- This topic has 33 replies, 23 voices, and was last updated 10 years, 4 months ago by
therevokid.
October 5, 2014 at 7:18 pm #22512
Cooperdan
Hi, as the subject suggests, I have had countless problems with my Garmin Edge Touring sat nav and was wondering if anyone else has? I downloaded routes this summer when I rode LEJOG with a touring company (fortunately, I had paper back up maps) and despite having these routes, the damn gadget wanted to take me off road! Before anyone suggests it, I have set it for ‘road only’ as I am on my road bike, etc.
Hilariously, whilst on the Yorkshire tour sportive last weekend (again with a downloaded route), the Touring wanted to take me off down a trail again! I switched it off and followed the masses.
I have done routes via strava but haven’t got around to testing them on the Touring yet but am rapidly getting fed up of its inane ways – a real waste of cash!
What are anyone else’s experiences? 8|
therevokid
been happily using a touring
been happily using a touring plus for 6 months or so without any problems.
read the dcrainmaker and ridewithgps hints and tips and now follow routes
plotted with turn by turn that hasn’t missed a beat.
perhaps some rtfm may be in order before slagging it off ?
Flipsixty4
I bought a Garmin Edge
I bought a Garmin Edge Touring in April 2016. After a month of use, during which it said it couldn’t navigate the route a few times it simply froze. Sent it back to AS adventure (Belgium). 4 weeks after that they lent me another device while ‘Mr Garmin’ looked at the one they sold me. That one didn’t work properly either – didn’t display maps! 6 weeks later I finally got them to agree refund. So my conclusion is that the Garmin Edge Touring is not fit for purpose and I wouldn’t recommend buying from AS Adventure either. I’m gonna try using my iPhone with MapMyRide app as a far cheaper alternative.
vonhelmet
I have way more trouble with
I have way more trouble with my Garmin in Windows than in OS X. It takes forever to sync in Windows and keeps corrupting files.wellcoordinated
abudhabiChris
abudhabiChris wrote:abudhabiChris wrote:But, halfway through the ride it decided the memory was full and stopped recording.
There is nothing in the user manual about memory shortages or anything that might help explain what’s going on. I can’t even download the firmware updates because it says the device is full.
Update on this, for posterity and in case anyone else with the same problem finds this thread.
I found on some user forums a suggestion that if using a Mac you have to empty your Trash file, WITH THE GARMIN CONNECTED.
Apparently Mac puts lots of ghost files onto the Garmin, or doesn’t delete them or something bloody stupid like that. But just emptying the Trash doesn’t help, unless the Garmin is plugged in.
So I did it – took hours – and it worked.
A Mac doesn’t do anything other than show you what Windows does not. When you put a gpx file in the NewFiles folder on your device, the Garmin device processes the file to make it available as a course. When it does this it renames the gpx file with a ‘.’ prefix. The Mac is more likely to show you this than Windows unless you turn on show hidden files. Windows or Mac the folder gets filled up with all the files that you put there.
KirinChris
But,abudhabiChris wrote:But, halfway through the ride it decided the memory was full and stopped recording.
rjfrussell
Using ridewithgps you still
Using ridewithgps you still have to be very careful plotting a route- it too has a tendency to take you off road unless you plot the route in very short steps to make sure you stay on the black.Chippycyclist
Don’t give up its a good
Don’t give up its a good piece of kit once all the set up issues are sorted, I had all the same issues at the beginnin. Its how you set up the device to start with, which the rubbish Garmin manual and web don’t explain and Garmin Connect I regard as useless.
Two very good websites VELOGPS and RIDEWITHGPS which give a full and detailed low down on setting up a Garmin Velo is especially good.
The basic problem your having is that the base map is taking over your upload and rerouting you, Velo will advise how to prevent this.DanTe
You’ve turned ‘Lock On Road’
You’ve turned ‘Lock On Road’ on in the settings?
It seems it’s always new users that have problems with the things. It was the same for me. I hated it for the first few months.
Garmin need to look at that, they won’t, they’ll just keep adding ‘cool’ new features that will just further complicate things.
