Wheel recommendations?
  • This topic has 38 replies, 15 voices, and was last updated 2 years ago by Simon E.
  • #32962
    I’ve sung the praises of the value of my Mason x Hunt 650B Adventure Dynamo Disc wheelset, which has been on my bike since I built it in early 2020, over 16000 miles ago, and needed only minor truing, but at the beginning of my LEJoG I noticed cracks around just about every other rear spoke hole. Fortunately they held up for the whole trip, but I obviously need to do something about it before it fails on a ride. I can either rebuild with a new rim on the same hub, or just replace with a new wheel that has a Shimano 11-speed compatible driver.
    The current rim is 28 hole, 25 mm internal, 28 mm external. Disc brake only, tubeless compatible. Possibly looking for something with eyelets this time. I’d like to get something that will last at least double that 16000 miles. I run 48 mm tyres.
    A little deeper would be okay, not sure about carbon.
Viewing 8 replies - 31 through 38 (of 38 total)
  • #1023917
    mark1a
    Richbeck wrote:
    Richbeck wrote:
    DCR can build you a better replacement!
    Better than 16000 miles for £250?
    #1023913
    Richbeck
    #1023911
    Grahamd wrote:
    A friend of mine binned his Hunts in similar circumstances, then found out that Hunt would have offered a discount on buying a replacement. Not sure if such offers are a regular service, but he regretted his hasty decision.
    Yeah, I might do it, but best case I have another wheel that will crack in under 20k miles, right? I suppose there’s some value in knowing they’ll last at least 1000 miles after noticing a bunch of cracks.
    #1023909
    This looks quite good.
    https://www.velocityusa.com/product/rims/aero-650b
    #1023907
    matthewn5
    David at DCR wheels can
    David at DCR wheels can probably build you a nice replacement, if Hunt don’t stump up.
    #1023905
    Grahamd
    #1023903
    Also, is it worth contacting
    Also, is it worth contacting Hunt? I’m 18 months past their three year warranty period.
