- This topic has 35 replies, 26 voices, and was last updated 9 years, 8 months ago by
ibr17xvii.
January 3, 2017 at 4:20 pm #26618
AWP
I’ll try to be brief.
I decided I’d try to get through the winter on a pair of Conti GP4000Sii (28mm). Whether I’ve been unlucky I can’t say but I’ve had a particularly bad run of punctures mainly from flint/stones to the point that I have had to patch the rear twice (never had to do this before) and likely it will have to be skipped if it happens again. Never seen a tyre looking so cut up.
Looking around at options, with a view to trying tubeless, I have a short list. I’ve read the reviews but could anyone, with actual experience of the following tyres, care to make any recomendations? All options would be 28mm.
Continental GP 4 Seasons – although tubeless ability is unknown?
Hutchinson Sector 28
Panaracer Gravel King
Schwalbe S-One Evo (might be called G-One Speed now?)
Hope you can help.
Thanks
ibr17xvii
Was sick of getting punctures
Was sick of getting punctures in winter on Gatorskins so got some Conti GatorHardshells, had them on for less then 400 miles & got a big split in the rear tyre yesterday.
Fortunately it didn’t blow out & fortunately I was round the corner from home but it’s very disappointing for a tyre that’s supposed to offer increased puncture protection.
I’ll probably get another as maybe I was just a wee bit unlucky but it’s frustrating nonetheless.
sergius
Don’t tempt the fates! After
Don’t tempt the fates! After 9000 punture free km since I started riding again; I then had five punctures in as many months.
I’ve decided against tubeless for the time being on my new wheels as I’m not convinced the faff is worth it. I struggle enough to fit non tubeless tyres as it is (it’s taken me over 30 minutes to get a tyre on once in the pouring rain!), as I understand it, tubeless are generally worse.
I generally ride Conti GP4000SII tyres, though I’ve now switched to gatorskins on my winter bike as I found the Conti’s were getting really cut up after only a short time.
wycombewheeler wrote:One in ten rides gets a puncture? Are you sure you’re fitting a tyre over your tubes?I ride six days a week, in all weathers, over very mediocre roads and cover between 4 and 5000 thousand miles a year. I’ve averaged less than one flat per year for as long as I can remember, .
Same here. Been commuting (urban roads and shared-use, muddy riverside paths, usual sort of thing, all weathers, almost always weighted down with panniers or a big bag) for nearly six years. In all that time, I’ve had – I think – about five punctures (and one of them was actually a sidewall tear).
(Oh god, I’ve done it now haven’t I?
)hsiaolc
Thicas1515 wrote:4 seasons are definitely overrated I think
Michelin Pro 4 would be better for puncturesNothing compares to tubeless. Not even close.
2 years without puncture (well I am sure there are but I’ve only witnessed it twice).
last time was two day ago? I was putting my bike up for cleaning and saw something shinning on the tyre. There was a pin stuck on it so I pulled it out, immediately hissing and in vertually seconds it sealed itself. Impressive. I rode in twice in the rain with no problem.
First time I was in Regents park and I heard a hiss and immediately selant was pissing out and I thought damn I need to push my bike to work. Guess what, in 3 seconds the sealant stopped coming out and it sealed whatever hole there was and I got to work just fine.
One of the best upgrades I’ve done since disc brakes.
wycombewheeler
peted76 wrote:wycombewheeler wrote:
Yes you still need a tube as sealing a tyre even with a track pump will need soapy water and is not something I would attempt by the road. but the benefit is not saving the weight of a tube, it’s in having to stop for a puncture once in 100 rides (or fewer) instead of once in 10. I recently fitted a tubeless, there was almost zero mess, small bottle of sealant with a nozzle that fitted into the valve (core removed) empty sealant into pre sealed tyre, (fit and seal empty then deflate, fill then reinflate.) I went with schwalbe s ones. very happy with them.mike the bike wrote:If you do puncture out in the countryside and the tyre needs topping up some are a nightmare to re-inflate. Fitting a tube means you’ve got to carry one, negating one of the advantages of the system. I recently passed a rider with just this problem, his mini-pump wouldn’t even begin to put air in the tyre and I wasn’t giving him my spare tube as I had another ninety miles to ride.
The sealants have a definite and short life in the tyre and will need renewing every few months. They’re not cheap and the job is messy, messy, messy.
The sealants will also bung up your valves, making inflating tricky or even impossible.
Wycomewheeler is doing it wrong. However saying that tubeless can be tricky to get right in my experience, where as tubes are always very simple.
I run tubeless and have done for nearly two years now, I’ve never fitted a tube on the side of the road, I’ve not the patience and I’d rather call the family taxi. What I do carry, is a small half filled bottle of bontrager sealant (the best for high pressure road tyres in my experience) and an air cannister, it’s easy to pop the valve out, refill sealant and inflate if it’s required in an emergency.
To be fair I should probably get a mini pump instead of the cannister as pressurised air shouldn’t ideally be used with sealant, but it’s a quick fix, light and easy to carry.
doing what wrong? initial set up, or roadside repairs? i haven’t had to make any repairs since going tubeless, but throwing more sealant into a tube to fix a hole the existing sealant is unable to seems pretty optimisitic to me. I’m not carrying a tube on my commutes now or if I go out for just a short ride (60-90mins), I do carry one on the club ride (would be too embaressing to ask for one) or audax rides (where i would be too far from anywhere).
