- This topic has 53 replies, 37 voices, and was last updated 11 years, 6 months ago by
oozaveared.
March 15, 2015 at 9:52 am #23509
smileydave
I need some help and advice.
i was cut up by a taxi, so shouted at him to give me some room.
as I came along his inside, he engaged me in conversation. I held onto his window frame to balance (clippy pedals), while we discussed highway code rule 163. He drove off without warning. I was in the impossible position of holding onto a (now) moving vehicle, knowing that if I let go I would definitely fall over, so I held on in the hope i could stabilise my self and come off safely – needless to say i didn’t, since he continued to accelerate. He refused to give his detailsI reported the driver to the police and have this week received a summons, charging me with dangerous driving.
Needless to say i am furious. I’ve been stitched up by the system – they only have my details because I reported the taxi driver myself.
an initial consultation with a solicitor is going to cost me £300, and possibly up to £2000 in defence costs. I’ve discussed the case with a JP, who thinks it should ever have come to court. but since it has, I’m forced to act.
the best financial solution, sadly is to take my lumps and plead guilty.I’m wating to find out if my initial statement was ever received by the case manager – I can’t believe that if they’d read both sides of the story they would have prosecuted me
I cannot believe that it was in teh public interest to prosecute me, the victim.
I think that this case will discourage cyclists from reporting dangerous driving, and if anything will encourage them to take the law into their own hands. If i’d scratched him and fucked off, I’d have got off scot free and had my revenge.
thoughts help and advice please kind people of road.cc
oozaveared
oh for god’s sake man. See
oh for god’s sake man. See them in court. That way the magistrates will see your statement and probably give the CPS a rocket. They are going to need to prove that you were cycling dangerously and they probably can’t except that your ststements says you were holding on to the window. But you made the complaint.They are not going to find you guilty and so what if they do. If they do the absolute Max fine is £1000. So that would be absolutely bang to rights for the most eggrwith every single agravating factor, ie drunk or drugged, extended period, multiple instances, poor record, attempting to deny or evade, failing to assist the police etc etc. Since you have oodles of mitigation even if they technically find you guilty it’s a slap on the wrist job.
Get a lawyer if you want and remember most home insurance policies will have cover for that. But seriously man – take the opportunity in court to embarass the silly buggers.
PaulBox
Apart from all the
Apart from all the sanctimonious twats on here, what I find most annoying is that the police/CPS or whoever is responsible for this, is wasting time and money prosecuting the fella. Surely there are more important things to be dealing with…edvelo
Also, there is a big
Also, there is a big difference between leaning on a stationary vehicle to gain balance while staying clipped in, and holding on, as the OP states he was.If the situation arose and I couldn’t unclip, but felt I had to stop to ‘discuss’ with the cabby, I certainly wouldn’t hold on. Instead, I would simply lean using my palm, such that if he drove away, I could easily push off, avoiding this very scenario.
I’m not condoning the cabbies actions, but it seems this whole situation could have been avoided if the OP had just been the better person and got on with his life.
YOLO after all.
rjfrussell
“as I came along his inside,
“as I came along his inside, he engaged me in conversation. I held onto his window frame to balance (clippy pedals)”and
“I was holding on to a stationary taxi . he drove off knowing i was holding on”
The only available analysis of the facts here is that:
1- the Taxi was stopped.
2- the OP, cycling, clipped in, was overtaking on the left hand side. Presumably he considered there was sufficient space to go past on the left.
3- the taxi driver “engaged him in conversation.”
4- the OP chose to stop.
5- But instead of unclipping to stop, he decided to keep his balance by holding on to the window frame.
As to the wisdom of the OP’s behaviour:
Debatable points
– without knowing more detail, there is at least a questionmark as to whether he should have been passing on the inside at all.
– should he have stopped and engaged in conversation with a predictably irate cabby, or just got on with life.
BUT- NO DEBATE ABOUT IT:
– Unclip and put your feet down- do not lean on a vehicle.
If you are unable to unclip sufficiently quickly to do this, it is blindingly obvious you shouldn’t be riding on the road clipped in- ride with flats until you can safely ride clipped in, which means being able to unclip when necessary.
If he could have unclipped but simply chose not to, that is both foolish and rude- and totally unacceptable, in my book- behaviour.
No view on the rights and wrongs of the prosecution, but no sympathy here for the OP. Brought it on himself.
vonhelmet
BigglesMeister
BigglesMeister wrote:smileydave wrote:section 28 actually. thanks for oyur input
Section 28 …http://www.legislation.gov.uk/ukpga/1988/52/section/28
28 Dangerous cycling.
(1)A person who rides a cycle on a road dangerously is guilty of an offence.
(2)For the purposes of subsection (1) above a person is to be regarded as riding dangerously if (and only if)—
(a)the way he rides falls far below what would be expected of a competent and careful cyclist, and
(b)it would be obvious to a competent and careful cyclist that riding in that way would be dangerous.
