- This topic has 19 replies, 16 voices, and was last updated 2 years, 1 month ago by
Anonymous.
October 29, 2023 at 7:34 pm #32724
martinsynapse
I don’t own a really high end road bike – you know the £13k ones – and while I don’t need one, I often want one… and Instagram and Cyclist magazine aren’t helping with that.
For context I ride about 3k miles a year, much of that urban commuting or out into the muddy wet rural side lanes. I ride in rain & mud – and my bike gets covered in that fine layer of grit all the time. It’s my gym, it’s a tool I use.
BUT as I see people out on a Sunday with expensive but pristine bikes … for example the Trek Madone, Cervelo R5, S-Works Tarmac SL8 etc – I do wonder what it’s really like to own and use one in British autumn & winter?
- Do bikes like these need to be looked after like a fragile prince/princess?
- Do they need to be cleaned after every use?
- Do they require really elaborate servicing?
- Do people who own them keep them for spring & summer only?
- Are they particularly iffy when the roads are frosty?
Do not buy ANY of Dolans “on
Do not buy ANY of Dolans “on sale” or “reduced” bikes due to “cosmetic” defects.These are bikes that were intentionally scratched and labeled that way to shift them onto unsuspecting customers.
I have 5 bikes and was goign to build up a new touring bike. So i bought one of the Dolan “cosmetic defect” cheap bikes. The paint chip was so small and in such a hidden space it was a joke. Really.
So i put this bike on the hook and bought parts a few bits at a time till i had enough to build it.
Turns out the “cosmetic” defect reduced price was not even alinged right when they welded it. IT was either not set right on the weldign jig when they welded it or an idiot went to work on it and did not bother rejecting it. IT went through Q and A like that. The rear brake bolt boss was nearly on the outide rim of a perfectly dished real wheel. That bolt was off by more than a 1/4 inch. Easily.
250 pounds down the drain. They would not refund this citing that it was 1 years since i bought it. Even though it was shipped out faulty.
I wont buy another Dolan if my life depended on it. Shame really, since terry is a good frame builder and built many gold medal winning bikes. But now Dolan has shifted to mass produced junk that is not even tested for Q and A, it seems.
My carbon kuota ultegra DI-2
My carbon kuota ultegra DI-2 is worth just about 3000 pounds. Hardly a “superbike” of the 13k variety but it is paid for and it is the love of my life. I have 4 other bikes.I do not take the kuota out unless there is a %100 of no rain. %100 no rain. If it even looks like a hint of wet weather i dont bother. It is a sunny day bike only because i know what the wet roads does to nice things in the UK.
If you live in area’s that are salted the damage done gets even worse. To me it is just not worth it so i dont do it. I have other bikes for that. I use my touring /shopping/training bike most of the time. A cheap and cheerful bianchi nirone with 5800 105. I have a tubus rack on it and it can carry two ortlieb pannier bags. Perfect for shopping. A full on 700c road racing bike with pannier bags. It does not get any better.
Secret_squirrel
Depends on the Superbike. I
Depends on the Superbike. I did about the same mileage as you last year mostly on my Reilly Gradient. With the possible exception of the frame the rest of the parts are pretty much what you’d find on a mid-high end bike – GRX DI2 and a power meter in my case.
Being a Gravel bike in the winter it gets a fatter tyred wheelset and mudguards but the consumables are either the same or identical spec. (Same wheel bearings across the wheelsets), same BB submerged in puddles etc etc.
Bear in mind there is marginal difference between the high end consumable parts than the mid range ones so they are all built to be fairly robust. Headsets, BB’s, chains, rings – they are all much of a muchness once you get past the all-steel low end stuff.
