracks the torchs light enough to maintain small pace. Back end is a Christmas tree. Lol
Luxie
I have the Volt 1200 for a 7
I have the Volt 1200 for a 7 mile commute on unlit road and it is great light. The only thing that annoys me is that I generally have it on the 2nd brightest setting until i get onto cycle paths away from roads where i need it on the brightest setting, to do that you have to go through the sequence of lower brightness/flashing setting to get to brightest. Not great when on poorly made tracks!
mista-tee
I have 12 miles of unlit
I have 12 miles of unlit commute and use 2 lezyne super drive lights. One is 1200 luman and the older one is about 700. I run two due to the risk of failure mid ride, with the added benefit of having more light available. I normally run them both on economy mode so maybe 500 & 300 lumen, switching to full power on downhill bits or on stretches where there are potholes. Obviously the faster you go the further ahead you need to be able to see.More thought needs to go into the design of bike lights. There are times when I would rather have the light pointing further forward to see further ahead but don’t as it would blind oncoming cars. A circular beam pattern is a bit of a blunt weapon.
I run mine for ~2hrs. If you want 4-6 hrs I would definitely take 2 lights. I think my older one is 3/4 years old and still going well. They are quite heavy but equally are pretty bomb proof having been dropped a few times.
Clunkymonkey
Bought “1200 lumen” light off
Bought “1200 lumen” light off fleabay for £25 it’s almost as bright as a car dipped headlight with a run time of about 90 mins and will fully recharge in about 4 hours. I use it on 2 miles of unlit cycle paths that don’t have any light spill from street lights and can see well ahead for 20-25 meters.
Don’t know if spending 3 or 4 times as much would be any better and if it gets stolen or busted its only the price of a takeaway for 2.
Hensteeth
I have a Lezyne 600xl on my bars set to full / dip at a touch of the button. Also have a Chinese torch with 18650 battery on my helmet which is like a full beam headlight. Any oncoming traffic I switch it off and the Lezyne is sufficient till they have passed. Headtorch would last about 4 hours but you can easily swap batteries. Lezyne about the same on dim setting. Have a look at BangGood or Gearbest. Very good flashlights for very little money. I think mine was about £8 on offer Inc. Battery. Had it for a year now and it is still fine.paulrattew
alan loves froome wrote:kevvjj wrote:This gets great reviewsRavemen PR1200 USB Rechargeable DuaLens Front Light With Remote
Specifically tailored lens for commuting too.
It’s the best light I’ve ever owned…and I’ve tested a hell of lot of lights! I can’t believe nobody came up with the dipped beam/full beam and the option of controlling it from the remote switch until now.
This is website gave it a rave review (excuse the pun) and rightly so. It covers all the night riding bases and it can charge up your phone and bike computer while it’s at it. The Ravemen beats all others.
Can you charge the Ravemen up while using it? One of the things that puts me off of the Cateye Volt 1200 is that the position of the charging port would make it difficult to charge while in use
Vili Er
Redvee
I’ve got a Mk3 Cirius and it
I’ve got a Mk3 Cirius and it’s had daily use for the last two years with no major issue, pnly problem was the stormport cap not being secure but after two years that was expected but a quick email to USE and a new one was on the post. Nearly bought a newer USE light but the current one does it’s job perfectly with only 300 lumens.
BikeJon
Stratman wrote:
Stratman wrote:I’ve used Ay up lights, and found them very good. They do come with multiple battery packs. I switched to an exposure Sirius, as it was smaller and lighter, which I’ve had for the past couple of winters and found fine for riding on unlit roads, but I’m not sure that it would have the endurance you’d need.
The Exposure Sirius does have a smart port so you can supplement the battery life with additional battery packs. Being Exposure, they are pricey too however. But I like my Sirius. My mate has just got the mk12 Joystick and that is mega bright!Stratman
CXR94Di2
Niterider 750 or above.
Niterider 750 or above.Anonymous