(3)In subsection (2) above “dangerous” refers to danger either of injury to any person or of serious damage to property; and in determining for the purposes of that subsection what would be obvious to a competent and careful cyclist in a particular case, regard shall be had not only to the circumstances of which he could be expected to be aware but also to any circumstances shown to have been within the knowledge of the accused.Have they charged you under the correct section ????????? You may well have been hanging on (an offence under sect 26) but not dangerous cycling (sect 28)!!!. Is it a moot point ? Unfortunately, you’d prob need to speak to your defence again to find out!
Have they charged him under the correct section? Well, let’s look at the conditions:
legislation wrote:(2)(a)the way he rides falls far below what would be expected of a competent and careful cyclist, andI wouldn’t expect a competent and careful cyclist to be hanging on to a vehicle, moving or otherwise. It seems most of us here wouldn’t, given that many have said he should have just put a foot down. Frankly I’d never touch a driver’s car if I could avoid it for fear of getting thumped. The same would be true if I was a fellow driver at the time or a pedestrian. Don’t interfere with someone else’s property.
legislation wrote:(b)it would be obvious to a competent and careful cyclist that riding in that way would be dangerous.Likewise. It should be obvious that if you’re hanging on to a stationery vehicle (presumably one with its engine running?) that it could imminently become a moving vehicle, which would be a bad thing.
legislation wrote:(3)In subsection (2) above “dangerous” refers to danger either of injury to any person or of serious damage to property;OK, so we’re looking for danger of injury or serious damage to property. Considering that the OP ended up injured and with damaged property, an outcome that could have been reasonably foreseen, that seems pretty open and shut.
It seems they’ve charged him under the correct section. OP should have just put his foot down and not started grabbing onto a car.
jacknorell
bashthebox wrote:There’s just
bashthebox wrote:There’s just too many of us in London; using the congested roads is a stressful experience…Not really, there are just too many idiots* who insist on driving whether actually needed or not.
*Plenty of people who have good reasons for using a car as well, and no issues with that. Able-bodied people not needing to carry a lot of stuff shouldn’t drive though.
bashthebox
Drivers are generally awful
Drivers are generally awful in London. My GF has to drive to work because she does shifts at all hours – SE15 to Chiswick – and her experience in a small car is sometimes almost as terrifying as riding a bike can be. People cut people up, pull out stupidly, lean on their horns, tailgate and brake check – all the shit we have to deal with. Ok, you’re protected in the metal box, but it’s still shit.
There’s just too many of us in London; using the congested roads is a stressful experience for everyone because there’s a significant minority using the roads in an angry and aggressive way – and I would include some bike riders in that too, though bikes can’t really cause damage to anyone (pedestrian crossing jumpers aside ).
For our safety and sanity, segregated routes are the only real solution. You can’t, sadly, stop motorists from making mistakes, being angry, or generally being fucking tools.BigglesMeister
hylozoist
hylozoist wrote:BigglesMeister wrote:smileydave wrote:section 28 actually. thanks for oyur inputSection 26 …
http://www.legislation.gov.uk/ukpga/1988/52/section/26
26 Holding or getting on to vehicle in order to be towed or carried.
(1)If, for the purpose of being carried, a person without lawful authority or reasonable cause takes or retains hold of, or gets on to, a motor vehicle or trailer while in motion on a road he is guilty of an offence.
(2)If, for the purpose of being drawn, a person takes or retains hold of a motor vehicle or trailer while in motion on a road he is guilty of an offence
[…]I’m fairly sure that the OP is either a troll or at the least not giving a full and accurate version of events, but as an aside, hanging on to a vehicle because it has moved off and you fear falling if you let go is likely not an offence under section 26, due to the “If, for the purpose of being carried” qualification. If you can convince a magistrate that you were holding on for any reason other than getting a lift (such as being too scared to let go), then they should not convict you.
<:P
26 (2) “If, for the purpose of being drawn” qualification may cover it.
There’s also the question of intent and reasonable doubt which is important when considering if an offence has actually been committed. It may even be that plod is just fishing hoping the OP will plead guilty as then he get’s a free one to add to the conviction rate.
hylozoist
BigglesMeister
This is of course irrelevant as the OP now states it is section 28 and in any case I am not sure they could convince a magistrate of anything based on this thread. One alternative reading between the lines view of the incident could be that the OP continued to hold on to the cab door after it drove off in order that they could continue to remonstrate with the driver. This would be covered by section 28 I think.
As several others have said to the OP: get legal advice. Speak to someone who is qualified to help you, and tell them the full truth. Avoid any temptation to make comments about their mothers. You may also want to speak to Citizens Advice as a first stop (http://www.adviceguide.org.uk) – they will probably also advise you to speak to a lawyer, but might be able to help you do this and give you some good, free impartial advice along the way.