Bigtwin
1. No. 2. Yes. 3. No. 4
1. No. 2. Yes. 3. No. 4. Some do, some don’t. 5. Depends on the tyres you put on them.
the little onion
My ‘good’ bike goes to bed
My ‘good’ bike goes to bed between November-ish and April-ish. For me, it’s the fact that winter roads knacker moving parts like nothing else. It’s partly the grease and mud, but mostly the grit and salt. Full lenth mudguards help a lot, but they don’t solve all the problems.
huntswheelers
My customers with the top end
My customers with the top end bikes only use them on dry days….and they are already in the Hung up until next year or booked in with me for a service and then hung up. Some are indoor warriors…. most are Gravel/Winter or both cyclist until Easterish….. infact many keep the Gravel/Road mix all year… and use the winter bikes on wet summer days…. As for them being “flaky” some are very and need regular fettling….like regular and as we know, race bikes are washed and set up daily after 100+ miles or so…… I’ve a mid range Italian Campagnolo equipped bike for the summer and it’s hung up already….the other bikes I ride are already in action until we have a sunny day…. I’ve 4 Turbo trainer bikes to sort this week…on site… in man caves and one lady cave
Canyon48
My Canyon Ultimate CF SLX is
My Canyon Ultimate CF SLX is at the lower end of the high-end road bike category (the only difference is I chose not to go for Di2). I choose not to ride it through the winter months, as I’m fortunate enough to have a dedicated winter bike (Whyte Wessex) with mudguards, a bike that sees a lot of abuse throughout the miserable winter.
For context, I ride about 2000 miles a year on my Canyon (dry summer miles) and 3000 miles a year on my Whyte (largely wet autumn/winter/spring miles). I hope the following answers to your questions may be of some use.
1. No, not really any more looking after than a cheap aluminium bike, just don’t prop it up by the frame or throw it on the floor (all bikes, regardless of cost, should be cared for).
2. Sort of. As I ride my Canyon only when it’s dry, I give it a quick wipe down after each ride to keep it shiny! My Wessex sees far more abuse, again I wipe it down after every ride (particularly if it’s got muddy) and I clean it every couple of weeks throughout the winter (I’d do the same to a cheaper Aluminium bike).
3. Nope. Lots of people say hydraulic disc brakes are a maintenance nightmare. I haven’t touched my hyd brakes in about 2 years, they are still sharp. Gear cables need changing as they wear (as per any other bike).
4. Yes. The winter is harsh on bikes (hence I have a winter bike), for example, I use the same type of Dura Ace chains on my Canyon and my Whyte, the poor weather in which I ride my Whyte means the chain wears twice as quickly. All the other drivetrain components wear and corrode quicker in the winter. I could ride my Canyon all winter and simply replace the pars, but I choose not to.
5. No more than any other bike. If you ride a bike over ice, you’ll probably fall off, it doesn’t matter if it costs £500 or £15000.
To be honest, there isn’t much difference between a ~13k bike and a ~7k bike. The main changes will be full electronic gears and a power meter.
The difference between a ~3k and ~7k bike will be aero wheels and a difference in groupset (the more expensive bike may also have a frame light by approx 200 grams).
Looking at it objectively, the difference between a ~3k and ~13k bike will be about 1kg of weight, switching from Shimano 105 mechanical to Dura Ace Di2, a powermeter and some super aero wheels.
theslowcyclistxx
I have space inside but have
I have space inside but have to carry my expensive bike around tight corners, close to white paint on the wall. This leaves me with the option of using my expensive bike only on dry days and my inexpensive bikes outside all year. I am pretty sure, however, that the bikes left outside and used in the winter need much more service and new parts. So it is perfectly possible to have expensive parts on the bikes used in winter, but in my experience this only leaves you with two (in my view not very appealing) options. Either you clean your bike well after each ride in the winter or you replace a lot of expensive parts each year. Most people I know who owns 10k+ bikes and use them in winter will do the cleaning as well. In my case, I try to upgrade my winter bikes with parts that are less susceptible to weather and theft in order to maintain some kind of performance alignment to those who ride expensive bikes all year.
