- This topic has 2 replies, 3 voices, and was last updated 3 years, 1 month ago by .
I have the misfortune to own a set of very expensive Zipp wheels fitted with an expensive, and overly complex, Cognition 2 hub, which it seems requires maintenance with monotonous regularity. The manual says only Zipp lube, or Phil’s Bio lube must be used, neither of which seem to be available in Europe. I can appreciate that the finicky internals used in these pieces of junk will be fussy about oil consistency. Whilst there are obviously other lubes which will do the job, I have already had one hub replaced under warranty, due to a failure after only 500km, so am not keen to experiment. Has anybody positive experience of using a different lube.