Finally, what is it with some riders and their aversion to unclipping?.
It’s fair enough all these people teetering at the lights with trackstands of varying quality, but if you’re going to stop and talk to a driver (let alone argue with them), it’s pretty damn rude to balance yourself by leaning on their vehicle unless you know them and know they are fine with it. Try using a random cyclist to balance yourself on at a set of lights and see how you get on if you disagree <:PBigglesMeister
exilegareth wrote:Bear in
exilegareth wrote:Bear in mind that the original post resembled an application to be on the Jeremy Kyle show, but….if you don;t think hanging onto a taxi while you’re being towed up the road is dangerous, where exactly would you draw the line?
I think the OPs point is that the driver pulling off with him holding onto his car is dangerous, to which some cynical lawyer has replied ‘yes it was dangerous, because you held on…'
Hanging on to a moving vehicle is a lesser cycling offence (Section 26 of the RTA). Dangerous cycling is much more serious (section 28 RTA), which he wasn’t (according to the account) – he was just hanging on (an offence under section 26).
In the OP he admitted to hanging on (RTA section 26) not dangerous (RTA section 28) cycling. This looks to me like plod has made a mistake and the OP needs to get some proper legal advice ASAP.
Paul J
abudhabichris:
Eh, a
abudhabichris:Eh, a trademark restricts the ability to trade using a certain mark – the clue is in the word. Merely cycling on a bicycle with fake badges on can not breach trademark law. Further, trademarks are a civil matter – you generally can not be prosecuted for a breach of trademarks, in the sense that word usually applies to being prosecuted by the state for a breach of criminal law.
Copyright on a bicycle: Bicycles are pretty generic. They pretty much all look very similar. Even the latest high-end bikes often have few distinguishing features. Further, such features would have to be creative – not functional – to be covered under copyright. There are also design rights, but those have to be registered. Then there are patents, but there’s little to be patented on a bicycle (outside the groupset perhaps – the big groupset makers patent every silly little thing they can). Also, again, these are all civil matters, and they can’t be brought against the person who bought the bike (though, the bike could conceivably be confiscated, however the bike owner could pursue the vendor for their money back).
Basically, you’re bringing up some rather flawed reasons for why we should disapprove of the OP.
KirinChris
FluffyKittenofTindalos
FluffyKittenofTindalos wrote:abudhabiChris wrote:Your profile says you ride a Condor “pirate version”. Does that mean a fake copy or a homage to Marco Pantani? if you are happy to tell everyone you ride a counterfeit bike then you seem to think the law doesn’t apply to you when you feel like it.
I don’t know about the rest of the discussion (don’t really see what the OP hoped to achieve with posting the hard-to-follow tale here), but you confuse me with this. Are you saying its actually _illegal_ to ride a bike that looks like a different bike?
It’s against the law to copy designs and trademarks and manufacture counterfeit goods.
Someone who knowingly buys fakes is complicit in that illegal process – whether it would satisfy a legal prosecution or not I couldn’t say, but it is taking part in a criminal trade.
In the context of this discussion, it suggests to me that the person who does it has a certain disregard for the niceties of the law, one which doesn’t square with running off to the police to complain about nasty taxi drivers.
Joeinpoole
smileydave wrote:
I”m fed upsmileydave wrote:
I”m fed up with near misses on a daily basis.If you’re experiencing “near misses on a daily basis” then the problem is most likely to be due to your own riding competence … or lack of it. From what I’ve read from your description of events you seriously need to improve your road-craft and also deal with your own anger-management issues.
I can *just about* understand you holding on to a vehicle whilst ‘in discussion’ with the driver but … when it moves off … *you* let go. All day long. You’ll never convince me that holding on to said vehicle was the safer option.
PonteD
A few words of advice:
Get a
A few words of advice:Get a camera, if someone cuts you up then just get home and report it to the police. An errant driver is far more likely to listen to advice from a policeman who has seen the video evidence than they will listen to you, after all a policeman has a personal invitation to a police cell if the taxi driver argues with them.
Learn to unclip from your pedals and in future don’t lean on Vehicles (stationary or not) and definitely don’t hold onto them.
I appreciate it would be useful to hear if anyone else has had a similar experience (clearly not from the responses) but please try not to discuss this any further in a public forum. If anyone has any useful advice, PM them instead, it may be better for you if you don’t effectively give a witness statement in a public forum.
Seek legal advice from a law firm who specialises in bicycle related law not just the local solicitor, a specialist may be aware of similar cases and can give you more informed advice and representation. Thankfully I have never had need to use one so unfortunately for you I cannot recommend one.
Finally, don’t take legal advice from people on forums.
Eebijeebi
Sounds like someone failed
Sounds like someone failed the attitude test. -