If you have the storage space
If you have the storage space I’d consider taking the budget you have and splitting it between two bikes: I buy all my bikes secondhand, I’ve got a beautiful Specialized Roubaix Dura Ace Pro for “best” and a Specialized Tricross for grim winter days, still a lovely ride but one that’s cheap enough and robust enough to take on the worst of winter without taking too much damage, without needing too much cossetting and without spoiling my rides by having me wincing every time I hit a pothole or go through a deep puddle.
KINGROLLO
If you can afford it then why
If you can afford it then why the hell not. £13K doesn’t even get you a new car these days – drop £600 a month on a new 4X4 and nobody bats an eyelid ! – A bike will most likely give you more enjoyment and of course there are the mental and physical health benefits of cycling as well.
All that said my foray into high end bikes ended in a expensive disaster – The frame creaked from day 1 and eventually cracked…..and cracked again – supplier refused to help – I had to write off an expensive frame (it wasn’t £13k expensive – but it was way more than I needed to spend)
I sourced a replacement frame from Dolan – which has been a revaltion – best bike ive owned. Its got we wondering are these high frames too light ? – I mean fine if you are a pro – your frame cracks they give you a new one – for mere mortals we are at the whim of the supplier – and even if they do help – you are still likely to be without a bike for a while whilsy they test it etc….
So for me – its Boardmans/Dolans/Giants/Merida – I d like to say I let my legs do the talking ……but they don’t these days.
kil0ran
I’m a fan of/convert to PF
I’m a fan of/convert to PF having had three Giant bikes all of which have done big miles in all weathers. Nary a squeak or rattle.
Electronic shifting is less susceptible to road grime and cold weather, same goes for hydro brakes. But yes more work when they do eventually go wrong.
Cugel
kil0ran wrote:
kil0ran wrote:Increasingly capable I think. Most bikes in that category will feature some or all of the following: Fully integrated cabling Wireless or Di2 shifting T47 BBsIncreasingly capable of frustrating the bejasus out of you when they need a fix. Add these to the other factor you mention of “risk is cost of fixing”.
Wot are concealed cables more capable of? Driving you mad with the rattles, drag on the sharp cable bends and inability to fix in less than three days of swearing and doing little dances of rage & frustration? Perhaps they train you to adopt the single position they allow because its far too much effort to change stem length or pitch; or shift spacers up or doon?
Before you ask … yes, press fit BB bearings are much better technically than the screwy ones and also much easier/cheaper to replace. Unless concealed cables get in the bluddy way. 🙂
peted76
– Often yes.. road debris will be more common in winter = scratches, plus some posh wheel hubs don’t like the wet/damp.
– That’s up to you.. but ‘best practice’ would be to give it a quick wash I’m sure.
– Nope. Same as every other bike.. (apart from if you have posh bearings in things, they can take things to a whole new level)
– I have a upper middle class bike, it gets used 90% in the dry and only on the odd occasion in Winter.
– Its the tyres which touch the road not the other parts, so no more iffy than any other bike to ride.
I try not to ride much in the winter nowadays but have done my share of inclement weather rides for sure.. I’d say for any bike, Winter can be hard on them, regular cleaning is a must, when brakes were ‘rim’ then you could wear through wheels quickly if you weren’t careful although I’d like to think that’s mitigated somewhat by discs now.. the key things I used to do were fit mudguards badly, get frustrated with them and then remove them and stick with an ass saver.. either change tyres for something larger or just lower the pressure a bit in existing tyres for more grip, be extra careful around roundabouts, never underestimate a puddle, I would also generally have to replace my lower headset bearings once a year after a winter (but that’s probably more bike model related than something everyone does)..
Key takeaway here is, don’t buy one high end bike, buy two bikes, one high end one and one cheap one for winter. Winter miles = summer smiles.
kil0ran
Increasingly capable I think. Most bikes in that category will feature some or all of the following:Fully integrated cabling
T47 BBs
Hidden mudguard mounts
Space for big tyresProbably the only thing missing is dyno light routing and mounting. Stick some grip tape on the exposed tops of your swanky aero bars and you’re good to go.
The only risk is cost of fixing it if you stack it on field run off, ice, or from sidewinds hitting the aero wheels.
