Bag which doesn’t interfere with my helmet – recommendation needed
  • #23871
    number9dream
    HI All,
    Despite the title I’m seeking some recommendations to help my cycling. I have two rucksacks, both supposedly “cycling friendly” (Deuter Cross Air and NorthFace Hammerhead) but both interefere with my cycling helmet when they have straps done up and are in a comfortable position. I find myself having to slacken off the straps so that the top of the bag doesnt push the helmet forward.
    Does anyone have a recommendation for a small rucksack for commuting which sits low enough on the back not to contact the helmet?
  • #843779
    PonteD
    I have a carradice Pendle,
    I have a carradice Pendle, easy big enough for a full days kit. For lighter days I have a Carradice Zipped roll, i usually use this as my saddle bag for weekend rides as well, more than enough space for a half day. i can even squeeze in a waterproof if I pack it right,
    #843777
    Matt eaton
    I used to commute with a The
    I used to commute with a The North Face Surge laptop backpack which just about fitted my work clothes and lunch. It always worked well on the occasions that I wore a helmet.
    #843775
    gthornton101
    I use a Deuter Cross Air for
    I use a Deuter Cross Air for commuting too, though haven’t had this issue with a Giro Monza helmet up top. My mate at work uses a 15L Osprey and actually, now you mention it, his backpack does sit lower down away from his neck than mine does!
    #843773
    Deuter Speed Lite?
    There are
    Deuter Speed Lite?
    There are 15 & 20L versions, my 15 seems to ‘taper’ towards the top unless it’s stuffed full. Suspect you will have to visit some outdoor shops and try-before-you-buy.
    Would you consider ditching the hat instead?
    #843771
    Malaconotus
    Any laptop will fit in a
    Any laptop will fit in a Camper Longflap (http://www.carradice.co.uk/index.php?page_id=product&under=type&product_id=35) and it would have to be a big one not to fit in a Nelson.
    #843769
    adrianoconnor
    For the past three years,
    For the past three years, I’ve been cycling every day with an Aqua-Quest ‘The Biker’ dry-bag/backpack. It’s 25L, square at the corners (so good for laptops), and 100% waterproof.
    Only clicks on my helmet sometimes when I have it filled to the brim. Normally it doesn’t go anywhere near — I know what you mean though, it is annoying when it does. Might be worth mentioning I’m 6 ft tall (height must play a part in how well it stays away from the helmet).
    Anyway, that’s what I use and it works well enough for me.
    #843767
    Colin Peyresourde
    What about a courier style
    What about a courier style cycle bag? Cycling with a rucksack is a no-no for me.
    #843765
    wycombewheeler
    ConcordeCX wrote:
    Use a
    [quote=ConcordeCX]
    Use a saddlebag. I commute using one of these: http://www.carradice.co.uk/index.php?page_id=product&product_id=38 or one of these: http://www.backcountrybiking.co.uk/product/viscacha/%5B/quote%5D
    pretty sure I won’t get my laptop in there.
    #843763
    number9dream
    number9dream wrote:
    Malaconotus wrote:
    Put the bag on the bike not on your back. Cycling in a rucksack is like carrying a wheelbarrow full of bricks.
    Or lose the plastic hat.
    Easier said than done with a frame without rack eyelets. Rucksack makes it sound bigger than it needs to be – it only needs to carry clothes for the work day. :D
    #843761
    BikingBud
    I have a Kreiga great for
    I have a Kreiga great for road bike, mountain bike and motor bike. Use it everyday. Not cheap but then what is, certainly not Rapha etc and there is far more utility in a good rucksack.
    http://www.kriega.com/r20/
    #843759
    Kadenz
    I had exactly the same
    I had exactly the same problem.
    It was caused by the fact that I have a relatively short torso for a man.
    I solved the problem by buying a Vaude cycling rucksack designed for women, which is shorter in height than the non-gender specific ones.
    I can’t remember what it’s called and it doesn’t have the name on the rucksack itself.
    The key thing is to check the size (height dimensions) of the rucksack before you buy it.
    #843757
    Nat Jas Moe
    Over Board bags are good I’ve
    Over Board bags are good I’ve had one for some time and never have had any wet gear as it is 100% water proof. And it doesn’t interfere with my helmet. Its at a decent price too.
    #843755
    I’ve had this problem too – I
    I’ve had this problem too – I ride with an Altura Zone 25 (sometimes). I find that loosening the shoulder straps a touch but still using the chest strap lets it sit an inch or two lower and it doesn’t foul my helmet. YMMV though, depends very much on position.
    #843753
    thedatastream
    Alpkit Gourdon
    Alpkit Gourdon 20
    Gourdon 20L
    Waterproof, tough, cheap, comes in different colours
    Only downside is a lack of an internal key pocket but some sticky backed velcro and a cheap pencil case can solve that
    I’ve had one for years for cycling with and its ace
    #843751
    J886atv
    Ditto above re Osprey – only
    Ditto above re Osprey – only I’ve got a Viper 9 litre bag – no issues re bag/helmet interference