….. but the benefit is not saving the weight of a tube, it’s in having to stop for a puncture once in 100 rides (or fewer) instead of once in 10……wycombewheeler wrote:One in ten rides gets a puncture? Are you sure you’re fitting a tyre over your tubes?
[/quote]Chlitern flints.
if i was looking at one replacement tube a year I wouldn’t have bothered. It’s not just me either. I would say on club rides (group of 8, probably 2 in 5 rides will be interupted by someone having a puncture.) . Everyone carries two tubes as getting two punctures in the same ride is not unknown.
logomomo
Have ridden 3k on Hutchinson
Have ridden 3k on Hutchinson Sector 28s – mixed riding – B roads, tow paths and back lanes). Had a couple of small punctures in that time though they both self sealed (stans tubeless sealant) with minimal air loss.
I did get a nasty slash on the side wall – about 10mm in length which obviously did not seal. It was on a ride from Cambridge to London and needed booting and an inner tube to get me home. Suspect it was a glass shard and the tyre was a write-off but that would have been the case with pretty much any performance tyre.
Highly recomend the Sector 28s – really lovely feel to the ride and good grip – only drawback is that they seem to kick up a lot of spray in the wet.
Thicas1515
Michelin Pro 4 would be better for puncturesSimboid
hsiaolc wrote:Ok let me give you another perspective.I also had conti 4 seasons. Actually I still have them. Used them for half a year (2 years ago one winter) and never will it be on my rims again. Cant compare the tubless’s comfort level. When you can run 50 psi or less it is a god send. The puncture proof is a plus but I get it for comfort and doesn’t seem to sacrifice any speed either.
Hence I want to go bigger to 32mm so I can dip below 50 psi to around 45.
I’ll 2nd that. I quite liked my 4 seasons, fairly fast and very robust. I once got the dreaded ‘ticking tyre’, knowing it probably meant a big puncture I stopped and picked out a shard the size and shape of a shark tooth, pointy end in, and nothing happened! Only problem is they ride like wooden hoops.
My new bike fits up to 35c and has stan’s grail so I put tubeless S-Ones on and what a difference! Road buzz is no more with 45-50psi and my arse can go at least an extra 10 miles without complaining. Faster too and no punctures so far in 2000 miles. I used 12mm rim tape just in the groove so it doesn’t touch the tyres and air loss is negligable. Hate punctures? Go tubeless.
riotgibbon
riotgibbon wrote:tried out my new Gravel King 32’sfar better on muddy tracks than S-Ones, but I don’t think as fast on the road. Have to get some more commuting miles in to really know about the road, but they’ve handled great off-road in some fairly sloshy conditions. Not slow on the road, just not as fast as S-Ones
First puncture on Gravel King”s, after about 90 miles, 20 of which off road. The Hollow Crown ….
riotgibbon
Bike Swanky
Had an abolsute hoot on
Had an abolsute hoot on Friday. Went geocaching off-road with the boys from Stolen Goat.
Rode the Tifosi TK7 Gran Fondo fitted with the S-Ones. https://www.facebook.com/BikeSwanky/posts/456445177812561
Up to 6″ of mud in places, slippery roots, ice, frozen hoof prints, slippery roots. More importantly, plenty of gorse bushes around! The S-ones handled it with no issues! No punctures! Running with tubes. Who’d have thought?!?!?
Also, the TK7 Gran Fondo was designed before Gravel Road became a thing…….who knew that it could handle it so well? 🙂 LOL
(It was fitted with a steel fork)
So, if you were wondering if the S-Ones would work well as good Winter on the road tyres, then I’d have to say “I’m sold” 🙂
riotgibbon
my first set of S-ones (30mm)
my first set of S-ones (30mm) went for 4k miles without punctures, then they gave in to the huge holes I managed to get. I got another set, and managed to get a double puncture on one of them within a week!
they do fix up, and are generally awesome but do be aware they aren’t invincible.
having said that, the bike they were on isn’t very happy – every bearing is broken, and Specialized have just replaced the carbon frame for free – well, they will call the Diverge “a go anywhere Adventure bike!”
Bike Science
Schwalbe S-One Tubless for me
Schwalbe S-One Tubless for me too on the winter bike. Best winter tyres I’ve ever used. They have/are changing name to G-One Speed though as you say. No difference in the tyre though as far as I’m aware. They offer a wired non tubeless version of the tyre too and they’re only £20. Run tubeless though if your wheels allow.
Bike Swanky
Winter tyre choice is more than avoiding punctures, although that is obviously a critical factor.
GP4000 S2 don’t have a compound that works very well in very cold weather.
4 Seasons has a better cold weather compound than Gatorskins for example.
Vittoria’s new Graphene tyres perform very well against punctures it seems. The Rubino Pro Control has a good rubber matrix too for cold weather grip. The older and non Graphene ones are frankly shite!
28c and above gives you lots of contact point with the road.
Larger volume tyres run well at lower pressures without necessarily having the issue of pinch flats.
The Schwalbe S-ones roll very well for a wide tyre with nobbly bits 🙂
I ride in sub zero temperatures on these tyres and have no issues.
That being said, you still need to amend your riding style to the conditions, as you’d expect.
P.S.
Watch out for camber when it is icy. You can find yourself somewhat contrary to the perpendicular if you’re not careful 🙂
Bike Swanky
Tannus LOL http://www
Tannus 🙂 LOL http://www.thesolidtyre.com/
