The Boardman Mens Waterproof Jacket is designed for use both on and off the bike and, typically for the British bike brand, it is extremely well priced. It has a detachable hood and excellent reflectives – and it lives up to the ‘waterproof’ part of the name very well. But I didn’t find it that breathable, which makes it more one for commuter riding than all-out efforts, and it has a less luxurious feel than some of the brand’s other cycling kit.
First off, this isn’t a dedicated road jacket with a skin-tight aero construction, but one Boardman says is designed ‘for use on and off the bike’. This makes it an option for the daily commute on the bike that you can also wear for walks to the shops or pub. And if it’s not raining, you can pack up the jacket and stick it in your bag – it’s a little too bulky to fit in a jersey pocket.
2025 Boardman Mens Waterproof Jacket - chest lgo.jpg2025 Boardman Mens Waterproof Jacket - collar.jpg2025 Boardman Mens Waterproof Jacket - collar open.jpg2025 Boardman Mens Waterproof Jacket - hood.jpg2025 Boardman Mens Waterproof Jacket - hood zip 2.jpg2025 Boardman Mens Waterproof Jacket - hood zip.jpg2025 Boardman Mens Waterproof Jacket - hem toggle.jpg2025 Boardman Mens Waterproof Jacket - front pocket.jpg2025 Boardman Mens Waterproof Jacket - cuff adjustment.jpg2025 Boardman Mens Waterproof Jacket - cuff.jpg2025 Boardman Mens Waterproof Jacket - back.jpg2025 Boardman Mens Waterproof Jacket - shoulders.jpg2025 Boardman Mens Waterproof Jacket - tail.jpg2025 Boardman Mens Waterproof Jacket - vent.jpg2025 Boardman Mens Waterproof Jacket - pocket.jpg2025 Boardman Mens Waterproof Jacket - reflective back.jpg2025 Boardman Mens Waterproof Jacket - reflective front.jpg2025 Boardman Mens Waterproof Jacket - reflective shoulders.jpg2025 Boardman Mens Waterproof Jacket.jpg
The construction doesn’t have the feel of a high-end road jacket either, but then again it does have an entry-level price. The outer material is shiny and hard on the reflective sections, with a slightly softer feel elsewhere.
2025 Boardman Mens Waterproof Jacket - reflective shoulders (Image Credit: Farrelly Atkinson)
Inside the outer shell is a mesh net layer, which reminds me a of a tent’s fly net, which is designed to let air circulate.
The front has a full-length zip with poppers at the top and bottom, and just as with a regular civvie jacket there’s a zipped pocket either side.
2025 Boardman Mens Waterproof Jacket - front pocket (Image Credit: Farrelly Atkinson)
The rear zipped drop-in pocket more akin to that of a regular cycling jacket.
2025 Boardman Mens Waterproof Jacket - pocket (Image Credit: Farrelly Atkinson)
There’s also a rear vent, presumably to let some heat out when you’re working up a sweat.
2025 Boardman Mens Waterproof Jacket - vent (Image Credit: Farrelly Atkinson)
A small fleeced section around the neck that feels nice against your skin, and there’s a detachable hood, which is secured with a zip.
2025 Boardman Mens Waterproof Jacket - hood zip 2 (Image Credit: Farrelly Atkinson)
When the hood’s off the zip is covered by a Velcro flap, which helps to make it look like a regular non-hooded jacket.
2025 Boardman Mens Waterproof Jacket - hood zip (Image Credit: Farrelly Atkinson)
I found the fit reasonable when I was riding, though there was a little flapping, which I’m not used to in a road-going jacket. The medium-size jacket came up true to size and there was room for a few layers underneath, handy when things turn cold.
2025 Boardman Mens Waterproof Jacket - collar open (Image Credit: Farrelly Atkinson)
This is also true of the Velcro cuffs, but again these make it feel less of a cycling-specific option than an all-round jacket that you can use on the bike.
