- This topic has 24 replies, 15 voices, and was last updated 9 years, 6 months ago by
calayanrail.
April 27, 2017 at 12:43 am #27046
daviej
So with tubeless becoming more common I have the following question.
What is the difference in ease of roadside repairs between a Tubeless with a sealant and a Tubular with some sealant in it?
700c
check12 wrote:
check12 wrote:Tubular tyres have higher rolling resistance than the best tubeless (pro one) and normal tubed tyres (4000s etc. ) so less/no temptation to go for them for me. http://Www.bicyclerollingresistance.com
Not so according to your website (eg vittoria’s corsa g speed tub and clincher have lower rr than the tubeless schwalbe), although not that many tubs are actually tested
A useful site but lab tests probably best taken with a pinch of salt.
dave atkinson
I’ve run tubeless on my main
I’ve run tubeless on my main bike (kinesis tripster atr) for about three years now. the main difference in roadside repairs is that there haven’t been any, at all, ever. maybe i’ve been lucky. certainly on the dirty reiver last weekend there was at least one person by the side of the road swearing at a tubeless tyre, and mike had to put a tube in one of his after he accidentally deflated it and didn’t have the wherewithal to get it sealed again. so it’s not a magic bullet
there’s various things to consider and it’ll depend on what you’re doing. small holes will get fixed by the sealant. anything bigger than that will need some kind of repair. normally it’s just a case of sticking a tyre boot on the inside and fitting a tube, the same as you would if you ripped your tubed tyre. i carry a single tube on most rides, and two on longer rides. but that’s what i used to do before tubeless, too.
i like to carry all sorts of stuff with me on rides, and one of the things i carry is a needle and a length of dental floss, for emergency repairs to stuff. i’ve sewn up a hole in a tyre (not my own) once, and also fixed a shoe and an embarrassing hole in my shorts. dental floss is ace because it’s super strong and it’s also waxed so it’s easy to pull through thick fabric, or the wall of a tyre. if you were on a longer tour then you’d likely be able to re-seal a tubeless tyre if you sewed up the hole. i haven’t tried, but when my current tyres reach the end of their operational life i’ll give it a go. to pop it back on the rim you’d probably need a CO2 cannister.
the pay-off for no faffing on the go with tubeless is extra faffing, checking sealant levels periodically, and when you’re swapping tyres. faffing at home counts as fun though, right?
700c
I remember surprising some
I remember surprising some guys wrestling with a puncture at the side of the road on ride London. (Everyone was puncturing due to atrocious conditions). Along I come with punctured tub, cursing my luck. I whip it off, put pre-glued spare on, inflated and off again with a cheery wave before they’d finished!Admittedly tubs were a poor choice that day as the conditions became so bad, but they were later repaired at home with sealant.
I only use them now in good weather but I do think the negatives are overplayed. I suspect the best tubeless would have a lower rr but otherwise, after the faff of installation (no worse than tubeless surely), they are lighter, safer, wheels are often cheaper, can run at a greater range of pressures, they puncture less, and ride at least as well as the best clinchers w/latex inners.
Apart from that one ride (through foot high water! ) I’ve only ever punctured one tub and have done thousands of miles since.
check12
simonmb
Tubular only makes sense for
Tubular only makes sense for best bikes, best rides. The ride is plush, but you weigh this against the risk of inconvenience if you get a flat. I can’t understand why anyone would go to the expense of fitting tubular wheels and tyres, and then fill it with sealant. If you’re that concerned about getting a puncture, stick with clinchers (regular or tubeless) and carry a spare tube in case of emergencies. Save the tubs for the weekend.
Jimthebikeguy.com
This ones a fairly simple one
This ones a fairly simple one but there is a lot of resistance at the mo towards tubeless from some quarters (because its newish tech like discs). Tubeless for day to day use is the easiest and best thing by far, unless you like fixing punctures. And any ideas about it being a faff are ironic given that the word faff was invented to refer to tubular tires.CXR94Di2
Tubeless with sealant, easy
Tubeless with sealant, easy to repair incase of emergency, fit inner tube. Unlikely to get a puncture that doesn’t self seal.Tubular, carry foam or have sealant in tyre, I use Stan’s sealant. Again unlikely to puncture that won’t self seal. Emergency, carry phone and get a lift home :). Tubular can be really difficult to fix at the roadside.
Without boring you with my
Without boring you with my bias/opinion about tyres… a roadside repair on a tubeless tyre is no different to a roadside repair on a tubed tyre (just put in a spare tube). It can be a tad messier…
For a tubular, if you have added sealant and it still deflates then the hole is too big to fix with ‘foam’. You will need to rip the tyre off and replace with the spare you are carrying (you are carrying a spare tyre aren’t you?) – if you have never done it before it will take ages (the reason why most tub users get it done at a shop) – if you are experienced, not so long…
You won’t find many commuting
You won’t find many commuting on tubular but it’s that type of riding that is usung tubeless more and more as well as leisure cycling (as in not competition).
Personally I don’t use sealant in my tubs, I won’t buy wafer thin tyres that are more likely to puncture. Currently use a 25mm conti comp front and a 27mm veliflex vlaandaren. Spendy up front but plush fast ride and I haven’t flatted a tub in years (conti 4000SII before) but do take a 125ml can of foam sealant as a back up on rides which inflates and seals tyre instantly. Used to take a spare get you home tub if I was away or on a really long ride in case but not so much these days for day rides.
Are tubeless easier, in terms of on the spot fix well if the sealant works they look to be great but all that sealant, the faff of the tyre, biying new rims, the valve and so on, not for me, I’d rsther stick to normal clinchers and tubes for everything else other than the fast bike.
Worse rolling resistance, very likely, less costly, not even close, tubeless is expensive by comparison, more complicated and time consuming unless you’re careless and puncture a lot and/or buy inappropriate tyres/don’t inflate correctly, not to mention the sealant aspect. -
