- This topic has 23 replies, 19 voices, and was last updated 9 years, 3 months ago by .
Earlier in the year I decided I wanted to replace the wheels on one of the bikes, I am a big fan of Hope hubs (I am the one that actually likes the sound of the free hub).
I priced up the hubs, rims and spokes and the price started spiralling up, so I settled on a factory set of Hope 20FivePro 4’s, they appeared to fit the bill and came under my custom build budget, they also came as Tubeless ready if I fancied the dabble….
When it came time to actually fit the new seasons kit to the bike, I was relishing the idea of fitting the new wheels, and then I ground to a halt, my normal tyres of choice (non tubeless) Conti GatorSkin Hardshells would not fit, even after leaving out in the sun, pre fitting to another wheelset, they simply would not fit!
It gave me the kick to actually try tubeless, I settled on Schwalbe Pro-One…
They fitted quite easily and tyre seating was straight forward (I used a Co2 canister), removed the valve core and added 20ml of Stans, pumped it all up to 80psi and everything was good, my world was in sync…
Everything was good for 900 miles, I did Barry’s Bristol Ball Buster 200k, a long weekend around Snowdonia, and I was starting to get a good feeling about tubeless…
After getting back from Snowdonia I noted that the tyre pressure had dropped to less than 40psi, on pumping the tyre up ALL of the Stans vomited from a puncture in the tyre (at about 75psi), time to try a plug, it took 2 plugs and the tyre was deformed after the repair, I decided I could not trust it, so tried fitting a new spare Schwalbe Pro One (I would normally expect at least a year and 6000+ miles for a tyre, 900 miles hurt)
No matter what I tried I could NOT get the tyre to seat, I ended up replacing the rim tape, this appeared to solve the problem, new rim tape was not compressed into the well of the wheel and as such the tyre bead had an easier ramp to the sidewall….perhaps I should try wider Rim Tape? The internal dimension of the rim is 21mm and I used 21mm rim tape, that does not allow for the tape to seat into the internal channel completely?
Now 600 miles later, I clipped a stone on my lunchtime ride today, more of a pinger than a slicer…
It appears to have caused a puncture on the tyre shoulder (between the tread and side wall), Stans did not seal it and the tyre went down, I would normally avoid Co2 and Stans, but as time was limited I used Co2 to inflate, The tyre went up and stayed up, no signs of leak, I assumed that Stans was in the wrong place at the wrong time, 10 miles later and the tyre was low pressure again, I re-inflated, 5 miles later low pressure again, I re-inflated with hand pump….
When I got home I left the bike outside, and hour later tyre was still up and firm…There was no sign of where the puncture was, I pumped it up to 80psi and all was still good, the whilst doing something else, a hissing was heard, and a small fountain of Stans started spraying for a pin size hole, wiping it with a cloth and the leak stopped……I let the tyre down, removed the valve core and added another 20ml of Stans, pumped tyre up, rotated it and let the leaks seal…
So am I just being unlucky and I should persevere, I have a set of Hutchinson Fusion 5’s to try, just in case its the Pro Ones, they are racing tyres, and I am not a racer!
Should I just abandon and get the rims replaced so I can use my tyre of choice (Conti Gatorskin Hardshells)
Or am I doing something fundamentally wrong? I suspect wider rim tape as mentioned earlier would solve my tyre change seating issue, but has nothing to do with punctures…
And please don’t tell me Tubeless shouldn’t puncture, it is an unfortunate side effect of pneumatic tyres, even Schwalbe Marathon Plus tyres puncture (I have had two punctures in 10 years on them)