2025 Boardman Mens Waterproof Jacket - cuff adjustment (Image Credit: Farrelly Atkinson)
I didn’t find the jacket that breathable, and you will get quite sweaty if you’re working hard – but nothing like one of those super-plasticky ponchos, which can feel very unpleasant against your skin.
The highlight of the jacket is that it is genuinely waterproof. While a lot of the summer has been dry, this has been interspersed with some seriously heavy downpours – and after a few hours riding in some quite serious rain, almost no moisture made its way through. This is very good for a jacket costing just £45.
2025 Boardman Mens Waterproof Jacket - shoulders (Image Credit: Farrelly Atkinson)
If you tend to ride without a bag, you will struggle to fit this in a pocket if it’s not raining, as it’s a big jacket even when it’s rolled up.
This isn’t an issue, of course, if you ride with a backpack, pannier or other bag.
2025 Boardman Mens Waterproof Jacket - back (Image Credit: Farrelly Atkinson)
It also scores well for reflectives, which is exactly what you want from an urban jacket.
2025 Boardman Mens Waterproof Jacket - reflective front (Image Credit: Farrelly Atkinson)
The chest and shoulders are extremely reflective, there’s a reflective strip down the front, on the zip flap, the tail, and on the outside of the arms too, which is a very good location for reflective materials.
2025 Boardman Mens Waterproof Jacket - reflective back (Image Credit: Farrelly Atkinson)
The two side pockets are a decent size, but they aren’t map pockets so they don’t go up that high. The rear pocket isn’t that large either, but it is roomy enough for a bunch of snacks and an inner tube. Its zip does a good job keeping the rain out, but that added water-resistance can make it more of a faff to undo.
2025 Boardman Mens Waterproof Jacket - hem toggle (Image Credit: Farrelly Atkinson)
The hood is a good call for a commuting jacket, but doesn’t fit over a helmet – which seems to me to be a bit of an oversight. However, it is at least removable, which means you can take it off so it doesn’t annoy you when you’re turning your head.
2025 Boardman Mens Waterproof Jacket - hood (Image Credit: Farrelly Atkinson)
If you’re after something that can work on and off the bike, but aren’t too fussy about breathability, packability or snug fit, then the Boardman jacket is a reasonable option. If you’re just after a rain jacket for on the bike though, you may find better options elsewhere.
Value
The Boardman’s £45 price puts it very much in entry-level territory, and at this sort of price I think it does a good job at covering all the basics.
The Madison Roam Jacket Madison Roam Jacket has some similar properties to the Boardman, as it also majors on waterproofing at the expense of breathability. But it does have a more premium feel to it, so its £119.99 price tag feels reasonable.
The Chapeau City jacket is also impressively waterproof and windproof and like the Boardman and Madison it also get a little sweaty. But it’s less than half the weight of the Boardman and its lack of bulk means it’s packable too – though it’s now a much pricier £149.99.
Conclusion
If you’re looking for a genuinely weatherproof outer layer for commuting and casual riding, and for use off the bike, the Boardman Mens Waterproof Jacket is well worth taking a look at. It doesn’t have the premium feel of some its competitors – but then again they don’t have the Boardman’s £45 price tag. It’s not one for packing into a jersey pocket, but if you ride with a bag of some sort, you’re sorted, and it’s great to see such large reflectives too.
Verdict
Good commuter-friendly option that scores very heavily when it comes to waterproofing – and the price is right
road.cc test report
Make and model: Boardman Mens Waterproof Jacket
Size tested: M
Tell us what the jacket is for and who it’s aimed at. What do the manufacturers say about it? How does that compare to your own feelings about it?
Boardman says its “Men’s Waterproof Jacket is the ultimate versatile layer, perfect for both on and off the bike. Ideal for both leisure rides and commuting, this jacket combines style with functionality, featuring reflective detailing to enhance your visibility in low-light conditions, keeping you safe on the road.
