- This topic has 35 replies, 20 voices, and was last updated 11 years, 11 months ago by
fukawitribe.
November 29, 2014 at 11:21 am #22799
fitzey50
anyone riding this set up,
at the moment I’m using 50-34 with an 11-32 cassette and i love it,
i enter a lot of the hillyer sportives and have a little bucket list of all the major climbs in the uk.
next year I’m booked to do the wiggle dragon ride and and also going to the alps to do alp dhuez and col du galibier.
I have just ordered a new canyon ultimate cf slx, the bike comes with 52/36-11/28 and canyon don’t allow you to change it,
Will i really have to spend more money out changing it to compact? -
DanTe
Running Ultegra 6700 50-34
Running Ultegra 6700 50-34 can I just whip both old chainrings off and replace with the 52-36 or is the BCD of the mid compact the same as 53-39 and not compatible??Daks
Agree with most comments
Agree with most comments here. 36-28 will get you up most hills no bother, works for me fine and i’m no climber.petermsmart
36-28 may be enough to get up
36-28 may be enough to get up Huez or Galibier, but it obviously depends on how young and fit you are. I’m 56 years old and have a 30t on the back for my usual rides in the Yorkshire and Derbyshire peaks. I got up both Huez And Galibier climbs on that gearing during six rides in six days in the Alps. But there were times i would have liked a get-out spinning gear when my age caught up with me. This year we are off to the steeper Dolomites and the Stelvio. This time Im going armed with a 34 on the back. Its easy enough to use a chainwhip and put your normal cassette and chain back on when you get home. But all this is for old weary legs like mine. Please ignore if you’re a young whippersnapper!joemmo
Scrufftie wrote:I started
Scrufftie wrote:I started with a compact and swapped to a 52-36. I think you’d be able to run a 32 rear cog without changing the rear mech.That would be a 37 tooth difference, I think most short cage rd have a 32t capacity or thereabouts so probably not.
joemmo
Scrufftie
I started with a compact and swapped to a 52-36. I think you’d be able to run a 32 rear cog without changing the rear mech.birzzles
You can get 32 on the Canyon
You can get 32 on the Canyon Ultimate CF 9 SL. I think it is the only canyon bike with this gear. Odd really, as they dont even offer it on the endurance models. 52/36 with 11-32 on a 11 speed is a reasonable substitute for a triple, giving a good spread of gears. The key isnt just what the lowest gear gives, it is also the pattern of ratios through the cassette. It is worth thinking what ratios you regularly use on your current setup, and work out how these would translate into your new setup. For example i often use 39/16, on a compact this would be either 34/14 or 50/20. Lots of manufacturers are now giving 11-32 in 2015, this makes more sense with 11 speeds to play with, and starts to make triples seem less necessary.macrophotofly
Going from a 34-32 to 36-28
Going from a 34-32 to 36-28 is likely to change in the way you cycle hills. I’m not sure all of the other comments have spotted that you will be losing on both cogs. With 36-28 it will basically be like your current 34 with the largest cog on the back being a 26 or 27 (26.4 to be precise). Can you climb comfortably with that?
I do a fair bit of weekend mountain climbing (just club, no competitions) here in Japan and I have compact on the front with a 26 largest on the back so it is quite possible – but my cadence is in the 66-78 range (I’m guessing you currently like to spin up a hill at 80?).I’d happily change to a mid compact (36) on the front with a 28 on the back – I find I swap too often between the front cogs on a compact when things flatten out. So I’d say keep the 52-36 crank and if you want to spin up the hills get a 32 cassette with the Ultegra GS long cage 6800 RD (you can always swap back in the 28 cassette for winter riding!). You’ll still be losing a bit to your current set-up but 36-32 isn’t as signifigant as a 28
macrophotofly
Daveyraveygravey
fitzey50 wrote:Thanks for all
fitzey50 wrote:Thanks for all the great replays on this
The canyon is my dream bike so I can’t put my old sram crankset on it,
It does hilight a problem if you r buying a canyon bike, the only model I can buy with a 34/50 crank on is a bike I don’t want.
So I’m having to buy the bike I really want, with the gears I don’t !
Canyon should look into this because it must put some people off..
The mid-compact makes Canyon even more attractive for me! I run a 53-39 with a 12-27 cassette; I feel a 52-36 will be a better compromise and as the other posters have said you can change the cassette easilyReg Molehusband
Shamblesuk wrote:I went from
Shamblesuk wrote:I went from a perennial 50/34 user to 52/36 when I bought my R3 this year, and was worried how I would manage on Toys Hill etc, not being a whippet by any stretch of the imagination.I wouldn’t conceive going back to a 50/34 now. Paired with 11-28, for me it’s the perfect ratio. I no longer spin out going down Ide Hill as I used to.
Horses for courses, of course.
Like Shamblesuk, I have the 11/28 and 52/36 setup on my 2015 Genesis Equilibrium 20. It came as standard and I’m very happy with it for the same reasons.
joemmo
At the risk of repeating
At the risk of repeating myself, you’re focusing on the chainset but it’s the cassette that is going to make the difference here, not 2 more teeth at the front.With an 11-28 you will be losing your bottom gear, your lowest gear will be pretty much the same as to the second lowest on your current bike. If you can live with that then I wouldn’t fret over it.
fitzey50
Canyon should look into this because it must put some people off..ajmarshal1
The difference in gear inches
The difference in gear inches between a 36-28 and 34-28 is minimal (36 v 34 funnily enough?). If you can live without your 32 on your compact, you can live without it on the semi. 36-28 is more than enough on Huez or Galibier.therevokid
bung the sram chainset on the
bung the sram chainset on the ultegra bike … it’ll work (look pants mind you !!) -