Do not use the Garmin site for anything, it’s terrible!
I use strava route plan – download gpx – new files – eject properly and it’s really easy.
If I go off piste I tend to just drop a pin where I want to go and then navigate to that. Always works fine. Keep recalculate on but switch it prompt so that you can say yes or no.Cheeky request: after 3 years of Garmin use, if you’re doing tight overlapping loops in the same area, how do you make sure you’re following the correct flow of the route from start to finish?
There must be a way I just haven’t ever looked into it.rjfrussell
is the Edge 1000 any better
is the Edge 1000 any better or do people with it have the same sort of complaints?keef66
wellcoordinated wrote:keef66
wellcoordinated wrote:keef66 wrote:Out of curiosity I’ve just been on ride with GPS and tried to make it route me down the various detours the Garmin has tried, but it stubbornly refuses to send me off road, whichever map I choose.So why does the Garmin??
So there’s your solution. Plan the route on Ride with GPS and download it to our Garmin. You can do it for free. Just export a gpx file and the put the gpx in the New Files folder on the Garmin. This is what I do and providing I keep my eye on Ride with GPS when digitising the route everything is fine.
That’s exactly what I’ve resolved to do, but it still means that one of the Edge Touring functions, namely the ‘suggest a circular route of a certain length’ one, is essentially useless. Which is a pity because that’s generally what I wanted it to do, without having to faff with the pc.
I’d still be curious to know why it works on OSM / RWGPS but not on the Garmin…
KirinChris
I’m ready to put my Garmin
I’m ready to put my Garmin 510 under a bus – without me attached I hope.Did a big ride yesterday around Dartmoor. 150km with some really hard climbs. I had plotted the route from Strava, downloaded to the Garmin and deleted all my other activities.
The route-tracking is basic but I find it adequate for areas like that where it’s usually pretty obvious which way the route is heading.
Consequently I don’t have any of my data from the hardest parts of the ride, nor are my times up the climbs recorded on Strava.
This happened to me last year on a trip to Scotland when I did the climb up Bealach Na Ba. The Garmin satellite tracking didn’t overlay to the actual road so Strava decided I hadn’t done the climb.
I am just waiting for someone to come along with a decent device that doesn’t rely on also having a smart phone. I’ve already ditched the Garmin HR unit.
wellcoordinated
keef66
keef66
wellcoordinated wrote:When a
wellcoordinated wrote:When a Garmin device that includes mapping sends you down a track, the problem is nearly always with the map source and not the Garmin device. Garmin has no control over the map base and if a track is flagged as a road in the map base then it the device will think it is fair game, if you have set for roads only.I use Ride With GPS, which is great but aslo not infallible. If you casually click points miles apart when digitising the route the software will work out a route between your points, but beware. Even with the RWGPS set to cycling it still uses some tracks to route between the two points – its the same with all applications using OSM maps. It’s up to you to check the route before you ride.
You could of course submit corrections to the OSM base, but that’s another story..
But that’s my point. There’s a footpath near Snailwell that the thing always wants to take if I’m in the area. It’s so overgrown you’d struggle to walk down there. I looked on OSM and it is tagged as a footpath. I pointed this out to the OSM mods and they replied quite tersely saying it was correctly flagged as unsuitable for cycling and that the problem must be with my Garmin. I keep the maps up to date but the issue persists.
As you suggest, in future I’m doing all my road route plans on the pc and scrutinising them closely for any non tarmac suggestions before uploading them to the Garmin.
rnick
Well I’ve had my Touring+ for
Well I’ve had my Touring+ for 8 months now and in terms of routing (imported from Garmin’s site) it’s poor. Despite changing the settings per Garmin, I’ve still enjoyed some interesting off road travels, the most amusing being a detour down a bridleway which started fine, but soon livened up by a herd of heifers in hot pursuit who were keen to find out just what the shiny object was (new PB for 500m cross country).Anyhow, I’ve given up importing maps and have found inputting location names directly worked far better, but still not perfect. I take a map as back up if heading further afield.