“Stay warm and dry with its waterproof fabric, which also provides wind protection for extra comfort. The jacket’s subtle design makes it suitable for everyday wear, while the removable hood offers extra shelter when needed. With two front pockets and a secure rear zipped pocket, your essentials stay safe and within easy reach.”
While there are a few issues – it’s not that breathable and the hood doesn’t fit over a helmet, which seems like an oversight in a commuter-friendly top – its waterproofing is very impressive for a jacket costing just £45.
Tell us some more about the technical aspects of the jacket?
Versatile Jacket for use on and off the bike
Two secure front zipped pockets and 1 rear zip pocket
Waterproof and windproof fabric
Taped seams to prevent water intake
Large panels of reflective fabric for visibility in lower light
Rate the jacket for quality of construction:
7/10
The jacket is well made, though it doesn’t have the premium feel of some of its competitors.
Rate the jacket for performance:
6/10
It keeps you much drier than you’d otherwise be without it – so it does a very decent job there. But it’s not that breathable and if you’re working hard, you will get sweaty.
Rate the jacket for durability:
7/10
So far it’s held up well to use, and there’s nowhere which feels lacking in material, or like it would be easily damaged.
Rate the jacket for waterproofing based on the manufacturer’s rating:
8/10
Boardman and Halfords don’t state the jacket’s waterproof rating but just says that it’s ‘waterproof’ – and it ticks that box very well even in quite long downpours.
Rate the jacket for breathability based on the manufacturer’s rating:
4/10
Boardman doesn’t mention breathability in the jacket’s description – and I didn’t find it that breathable. While this means it really isn’t one for hard training efforts, for slower, more leisurely rides it’s less of an issue. And that’s even more so if you’re using it off the bike.
Rate the jacket for fit:
6/10
I found it a comfortable fit with room to wear layers underneath, which is what you want from a jacket you’re likely to be using for year-round commuting.
Rate the jacket for sizing:
6/10
It fits well and as I’d expect a medium to.
Rate the jacket for weight:
5/10
At 530g it’s far from a lightweight option.
Rate the jacket for comfort:
7/10
Apart from getting pretty hot and sweaty during harder efforts, I found the jacket comfortable.
Rate the jacket for value:
7/10
It’s very attractively priced when compared with most similar jackets.
How easy is the jacket to care for? How did it respond to being washed?
I’d keep washing this down to the minimum and then would wash it very cautiously, as the waterproofing could be compromised, which may result in the need to reproof it.
Tell us how the jacket performed overall when used for its designed purpose
It generally works pretty well – it’s marketed as a waterproof jacket and it’ll keep you impressively dry. And all for just £45. I feel that the hood should fit over a bike helmet, but it is at least detachable. And for the most part it does exactly what you’d expect a commuter-type jacket to do, with the added bonus of large reflective patches.
Tell us what you particularly liked about the jacket
The waterproofing.
Tell us what you particularly disliked about the jacket
Its (lack of) breathability and that it doesn’t fold down small enough to comfortably fit in a jersey pocket.
How does the price compare to that of similar products in the market including ones recently tested on road.cc?
The £45 price makes this one of the least expensive waterproof jackets out there.
Did you enjoy using the jacket? To a degree, yes.
Would you consider buying the jacket? No – it doesn’t suit my type of riding.
Would you recommend the jacket to a friend? Yes – if they want a budget option for commuting.
A fine jacket for commuting, and more leisurely riding, but if you ride hard or want a racier jacket, this isn’t the one for you.
Overall rating: 7/10
About the tester
Age: 25  Height: 174  Weight: 78
I usually ride: Storck Aerfast   My best bike is:
I’ve been riding for: 10-20 years  I ride: Every day  I would class myself as: Expert
I regularly do the following types of riding: road racing, commuting, touring, club rides, fixed/singlespeed, mtb,
