- This topic has 16 replies, 13 voices, and was last updated 8 years, 12 months ago by
Johnnyvee.
October 25, 2017 at 6:00 pm #27771
Johnnyvee
If you use more than one set of wheels do you have a cassette fitted to each rear and a chain that goes with that wheelset or some other way of managing or rather matching the wear.
I’d like to be able to swap wheels quickly without too much faff.Anyone have any top tips here?
Cheers.
Johnnyvee
I have a winter and turbo set
I have a winter and turbo set and a better set for nicer weather. Have now found out that the cassettes are slightly at different positions when the wheels are in place so swapping means I have to tweak the adjuster to keep the gears shifting crisply. Why is nothing straight forward?!
Oh well I’ll just keep the original set on for now and put the better ones on in Spring. I had hoped to have a trainer dedicated wheelset or rear wheel and another outdoor set.
Bikes – it’s a love hate thing and I can see now that I should have just got a winter bike.Dunhoy
I have three hand built sets (thanks DCR Wheels) each has its own cassette and they get swapped between bikes as needed
froze
If a person is using two sets
If a person is using two sets of wheels for one bike that usually means they have training wheelset and a racing wheelset, each set would have a different gear profile. While changing the cassette isn’t a big deal (plus cleaning your hands afterwards) but why bother doing it since the cassettes aren’t all that much money anyways? Also why put twice the wear on one cassette.
Johnnyvee
I have the same cassettes
I have the same cassettes fitted to each wheels or at least will have by the weekend.
Grahamd – brilliant idea! If only
antigee
Done this for several years
Done this for several years to make it easy have cassettes on both wheelsets run disks and currently get away with not resetting calipers despite different hubs
To avoid issues around chainwear and cassette wear i do regularly use a chain checker and retire chains promptly
Never had an issue with limit screws sometimes a quarter turn on inline adjuster to get indexing correct
Works well for me mainly ride mixed gravel on 35mm tyres but if going on a 100% road ride or some event that dictates riding a bit faster will fit the wheels with more trad roadie tyres
N-1 though 🙁surly_by_name
Cassette on each wheelset,
Cassette on each wheelset, will save you the most amount of time at the time when you need to save that time (i.e., when you wake up to go for a ride) if you don’t have time to set everything up the evening before. (Or you have better things to do with your time.) Don’t worry too much about differential wear, chain will see to that. Or if you do, swap the cassettes between the wheels at periodic intervals (when you have time). Change chain every 3 months.
700c
Across two bikes I have a
Across two bikes I have a total of 4 wheelsets on the go at the moment, with 4 different cassettes (not always the same on each wheel).
The reason is a combination of old as a turbo wheel, basic (winter) and two different rim depths for fair weather riding.
All are compatible with each other, none has massively more milage than any other, no jumping/ skipping etc. You just need to swap over the cominations quite regularly to ensure they wear with your chain.
Introducing a brand new cassette or chain into the system after 000’s of miles will invariably cause some problems however.
dottigirl
I’d be more worried about the
I’d be more worried about the difference in limits between wheels – just changed some over and if I’d used hte first wheels with the second wheels limits, the mech would’ve been in the sprockets. And vice versa for the frame.
Grahamd
Johnnyvee wrote:
Johnnyvee wrote:Thanks for all the replies. I’ll be running the old set of wheels with cx tyres and the new set have tubeless road for better conditions and the turbo. Slight wiggle is the bike has discs and the calipers just need a tweak to align but it may just be quicker to do than change chains all the time. I do have the right tools to do all of this I was just looking for others experiences to see what worked best as I’m time poor first thing in the morning when I’m heading out for a ride. I do usually make sure the bike is ready the night before but those with kids will appreciate it’s not always that easy. Cheers allTrain the kids to do your bike maintenance. 🙂
Johnnyvee
Cheers allGrahamd
I run two sets, one set
I run two sets, one set aluminium and the second set carbon with aluminium breaking rims. Means brake pads don’t need changing, just adjusting for different wheel widths.
I keep separate cassettes on each, just for convenience.
SingleSpeed
My main issue is between
My main issue is between swapping carbon wheels and alloy wheels so time is irrelevant as you have to swap out pads and I only run three road bikes with gears anyway, having said that I buy a wheelset a cassette and a chain, if I’m changing wheels for different uses I’ll tend to be wanting a different ratio any way so having a chain cut to the right length and Quicklink makes it much easier. I keep the chain in a poly bag in the myriad wheelbags in the bike room, makes it much simpler for me, You know each chain has done the same miles as the cassette.
MTB’s are much easier Hope hubs, 160mm rotors, S-Works tyres and Various Chris King King Sprockets, that’s just a swap out depending on the conditions of the race!
Unless your kit is really
Unless your kit is really high end and you’re doing a ton of miles then just go with the cassette on wheels same chain advice.
If you are doing a lot of miles or leaving the wheels on for a decently long period of time consider swapping chains too afterall a chain takes similar time to remove fit as it does a cassette so swings and roundabouts in that respect.
beezus fufoon
with the right tools,
with the right tools, swapping the cassette over takes about 3 minutes
kil0ran
I ran two wheelsets last
I ran two wheelsets last winter. Both had cassettes installed (same ratios and manufacturer) and I used the same chain. The whole drivetrain was new components at the start so the only item that wore at a different rate was the cassette. Didn’t have any issues with shifting performance when swapping to my wet weather wheels from my best wheels. Probably 80/20 usage between the two wheelsets over the winter. Depending on tolerances you might need a small tweak on the rear mech barrel adjuster to sort out indexing but I never did. Obviously important to get the wheel centred in the dropouts – mine was a disc braked bike with a QR at the rear rather than thru-axle but I didn’t have any issues.
I think if you abuse your chain, or the cassettes don’t match in terms of spec of age you’ll get issues, but these are overstated in real world use.
